Old 06-11-2019, 12:40 AM #16
mattgeeee's Avatar
mattgeeee mattgeeee is offline
mattgeeee is on a distinguished road
mattgeeee's Avatar
Originally Posted by krelnydelnky View Post
im buying the FJ kit from Wicked Fab - hopefully getting the order in on monday - theyve been busy. We will be doing the install! I will definitely take pictures and do a writeup!
Any updates?
Did you get the pivots/frame in or anything?
Stoked to see how this will turn out!
2014 3.5+ LT 4Runner
mattgeeee is offline   Reply With QuoteReply With Quote
Old 06-20-2019, 02:33 PM #17
krelnydelnky's Avatar
krelnydelnky krelnydelnky is offline
krelnydelnky will become famous soon enough
Originally Posted by mattgeeee View Post
Any updates?
No updates - had a little setback - still going to do it though!! This summer for sure
BUILD THREAD - '16 Blizzard White T4R SR5[/URL]
http://www.toyota-4runner.org/5th-ge...sr5-build.html
krelnydelnky is offline   Reply With QuoteReply With Quote
Old 09-02-2020, 10:32 PM #18
JustinSmileySteele's Avatar
JustinSmileySteele JustinSmileySteele is offline
JustinSmileySteele is on a distinguished road
Ever get around to trying this out?
JustinSmileySteele is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 03:46 AM #19
mattgeeee's Avatar
mattgeeee's Avatar
If he hasn't, I'll post up some pictures when I get it all in 👍
I finally pulled the trigger and ordered the kit today!
Old 09-09-2020, 10:58 AM #20
WeedKillrr's Avatar
WeedKillrr WeedKillrr is offline
WeedKillrr is on a distinguished road
WeedKillrr's Avatar
WeedKillrr is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 11:26 AM #21
Inv4drZm's Avatar
Inv4drZm Inv4drZm is online now
Inv4drZm's Avatar
You can get the same amount of travel with a 14" short bodied King shock with a custom shock hoop. Not to mention probably easier to tune as it's a 1:1 movement ratio with the tire. That is, if you have the wheel spacing or axle width to fit the shock.
The cantilever kit looks like a lot of fabrication involved. Cutting off both panhard bar mounts and welding on custom ones. Just as much custom work as cutting into the body and reboxing it in to fit huge shocks or coilovers IMO.
Inv4drZm is online now   Reply With QuoteReply With Quote
Old 09-09-2020, 02:07 PM #22
WeedKillrr's Avatar
WeedKillrr's Avatar
Old 09-10-2020, 04:26 PM #23
mattgeeee's Avatar
mattgeeee's Avatar
You're correct, you can absolutely obtain the same travel with a longer shock through the cab, since that's what most other SUVs do.
Though it might be difficult to find a decent coil that's that tall. I think trying to fit a coilover/bypass setup would be tough.
I replaced my Tundra that had a full bed cage with the 4Runner so I could have more room on trips.
So punching through the cab and eliminating some of that space wasn't an option for me.
I currently have 3.0 2-tube bypasses in the rear, and had to run spacers to not rub the hoses/reservoirs. So with the cantilever kit it'll be nice to eliminate spacers and not worry about rubbing as well.
The amount of work required for either a longer shock or this cantilever kit is probably about the same.
Though I'll let you know once I actually install it, LOL
Old 09-11-2020, 10:14 PM #24
nimby's Avatar
nimby nimby is offline
nimby is a jewel in the rough nimby is a jewel in the rough nimby is a jewel in the rough
nimby's Avatar
Yeah, but cantilever.
nimby is offline   Reply With QuoteReply With Quote
Old 10-18-2020, 10:45 AM #25
nimby's Avatar
nimby's Avatar
Did you install this yet?
Old 10-18-2020, 08:53 PM #26
mattgeeee's Avatar
mattgeeee's Avatar
Received the kit and decided to have them do the install.
They currently have the 4Runner.
I should have it back in a few weeks here 👍
Old 02-11-2021, 09:42 AM #27
Florunner78 Florunner78 is offline
Florunner78 is on a distinguished road
Florunner78 is offline   Reply With QuoteReply With Quote
Old 02-28-2021, 10:02 PM #28
mattgeeee's Avatar
mattgeeee's Avatar
Originally Posted by Florunner78 View Post
I haven't been on here in awhile... haha my bad!
I'll make a better write-up later, but here's the majority of it...
Went down on a 3 day baja trip a few weeks ago and the thing was solid!
The rear feels WAY better than it did before. It's now keeping up with or out performing the front.
Still need to head up to Johnson Valley one of these days and have a dedicated tuning day.
Travel numbers where they sit currently: 13.5" driver 15.5-16" on the passenger's side...
When I first got the truck back the driver's side upper link was contacting the gas tank and limiting driver side travel at 11.5".
They made some bent upper links and moved the bumps up an inch and a half or so (they were still mounted using Chaos' bump kit). 33s are about as big as you can stuff in the rear now.
At full bump the rocker arms were contacting the cab as well. So I made some cutouts in the body and boxed them in (all under the carpeted area).
Also they had 500lb/in springs in the rear, I swapped those out to 600lb/in and it doesn't sag as bad in the rear with those.
There's currently a decent amount of binding when the rear droops out, so I'm tossing around the idea of 3 linking it (we'll see when I get to that).
At a minimum I'm going to see if I can make some plated upper arms that have more of a bend to them to even up the travel..
I'll likely make a new mount on the axle side for the pan hard to see if that helps with the binding (rotating the rod end 90deg so it's in the direction of travel)
Rear Long Travel - Cantilever - 5th Gen-20210113_200950_resized-jpg  Rear Long Travel - Cantilever - 5th Gen-20210113_200608_resized-jpg
Old 03-05-2021, 10:46 AM #29
So. Very. Sick.
Old 03-05-2021, 01:04 PM #30
Damn thats awesome.
5th , fit , gen , rear , runner
Long travel rear on the cheap wfo9 5th gen T4Rs 29 11-18-2020 04:09 PM
Rear long Travel twitchee2 3rd gen T4Rs 31 10-06-2016 06:22 PM
Rear Long Travel Tooltime19 4th Gen T4Rs 0 03-21-2016 06:05 AM
MetalTech long travel rear Qjake 5th gen T4Rs 55 03-24-2015 05:14 PM
