01-04-2021, 01:13 PM
#226
Originally Posted by glwood54
Hello
@ smeerun
. New guy here, I've been following this thread and yours on the subject for some time. I have everything on order to complete this mod, the parts are due to deliver today. One question - do you need to remove all the raised portions of the bottom mounting surface of the grab handle with a dremel, so it's flat, with no raised surfaces? Thanks!
yes correct. the bottom of the handle has square shapped sections that protrude that require to be cut off with a sharp razor box cutter type knife or dremel them off.. they are like tabs that need to come off...
the round area where the bolt goes stays but the square section needs to be cut flat.
-J
01-04-2021, 02:26 PM
#227
Banned
Real Name: Mark
Banned
Real Name: Mark
The above post had the photos showing when I posted it, now they don't show up. I'm not sure what the deal is. I did everything
@ ElectroBoy
listed above in order to upload the photos...I guess I am not up on the nuances of T4R.org.
Hmmmm...
Maybe you’re trying to upload a photo that is too large. I’ve had the process choke for me if a photo is over 1Mb or so.
01-04-2021, 04:52 PM
#228
Received my kit last week and my handle & covers today. Looks like I've got a project for tomorrow!
Sent from my SM-G986U using Tapatalk
2019 MGM TRD ORP
Dobinsons IMS 3in lift, FN f(x) Pros 17x8in 0 offset, 285/70 C load Nitto Ridge Grapplers, and all sorts of other fun stuff
shootn4runner on IG
01-04-2021, 04:54 PM
#229
-J
Thanks for the response. After getting the bracket mounted and the trim piece back on, it became apparent what needed to be cut. I ended up cutting the round raised portion of the bottom mount flat also in order for the handle to be flush. Nothing off the top mount as far as the round raised portion, just the square notch thingie.
01-04-2021, 05:00 PM
#230
Originally Posted by ElectroBoy
Hmmmm...
The two JPG photos I uploaded are about 350 kb each. Too large? They showed up initially when I posted the reply, but when I navigated to another thread, then back, they just have this showing:
-img_1488-jpg -img_1489-jpg
Would they work if I uploaded them as thumbnails instead of full size?
01-04-2021, 06:08 PM
#231
Hmmmm...
I've had nothing but issues trying to upload pics from my phone, even small ones, so I just use imageshack
Best Regards,
Saker
01-05-2021, 11:59 AM
#232
I don't use any photo store/share sites since the great Photobucket debacle, so I guess I am out of luck being able to post any images on this forum.
01-05-2021, 02:03 PM
#233
Did mine today. It was a lot easier to do than I expected. Once my Dobinsons IMS kit is in and installed and the new wheels & tires are on, it's going to be getting daily thanks from my old knees.
2019 MGM TRD ORP
shootn4runner on IG
01-05-2021, 03:29 PM
#234
Yep! Thats what I was trying to say, once you get it mounted up it will be clear what you'll need to shave down to make it flush.
I highly recommend using imgur.com to host images for the internet and here is why:
Reddit.com is one of the largest conglomerate of online communities (globally) and >80% of people host their images on Imgur and then post to reddit. It would be detrimental to the historical value of Reddit's posts if Imgur were to ever go under and thus it's extremely likely that Reddit would acquire Imgur simply to retain both the simplicity of Imgurs image hosting service and to avoid the Photobucket situation all over again.
Of course, we can never fully know what the future holds and we're just a bunch of folks hoping that these sites all stick around.
Glad you got the handle installed regardless!!
[ Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo OC A/T III 265/70/17 (TE Wheels) | Dobinsons UCA's + C59-302/GS59-700 Front + C59-500/GS59-705 Rear | C4 Rock Sliders | SSO Roof Rack | Ironman 8.5" Awning | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs | CTH Folding Mirrors + LED Sequential Blinker Mirrors
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Blue Ridge "Attic"
01-06-2021, 08:57 PM
#235
Real Name: Jon
Real Name: Jon
Sadly Doesn't Work on All 5th gens
Well I'm sad to write that this kit doesn't work with ALL 5th gens. I was so excited to install this in the truck to surprise the wife but unfortunately I cant. My 4Runner is a 2011 Trail Edition and appears to have a different A-Pillar and air bag design. As you can see in the photos the "SRS CURTAIN AIRBAG" logo is in a different location, and not actually a bolt cover. The A-pillar is also not supposed to be removed by just anyone. There is a one way clip at the top that the will only release if you break it. It looks like the A-pillar is connected to the airbag with a ribbon and I'm guessing Toyota was protecting people from removing the cover and messing up the airbag.
Good news is its easy to tell by looking if you are one of the few like me that this won't work for by looking at the airbag warning logo. I'm also happy to say this kit wont go to waste, a friend is going to use it on their rig.
Jon
1997 SR5 3.4L Aussie Locker rear, OME lift, Home made bumper, safari roof rack. - "Klause"
2011 Trail, Salsa Red, KDSS, Nav, Toytec ultimate lift, Shrockworks Front Bumper, Front Runner 3/4 Roof Rack - "Oliver"
01-06-2021, 11:44 PM
#236
Originally Posted by <<<<
Jason, do you have bracket and install instruction for pre facelift 5th gen (2010-2013)? On my 2013 SRC cover doesn't exist whole A-pilllar cover is one piece. Also removal of it is not simple pop it off and looks like some cord holding it and must be cut. Without clear instructions I'm hesitant to cut anything near curtain air bag.
Yes, it can be done, it takes two brackets and have had people do it successfully just need to line up brackets with out the plastic apillar in place then install the apillar and drill holes into it.
you can just remove that cover, the cord can be removed. the airbag is installed AFT of where the handle goes and airbag is not affected at all.
-J
So did you contact Jason and inquire about your model ?
It looks like someone asked about earlier year models and was told it would work, but not with the bracket you describe!
Reach out to Jason and see what you really needed.
Best Regards,
Saker
01-07-2021, 10:53 AM
#237
hi yes, it works on 2011 i have done it before. please email me and we can figure it out as this thread is 2014+ and there is a way to get it going for older models. 2010-2013's.
-J
01-07-2021, 12:02 PM
#238
Real Name: Jon
Real Name: Jon
-J
Awesome support from you guys thank you so much! I'm excited again to get this installed.
Jon
02-15-2021, 05:11 PM
#239
Ordered and paid this past weekend, thankfully Jason is still making these! Thanks Jason for the quick reply. Man, I used this handle all the time on my 2002, it will be great to have it on my 2017 now. Thanks Saker for doing the original write up.
2017 SR5 prem in silver: Viper remote starter, Carista fob mod, Aries mats, Rhino Rack mast holder, BLACK Fluid Film, TRD forged billet oil & radiator caps, LED puddle mirror, map, cargo & reverse bulbs, Kat's battery wrap, Bilstein 5100 level lift, OEM hitch cover, glove box organizer, ARB Scuba mod, Lamin-X yellow w/ Calais yellow LED, lift gate stickers, dipped emblems, FJ40 shift knob, ambient light sensor mod, MeSo puddle pods, blacked out steering wheel garnish, Driver side A-pillar grip handle...and the fake Pro grill
03-03-2021, 05:59 PM
#240
Real Name: Kevin
Real Name: Kevin
Anybody ever have trouble getting hold of
@ Jasontamu
? Was talking with him last week, and made payment. Now, nothing...?
Bullets, blades, bourbon, and buoyancy. No necessarily in that order.
'21 TRD OR, Nautical Blue, 3" Toytec lift, 285/70/R17 Cooper Discoverer AT3, Toytec rock sliders, blacked out badges, LED high beams, Sprint Booster.
