Old 05-06-2019, 11:08 PM #1
krelnydelnky's Avatar
krelnydelnky krelnydelnky is offline
krelnydelnky will become famous soon enough
Rear Long Travel - Cantilever - 5th Gen
Has anyone looked at this setup for the 5th gen runner? anyone know specs and if it would fit?
FJ CANTILEVER Rear Suspension
BUILD THREAD - '16 Blizzard White T4R SR5[/URL]
http://www.toyota-4runner.org/5th-ge...sr5-build.html
krelnydelnky is offline   Reply With QuoteReply With Quote
Old 05-06-2019, 11:30 PM #2
mattgeeee's Avatar
mattgeeee mattgeeee is offline
mattgeeee is on a distinguished road
mattgeeee's Avatar
Subscribing to this...I've come across that same cantilever setup when I was looking for what to do with my rear and wondered the same.
2014 3.5+ LT 4Runner
mattgeeee is offline   Reply With QuoteReply With Quote
Old 05-06-2019, 11:37 PM #3
One of my buddies did a cantilever setup and it works mental. Im pretty sure he did this one, and wicked creations modified it a bit. Damn close to going full send into it.
Old 05-06-2019, 11:50 PM #4
mattgeeee's Avatar
mattgeeee's Avatar
Cantilever setups work great! You should definitely pull the trigger and do it so you can make me jealous, haha.
I always figured the fuel tank would be in the way but it looks like they kept it on the FJ. I wonder if you could get that FJ setup to work with the 4Runner...
It'd be awesome to have a rear that could keep up with the Camburg's front!
Old 05-06-2019, 11:53 PM #5
Please do it. Cantilever kits are incredible. other than shocks through the cab i don't think there's another way to do a true LT rear setup.
Old 05-07-2019, 01:00 AM #6
canadian bum canadian bum is offline
canadian bum will become famous soon enough
It should work. The back of the 4runner isn't any shorter than an FJ. Obviously if you had KDSS it would have to go. And may need to modify the weld in structure but that is easy. Would be a sweet set up for sure.
2016 ORP, OME 3" lift with 1/2" coil spacer, Modified Metal-Tech Bumper, 295/70R17 STT Pro, and a bunch of other stuff.
2005 Tacoma DCLB that is a bit ridiculous Build Thread
78 FJ45 and 79 BJ40 Land Cruiser never ending projects
IG @schultzy507
canadian bum is offline   Reply With QuoteReply With Quote
Old 05-07-2019, 01:08 AM #7
Thats what I think - my buddy had a 4th gen and it worked. sounded like a bit of modifying on the structure like you said, but damn, i think its doable. no KDSS so we're good there.
Old 05-07-2019, 01:12 AM #8
Yeah the hard part with pivot ratios and location is already done in this kit. A little bit of modification to get it up into place in the frame if needed is nothing. I'd say go for it if you're thinking about doing it.
IG @schultzy507
Old 05-08-2019, 09:29 PM #9
Copy, gonna send it. We will see how it goes!
Old 05-08-2019, 10:55 PM #10
The_Green_Wang's Avatar
The_Green_Wang The_Green_Wang is offline
The_Green_Wang is a jewel in the rough The_Green_Wang is a jewel in the rough The_Green_Wang is a jewel in the rough
There is a guy that has a 5gen that has cantilever, hes a famous guy lol let me see if I can find him, was on instagram
Sent from my SM-N950U using Tapatalk
The_Green_Wang is offline   Reply With QuoteReply With Quote
Old 05-08-2019, 11:53 PM #11
That would be sick!
Old 05-08-2019, 11:58 PM #12
Gonna send on all the beef tomoro. Fox all around, bypasses, bumps and coilovers. Fingers crossed its all gonna work!!
Old 05-09-2019, 09:39 AM #13
yassssssss
Old 05-09-2019, 10:19 AM #14
Aznwolf118 Aznwolf118 is offline
Aznwolf118 is on a distinguished road
Ohh this sounds like a write up and parts list numbers.
which shop is doing your instal?
2002 - trd s/c, header, exhaust, urd 7th...armored and expo set up
http://www.toyota-4runner.org/3rd-ge...ml#post2355344
1989 - 1UZ swap Cali Bar'd --SOLD--
http://www.toyota-4runner.org/classi...xperiment.html
Aznwolf118 is offline   Reply With QuoteReply With Quote
Old 05-11-2019, 10:07 PM #15
im buying the FJ kit from Wicked Fab - hopefully getting the order in on monday - theyve been busy. We will be doing the install! I will definitely take pictures and do a writeup!
5th , fit , gen , rear , runner
Long travel rear on the cheap wfo9 5th gen T4Rs 29 11-18-2020 04:09 PM
Rear long Travel twitchee2 3rd gen T4Rs 31 10-06-2016 06:22 PM
Rear Long Travel Tooltime19 4th Gen T4Rs 0 03-21-2016 06:05 AM
MetalTech long travel rear Qjake 5th gen T4Rs 55 03-24-2015 05:14 PM
