05-06-2019, 11:30 PM
Originally Posted by krelnydelnky
Subscribing to this...I've come across that same cantilever setup when I was looking for what to do with my rear and wondered the same.
2014 3.5+ LT 4Runner
05-06-2019, 11:37 PM
One of my buddies did a cantilever setup and it works mental. Im pretty sure he did this one, and wicked creations modified it a bit. Damn close to going full send into it.
BUILD THREAD - '16 Blizzard White T4R SR5[/URL]
http://www.toyota-4runner.org/5th-ge...sr5-build.html
05-06-2019, 11:50 PM
Cantilever setups work great! You should definitely pull the trigger and do it so you can make me jealous, haha.
I always figured the fuel tank would be in the way but it looks like they kept it on the FJ. I wonder if you could get that FJ setup to work with the 4Runner...
It'd be awesome to have a rear that could keep up with the Camburg's front!
05-06-2019, 11:53 PM
Please do it. Cantilever kits are incredible. other than shocks through the cab i don't think there's another way to do a true LT rear setup.
05-07-2019, 01:00 AM
It should work. The back of the 4runner isn't any shorter than an FJ. Obviously if you had KDSS it would have to go. And may need to modify the weld in structure but that is easy. Would be a sweet set up for sure.
2016 ORP, OME 3" lift with 1/2" coil spacer, Modified Metal-Tech Bumper, 295/70R17 STT Pro, and a bunch of other stuff.
2005 Tacoma DCLB that is a bit ridiculous Build Thread
78 FJ45 and 79 BJ40 Land Cruiser never ending projects
IG @schultzy507
05-07-2019, 01:08 AM
Thats what I think - my buddy had a 4th gen and it worked. sounded like a bit of modifying on the structure like you said, but damn, i think its doable. no KDSS so we're good there.
05-07-2019, 01:12 AM
Yeah the hard part with pivot ratios and location is already done in this kit. A little bit of modification to get it up into place in the frame if needed is nothing. I'd say go for it if you're thinking about doing it.
IG @schultzy507
05-08-2019, 10:55 PM
There is a guy that has a 5gen that has cantilever, hes a famous guy lol let me see if I can find him, was on instagram
Sent from my SM-N950U using Tapatalk
05-08-2019, 11:53 PM
That would be sick!
05-08-2019, 11:58 PM
Gonna send on all the beef tomoro. Fox all around, bypasses, bumps and coilovers. Fingers crossed its all gonna work!!
05-09-2019, 09:39 AM
yassssssss
05-11-2019, 10:07 PM
Originally Posted by Aznwolf118
Ohh this sounds like a write up and parts list numbers.
which shop is doing your instal?
im buying the FJ kit from Wicked Fab - hopefully getting the order in on monday - theyve been busy. We will be doing the install! I will definitely take pictures and do a writeup!
