Old 05-28-2019, 11:18 AM #1
WEAK_E90 WEAK_E90 is offline
WEAK_E90 will become famous soon enough WEAK_E90 will become famous soon enough
RCI Skid Plate Questions For Current Users
Looking at getting rid of my TRD skid plate for something different. I got the TRD with the vehicle. Neighbor wants to buy mine for a pretty good price figure I can change things up.
For people who have Icon front suspension - with the radiator support spacers (to avoid having your sway bar make contact with the bracing) will the RCI skid plate still work with this? (my guess is yes but double checking).
For any existing RCI skid plate owner: Would you recommend steel or aluminum? The chance of the skid plate actually seeing an object is slim to none. I sold my stock one and will need something to cover it. Thoughts?
Thanks in advance!
Jealousy is ugly... Don't be ugly.
Tirdy5's w/ -70 F5's
WEAK_E90 is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 11:30 AM #2
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
i'm happy i went with aluminum, it's been abused offroad enough that it has a few gouges but it does the job and is really lightweight. i would only ever change to steel if i ever started hardcore crawling (in which case i'd just get a vehicle better suited to that)
jhguth is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 11:34 AM #3
anyone know if these work with the 1" differential drops too?
another thing down there thats changed wanna make sure works before i drop the coin...
Old 05-28-2019, 12:37 PM #4
coversion's Avatar
coversion coversion is offline
Real Name: Tim
coversion is on a distinguished road
coversion's Avatar
Real Name: Tim
I'll echo the sentiment on the aluminum skids.
I have scraped over numerous rocks, as well as hung/dragged across my RCI aluminum skids many times. You will see the gouges/scratch marks, but absolutely no sign of them being inadequate or compromised.
With everything else I've done attempting to get into single-digit MPG, I am more than pleased with the aluminum skids.
coversion is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 12:43 PM #5
coversion's Avatar
Real Name: Tim
coversion's Avatar
Real Name: Tim
I can't speak to the Icon setup, but they work fine with the Toytec diff drop installed.
Old 05-28-2019, 01:43 PM #6
Kenstaroni's Avatar
Kenstaroni Kenstaroni is offline
Kenstaroni is on a distinguished road
Kenstaroni's Avatar
I have RCI skids with the icon sway bar relocation brackets. No issues with the skids at all. Still had to trim my radiator bracket support to keep it from rubbing but has nothing to do with the skid.
I have RCI's full skid package front, mid, transfer, and fuel. Happy with all of them.
The TRD pro skids only suck if you have one that doesn't have an oil change access hole...then I can understand the swap. Otherwise I don't see the big attraction to swap skids. Most aftermarket one's are compatible with the TRD pro front skid (or offered as an option). Doesn't sound like you use yours right now so I'd get aluminum I guess if you're set on doing it.
Kenstaroni is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 01:55 PM #7
87pony 87pony is offline
87pony will become famous soon enough
if its never going to see significant offroad, not sure why you got rid of your factory. a friend of my destroyed his aluminum in moab and decided steel was next. I personally went steel cuz I'm off in the colorado "rockies" often.
87pony is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 02:00 PM #8
bingo - the door would be nice for oil changes - as anxiety is kicking in of stripping the bolts. If someone pays me good money for my TRD plate id do it.
Old 05-28-2019, 02:42 PM #9
BigredTEX's Avatar
BigredTEX BigredTEX is offline
Real Name: Rick
BigredTEX is on a distinguished road
BigredTEX's Avatar
Real Name: Rick
I've got the steel and my son had the aluminum until it cracked is two places. He placed it with steel, warrantied by RCI (they gave him the choice of wither). Should be no clearance issues with either the sway bar relocation or diff drop.
If you have no plans for anything really challenging off-road, the aluminum should be fine. If you really plan on hitting some rocks, I'd go steel.
2012 Trail Edition, Salsa Red, MetalTech (Icon) Long Travel Rear, Panhard Relocation Bracket, Radflo 2.5" Extended Travel Front, LR UCA's, 17x9 XD wheels, Cooper S/T Maxx 285/75-17's (34"), 4.56 Gears, Wet Okoles, Weather Tech FLoor Covers, Canvasback Cargo Covers, Shrockworks Sliders, BudBuilt Hidden Winch w/ Warn 9.5ti, On-Board Air (using sliders as air tanks), Rigid D2's, RCI Skids, Body Mount Chop, Console Vault.
BigredTEX is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 07:32 PM #10
bigair96 bigair96 is offline
bigair96 will become famous soon enough
Cracked from use or another reason? I had no idea they would warranty armor. I have full rci aluminum, wanted to save weight and dont plan on bashing them often.
2018 sr5P XP Predator. Needed that 3rd row. TRD Pro susp, Toytec trd pro 2inch lift (HD springs), Gobi stealth, Falken at3w 285s, Trd and rci alum skids, Arb breather, Upper grill light source lightbar, slee sliders, wilco high clearance, arb awning, pedal commander, treaty offroad recovery points, alpha rex pro headlights, trd intake/exhaust, goal zero solar setup, greenlane offroad bumper, warn winch. C4 rear bumper coming...
bigair96 is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 08:29 PM #11
War Eagle's Avatar
War Eagle War Eagle is offline
Real Name: Mark P
War Eagle will become famous soon enough
War Eagle's Avatar
Real Name: Mark P
Buy steel if you want more protection than stock. Dont forget fuel tank too. ;)
Silver 2018 4Runner ORP w/ KDSS|Bilstein TRD FJC TTU & HD suspension|275 BFG KO2s|RSG sliders|RCI steel full skid set|Warn hybrid bumper|X20 winch w/ Southeast Overland Rope|DD Sport fogs & rear floods|22” X6 LED bar|Orange Boxx panels|Rhino-Rack Pioneer|Proline elite rear w/ dual swingouts & FrontRunner Table.
War Eagle is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 09:20 PM #12
bmrisko bmrisko is offline
bmrisko is on a distinguished road
Which skid and how did it crack?
bmrisko is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 10:29 AM #13
i'm curious where the crack was to keep an eye out, mine get abused pretty good
Old 05-30-2019, 09:50 AM #14
BigredTEX's Avatar
Real Name: Rick
BigredTEX's Avatar
Real Name: Rick
It was the front skid. It cracked on both sides at the transition as it curves from slanted in the front to flat along the bottom. He took photos and sent them to RCI. They warrantied it from the photos and didn't want it back so it went into the recycling bin.
Old 05-30-2019, 11:51 AM #15
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light
official vendor
No clearance issues with my RCI skids at all
RCI Skid Plate Questions For Current Users-rci-jpg
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
owner , plate , rci , skid , trd
Questions about TRD skid plate wbstru 5th gen T4Rs 1 12-12-2017 11:17 AM
2010 - current shock works 5 skid plate set. IRON433 For Sale: T4R Items 5 12-20-2016 11:15 PM
Skid plate questions...... 99Yotarunner 3rd gen T4Rs 4 12-04-2012 12:30 AM
BudBuilt Skid plate questions rrflyer 4th Gen T4Rs 1 01-24-2012 03:13 AM
Bud Built Skid Plate Questions Ghost Runner 5th gen T4Rs 2 03-22-2011 08:11 PM
