Old 01-26-2020, 12:29 PM #151
CutthroatSlam CutthroatSlam is offline
CutthroatSlam will become famous soon enough CutthroatSlam will become famous soon enough
Originally Posted by daytonaviolet View Post
My 3rd and 4th gen runner had the Oem a pillar bar. Was surprised the 5th gen didn’t have it. The a pillar bar helps to get into a lifted runner. You can also use the steering wheel but sometimes when it moves, you might loose your balance. Wifey is 5’3” and she needs this to get into a lifted runner.
I do use the one on the passenger, especially since just having surgery on my right foot. Otherwise, I grab the roof.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 04:44 PM #152
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a glorious beacon of light cb1111 is a glorious beacon of light cb1111 is a glorious beacon of light cb1111 is a glorious beacon of light cb1111 is a glorious beacon of light
cb1111's Avatar
While I see the possible advantage of this mod, has anyone had an airbag activation (including the driver's side airbag) following this mod?
While it is easy to say "the manufacturer cheaped out again", the fact remains is that we do not know why it isn't on the 5th generation.
About 10 years ago, vW owners started complaining about the fact that VW dropped the little change cubby on the Golf/GTI. There were pages of complaints on the forums. Long story short, the cubby was dropped due a regulatory requirement that required a knee bolster to prevent submarining following a crash.
The point here is that this mod may prevent the correct deployment of the airbag system. The design of the windshield, A pillars, dashboard and door panels are all part of the equation. Airbags are also designed to reposition the occupant. Perhaps that handle was removed because people's heads were whacking it during certain accidents.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 05:34 PM #153
Saker's Avatar
Saker Saker is offline
Saker has a spectacular aura about Saker has a spectacular aura about Saker has a spectacular aura about
Saker's Avatar
D I S C L A I M E R:
I AM NOT AN ENGINEER AND NOT RESPONSIBLE FOR YOUR ACTIONS, PERIOD. DO THIS MOD AT YOUR OWN DISCRETION
This has been previously discussed as to the location of the airbag and deployment, if you remove both A pillar covers, the airbag uses exact same location. Both mounting holes are in the exact same locations, covers and handles are in the same locations. The passenger side it is unobstructed, how could the driver side be obstructed?
please explain
Thank you.
Best Regards,
Saker
2014 T4R *BLACK* SR5 PREMIUM 4X4 | Saker’s Midnight Build | Scuba Mod | LED LIGHT BAR INSTALL | Disabled DRL Easily | Saker's EBRs Photos Updated 05-21-16| Saker's Previous 2013 FJ TT/SE
Old 01-26-2020, 05:37 PM #154
<<<<'s Avatar
<<<< <<<< is offline
<<<< has a spectacular aura about <<<< has a spectacular aura about
<<<<'s Avatar
Drivers but not Passengers? Seems unlikely reason to have it on one side. It would be gone on passenger side also if hitting the head on it was an issue.
Who Dares Wins
2013 TRAIL KDSS / Forged TRD 17x8.5 Wheels / Nitto TG 285/70/17 / Shrockworks Sliders / ASFIR Aluminum Trans Skid / 5000K HID Low HL / 5000K 10000 Lumen LED High HL /3000K LED Fogs / TRD Billet Oil Cap / B&I Carbon Fiber Dash / TRD Black Shift Knob / LED Interior / XUJI Leather Steer Wheel / Aluminum Pedals / Aluminum Battery Holddown / Northstar AGM battery / TRD Carpet Mats / LED floor lights / ARB on-board Air
<<<< is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 06:04 PM #155
Space King's Avatar
Space King Space King is offline
Space King has a spectacular aura about Space King has a spectacular aura about
Space King's Avatar
Yes, there is a risk of the driver's head colliding with the grab handle under certain conditions.
Before doing this mod on my own rig, I reviewed a lot of crash test footage. I determined that it would not interfere with correct airbag deployment. However, during a head on small-overlap collision to the driver's side, the driver's head does tend to traverse towards the a-pillar region. Which I suspect is the reason why Toyota chose not to put a grab handle that area.
Unfortunately, if I ever get in such a wreck, whacking my head on the grab handle will probably not be my biggest concern... the highest risk of injury will occur when the front tire rotates into the passenger compartment and crushes both of my legs.
In any event, it's a risk I'm comfortable with.
"Sometimes I sit and think. Sometimes I just sit."
Space King is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 06:05 PM #156
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 has a spectacular aura about patkelly4370 has a spectacular aura about
This is from a previous post.
"Btw not sure if it was mentioned but I 100% guarantee this handle was left off just the US 4Runner because of US-specific crash testing.
Not positive which test, but I'm guessing that it impeded on the dummy (or the dummy's momentum pushed it into the handle orclose to it) in some offset or frontal crash.
Guessing something about the GX or other model Lexus SUVs made it impede differently or to a lesser extent."
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 07:36 PM #157
cb1111's Avatar
cb1111's Avatar
Oddly enough, the driver and passenger react differently in crashes and it is in the small overlap crash where Vince's head can impact the handle on the driver's side, but Larry doesn't whack his head on the passenger side.
So you're OK with traumatic brain injury in addition to some leg damage? BTW, on the driver's side small overlap test, the front wheel folds under the car.
I'm always amazed as how the passengers and the drivers react differently in accidents and that is, in part, because the body structure is different on both sides.
A prime example is the Jeep Grand Cherokee, that failed in the small overlap test. At the time, that test was only conducted on the driver's side, so they beefed up the structure on that side in 2016. They added the passenger side test and - of course - it failed the test.
The bottom line is that it isn't always the greedy bean counters that cause a change.
Old 01-26-2020, 08:02 PM #158
Space King's Avatar
Space King's Avatar
So you're OK with traumatic...
It's all about risk assessment. If collision safety was my primary criterion, I wouldn't even be driving a 4Runner in the first place.
I understand your concerns and they have been duly noted. But at this point, you're starting to tread close to territory.
-3165-jpg  -3166-jpg
Old 01-26-2020, 10:35 PM #159
cb1111's Avatar
cb1111's Avatar
That's my specialty
None of us ever expect to get into an accident - but - the 4Runner is quite a capable vehicle and no "less safe" than most other vehicles.
Old 01-27-2020, 04:37 PM #160
Jasontamu Jasontamu is offline
Jasontamu will become famous soon enough
all pm's replied and emails as well. if i missed anyone please let me know.
thanks,
-J
Jasontamu is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 05:08 PM #161
this entire mod was a result of my wife being 5'-1" and being use to having a handle on all her prior SUV's....
-J
Old 02-24-2020, 08:50 PM #162
ruskieT4R ruskieT4R is offline
ruskieT4R is on a distinguished road
Been following a long time, with a fair bit of reading.. figured joining here was the next logical move. Very much looking to do this mod on my '19!! It seems as if every vehicle except for one of my coupes had a handle on the A pillar...
Thank you to Jason for going the distance and creating the fix. Is your email correct on the first page of this thread? Ive got the handle and the bolt covers.
If the brackets are still available, I would love to order one!!
ruskieT4R is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 10:18 PM #163
Yes in stock...email me.
Jasontamu2002@gmail com
J
Old 02-25-2020, 11:07 AM #164
Chyclone Chyclone is offline
Chyclone is on a distinguished road
I'm not surprised toyota doesn't offer this as an accessory, but I'm shocked that there aren't 3rd party companies that offer it. Good on ya, Jason.
Chyclone is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 04:33 PM #165
JustATallDude JustATallDude is offline
JustATallDude is on a distinguished road
Sent you an email Jason! I am excited to get this done. I love the look and if it can make life easier getting in then it's all a win!
JustATallDude is offline   Reply With QuoteReply With Quote
grip , handle , mod , pillar , side
Front Driver side A-pillar Grab handle? Brad2064 5th gen T4Rs 22 05-29-2019 01:14 PM
Driver side a-pillar grab handle? dedonderosa 5th gen T4Rs 30 05-04-2019 02:10 AM
Drivers Side Exterior Door Handle Griswald Classic T4Rs 1 07-11-2017 11:39 AM
Drivers side o shit handle bassmacka 4th Gen T4Rs 8 01-27-2017 11:48 PM
Drivers Side Door/B-Pillar Rattle stamonkey 5th gen T4Rs 3 09-05-2016 12:57 PM
