10-20-2019, 04:56 AM
#106
Originally Posted by FZRunner
Mine didn't go so well. The Pillar never fit right after getting the bracket in there. Followed all the directions, even cutting more out for the bracket, but the pillar would never stay in place. Finally just gave up and finished anyway. Now the pillar has a bulge in the middle area. Looks like shit, but what are you gonna do. I ran out of light so I'll take a pic, for what it's worth, tomorrow. Not blaming anyone, just to be clear, just seemed like my bracket was just a bit too tall. Didn't use washers on the bottom (screw) cause it would have been worse.
Maybe after surgery I can try again with the final steps, new pillars are only $70, so it's not the end of the world.
Make sure you trim enough of the underside so the black plastic doesn't interfere with the bracket.
10-20-2019, 11:49 AM
#107
Real Name: Greg
Real Name: Greg
Yeah, I trimmed via dremel the exact amount Jason showed in the pic, plus. The pillar never wanted to stay attached to the upper part. It would click in with force, then pop out again. It was obvious that the bracket was forcing out the middle. I used tape and a grease to mark the inner side when attached and it was an area completely cleared out. Nothing more I could do, but I tried anyway. That weakened the plastic supports on the side which allowed it bulge even more. I'll try again with a new one in a couple months, and maybe just live the minor bulge and not try to fix something I can't. At least it works.
10-20-2019, 12:06 PM
#108
So I super glued 5 washed to the bottom mount because there’s no way of getting those suckers in there otherwise. I had way too much play in it with only two and if I would have fastened the bottom bolt the whole thing would have shifted down so I’d try adding a few more washers.
Also, once the bracket is fully in place, obviously don’t remove it again, and you put the panel back on when you’re tightening down the handle itself it’ll get rid of some of that bulge in the pillar. Mine did anyway. Hope that helps
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
10-20-2019, 12:11 PM
#109
Real Name: Greg
Real Name: Greg
Yeah i tried washers with tape early on to even things out, it had no effect. I spent two hours trying to make this work, and basically ruined the A pillar in the process. I would never try to back out the screws by the way. It will be a couple months before I can play with this again. Appreciate the info though. Cheers.
10-20-2019, 05:56 PM
#110
Did you cut the hole large enough for the clip to stick thru the hole?
Best Regards,
Saker
10-20-2019, 10:08 PM
#111
I presume this will fit without issue on a 19?
2019 SW TRDORP
10-20-2019, 10:56 PM
#112
Yes, I installed this mod on my 2019 TRD Off Road and it fit perfectly.
10-21-2019, 02:57 PM
#113
someone named john emailed me with a email from im guessing his wife linda email and for some reason its not letting me reply. so if you are looking for a handle im not trying to ignore you but your email address isn't working for me somehow when I hit reply.
pm me here and ill help ya out.
thanks,
-J
10-22-2019, 07:21 AM
#114
That was me. New to the forum. I sent payment via Paypal. Thanks,John
10-26-2019, 12:35 AM
#115
Are these still available?
Very interested!
10-30-2019, 12:11 PM
#116
I'm still curious if it will fit my '13. There is an SRS plug in the a-pillar, but the A-pillar part number is different from '14.
2013 Shoreline Blue Limited
10-30-2019, 12:50 PM
#117
Originally Posted by Jasontamu
hi all....thanks for all the interest and im glad everyone likes it.
like saker mentioned im out of town for work...ill return this weekend and next week ill be able to make more with my welder (i believe i only have one more in stock currently) so i can if all goes well have products shipped by Friday next week......just PM me and email is fine as well. Jasontamu2002@g mail.com
i see i have some PM's already so i appreciate that and can make some once im back home.
thanks,
-J
Hi J. Im
Interested too. Can you pls PM once you’re back and got a chance? Thank you
10-30-2019, 03:13 PM
#118
Originally Posted by ElectroBoy
Thanks, Jason for a sorely needed mod. I just installed mine today. It took me a good amount of time due to my paranoia about cutting into my A pillar cover. After many measurements and many test fittings I got it done.
I did make a few tweaks to your excellent instructions to satisfy my OCD.
It’s always good to protect your dash surfaces and A pillar cover with masking tape and put down a towel on the dash to avoid scratches while working with tools. I also taped all around the hole drill locations to create a “bucket” with the tape sticky side up in order to catch the metal shavings.
I found that the pointed blade end on the sheet metal screws wasn’t sharp enough to enlarge the initial 1/8 inch pilot hole. So I drilled progressively larger holes, up to 3/16 I believe, to get to the proper size for the sheet metal screws to take hold and tap a few turns for the threads. I then backed out the screw and cut off the blade ends with a dremel cutting disc. On my A pillar the screws seemed too long, there was some kind of plastic backing in there that would have been pierced with the screw blade ends.
I used blue loctite on the threads and snugged up the bracket to the pillar. With the cover installed I found that the white nylon base on the lower attachment point of the handle needed to be shaved down to make it fit flush with the surface of the cover.
It looks great and feels just as sturdy as the passenger-side handle.
Thanks to
@ Jasontamu
and
@ Saker
Hi. Good afternoon! Can you kindly tell me where did you buy the grip? Is it thesame as the right one? How much? I have 2013 4runner limited and planning to install this. Thank you and looking forward on your reply.
Emer
10-31-2019, 03:03 AM
#119
Email sent. Thanks!
2017 4Runner Limited, Magnetic Gray Metallic.
Mods:
N-FAB nerf bars, SR5 wheels with 275/70r17 Blizzak LM-V2, Interior LED swap, Salex glovebox and console organizers and Salex console tray.
Mods to be:
Anytime backup cam, front cam (maybe side cams), nav override, 2 channel dashcam with custom rear mount.
