Old 01-06-2020, 07:36 PM #136
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet has a spectacular aura about daytonaviolet has a spectacular aura about
I just did this last night. It’s a great mod
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 12:52 AM #137
Saker's Avatar
Saker Saker is offline
Saker has a spectacular aura about Saker has a spectacular aura about Saker has a spectacular aura about
MY GARAGE
Saker's Avatar
MY GARAGE
Is your bracket holding the "A" Pillar Cover out?
IF so you can cut that hole larger so it does not hold the cover up/out....
See my pictures in the 1st post.
Best Regards,
Saker
2014 T4R *BLACK* SR5 PREMIUM 4X4 | Saker’s Midnight Build | Scuba Mod | LED LIGHT BAR INSTALL | Disabled DRL Easily | Saker's EBRs Photos Updated 05-21-16| Saker's Previous 2013 FJ TT/SE
Old 01-07-2020, 04:32 AM #138
Drivers Side “A” Pillar Grip Handle Installed on 2014 T4R
Yes I have a bulge as if the bracket is too tall. The round part under the handle actually passes thru the A pillar cover, cutting the whole bigger may not solve the bulge.
But are you referring to the clip? So the opening needs to be cut larger diameter so the clip clears ?
Old 01-07-2020, 04:59 AM #139
ElectroBoy's Avatar
Real Name: Mark
ElectroBoy is a glorious beacon of light ElectroBoy is a glorious beacon of light ElectroBoy is a glorious beacon of light ElectroBoy is a glorious beacon of light ElectroBoy is a glorious beacon of light
ElectroBoy's Avatar
Real Name: Mark
But are you referring to the clip? So the opening needs to be cut open so the clip clears ?
Yes, I had to cut the opening large enough for the clip to clear. But be careful so it’s not too big or the opening may show. Also, with the cover installed I found that the white nylon base on the lower attachment point of the handle needed to be shaved down to make it fit flush with the surface of the cover.
1st Gen 1987 T4R, sold at 180K miles
3rd Gen 2000 SR5, sold at 239K miles
5th Gen 2018 ORP, just interior mods
Old 01-07-2020, 10:14 AM #140
Saker's Avatar
MY GARAGE
Saker's Avatar
MY GARAGE
Yes, as in my photo
Best Regards,
Saker
Old 01-07-2020, 03:25 PM #141
Yes, as in my photo
Thanks I’ll give it a try this weekend
Old 01-07-2020, 03:26 PM #142
Yes I shaved the square base all the way done. I didn’t want to shave the round part where the bolt goes thru as it may weaken the handle. But currently the handle sits very flush to the A pillar.
Old 01-14-2020, 12:42 AM #143
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 will become famous soon enough patkelly4370 will become famous soon enough
All the parts arrived the other day. I got home from work 1½ days later than usual.
So the handle is tomorrows project.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 09:32 PM #144
Jasontamu Jasontamu is offline
Jasontamu will become famous soon enough
Hi everyone....
I shipped out a good amount of orders. Thank you all.
Been crazy at home working on them after work but fun and im glad everyone is happy with it...
If I missed any emails just reply again.
Thank you all.
J
Jasontamu is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 09:46 PM #145
Thank you Jason.
Installed mine the other day. I'll have to do a bit more trimming, but it is secure and really helps with getting in and out.
Old 01-25-2020, 11:42 AM #146
Im out of town on work and brought a few with me in my luggage. If I run out I'll let you know when ordering but I have more back home.
Thanks,
J
Old 01-25-2020, 12:40 PM #147
CutthroatSlam CutthroatSlam is offline
CutthroatSlam will become famous soon enough CutthroatSlam will become famous soon enough
Other than looks, I am at a loss for the purpose/use of this mod. When you're driving offroad, the driver should have both hands on the wheel. It's not needed to get in or out. It looks like it gets in the way.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 12:50 PM #148
I have arthritis in my left knee.
This handle makes it easier for me to get in without using the steering wheel as a handle, prematurely wearing the steering column bearings and not sliding off the seat when I get out, wearing and tearing the seams on the seat cover.
If I was still a young buck it wouldn't be an issue.
I don't use it when driving.
Old 01-25-2020, 12:57 PM #149
Saker's Avatar
MY GARAGE
Saker's Avatar
MY GARAGE
Thank you for your input.
No amount of typing here will obviously convince you of the pros of any of these handles.
Maybe we should just take the one off of the passenger side...., you should contact Toyota and suggest that!
Best Regards,
Saker
Old 01-25-2020, 05:09 PM #150
My 3rd and 4th gen runner had the Oem a pillar bar. Was surprised the 5th gen didn’t have it. The a pillar bar helps to get into a lifted runner. You can also use the steering wheel but sometimes when it moves, you might loose your balance. Wifey is 5’3” and she needs this to get into a lifted runner.
grip , handle , mod , pillar , side
Front Driver side A-pillar Grab handle? Brad2064 5th gen T4Rs 22 05-29-2019 01:14 PM
Driver side a-pillar grab handle? dedonderosa 5th gen T4Rs 30 05-04-2019 02:10 AM
Drivers Side Exterior Door Handle Griswald Classic T4Rs 1 07-11-2017 11:39 AM
Drivers side o shit handle bassmacka 4th Gen T4Rs 8 01-27-2017 11:48 PM
Drivers Side Door/B-Pillar Rattle stamonkey 5th gen T4Rs 3 09-05-2016 12:57 PM
Copyright © 2019
