Old 01-11-2020, 07:17 AM #16
MikeyMTBs MikeyMTBs is offline
MikeyMTBs is on a distinguished road
The Morimotos fit like shit on my 19 TRD. I had to trim the tabs significantly to get them to fit and then oval out the holes to line up the screws. I’m not all happy with the gap left either.
I looked at the brackets and wondered if they could be swapped. Good to know that can be done and I’m willing to take the whole bumper back off to swap out the brackets.
MikeyMTBs is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 01:39 PM #17
TheRetroFitSource Morimoto LED projector fog lights
Just to update my post above, I ended up pulling the Morimoto fogs back out so that I could swap the OeM fog light brackets onto the Morimoto fogs. I spent more time altering the XB bracket to fit than it did to swap the lights into the OeM bracket. Everything went right back together, the shitty spacing is gone and they fit perfectly in the housing.
Lesson learned. Don’t modify the Morimoto XB brackets, just swap them from your existing OeM fogs.
Old 01-11-2020, 03:45 PM #18
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
I don't understand all the issues with install. I had these on my 19 and yes the tabs are a bit different but they still fit in the slot with not alot of effort.
ForRun is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 06:26 PM #19
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Originally Posted by ForRun View Post
I don't understand all the issues with install. I had these on my 19 and yes the tabs are a bit different but they still fit in the slot with not slot of effort.
Same, mine went in no problem and have been great for over 2 years
Old 01-12-2020, 11:56 AM #20
17KT4R 17KT4R is offline
17KT4R will become famous soon enough
I went on EBay & picked up a set of these :: Toyota PT413-42191 Fog Light (Black)
Seem to be genuine OEM, came from a dealer. Fit like a glove and the LED beam pattern appears awesome to me. No adjustments required. Was able to do them easily from underneath. Hope this helps...
2017 TRD OR / KDSS / Canuckistan Edition
17KT4R is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 12:51 PM #21
Phade Phade is offline
Phade is on a distinguished road
When you say underneath - do you mean from inside the wheel wells behind the lingers, or literally from underneath?
I have these and ready to install myself and was hoping to squeeze them in today without spending a ton of time (out of fuel for the garage salamander...lol).
Phade is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 01:15 PM #22
ForRun's Avatar
ForRun's Avatar
Driver's side is wide open from underneath. Passenger side, take the 2 maybe 3 10mm bolts off the bottom side of the bumper, takes seconds and it opens up (from under the rig) the wheel well with plenty of room.
Old 01-12-2020, 03:55 PM #23
papadop88 papadop88 is offline
papadop88 is a jewel in the rough papadop88 is a jewel in the rough papadop88 is a jewel in the rough
Glad to hear man. How hard was it to swap the brackets?
papadop88 is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 08:30 PM #24
Yes, lying on my back on the driveway. Never thought of undoing those 10mm bolts as ForRun mentioned for the passenger side... I was able to easily feel my way up there however to undo the mounts and plop the new one in blindly, and finger tighten things before tightening properly. That plastic cover on that side is most of the pain.
Old 01-17-2020, 08:51 PM #25
It was quicker than getting the dremel out and butchering the Morimoto bracket to try to get them to fit.
1. From the OEM fogs, unscrew the adjustment screw, look inside the housing and pinch the tabs to let the screw fully back out. I used a small pair of needle nose pliers to pinch the tabs on the screw.
2. Lift the OEM bracket at the pivot point on each side and it will pop off.
3. On the Morimoto brackets, remove the adjustment screw and spring.
4. Remove the brackets at the pivot on each side.
5. Pop onto the OEM bracket onto the Morimoto pivots in the same orientation.
6. Screw in the white plastic adjustment screw from the OeM bracket.
7. Reinstall with no modification and enjoy having perfect fit with no gaps fog lights.
Old 01-18-2020, 02:37 AM #26
Wow, easier than I expected. Thanks man! How easy was it to adjust them afterwards?
Old 01-18-2020, 07:18 AM #27
Before I removed the OEM fogs, I marked the cutoff line on the wall in my garage. For adjustment of the Morimoto fogs, I reinstalled the bumper but didn’t attach the fender liner. It’s easy enough to lay under the front of the vehicle, flex the fender liner back a bit and reach up with a Phillips head to adjust. The big OEM adjustment screw makes it super easy. That took no time at all.
I adjusted the passenger side slightly higher than the driver’s. Buttoned it back up and it’s been perfect.
I was pissed with the fitment of the Morimoto fogs before swapping the brackets. I had ground the brackets down to nubs with my dremel and they still didn’t fit for shit. The screw side of the bracket has to be enlarged to fit.... it’s just not acceptable.
The fit with the OEM brackets makes these fogs really standout.
Old 01-22-2020, 11:54 AM #28
gsteitz gsteitz is offline
gsteitz is on a distinguished road
I'm having a very difficult time removing the leveling screw form the OEM set up to transfer the bracket. I read your reference to using pliers, but I'm not sure I understand how that should be working. Any clarification would be much appreciated.
Stock Morimoto bracket fitment is terrible!
gsteitz is offline   Reply With QuoteReply With Quote
cheers , easy , install , light , theretrofitsource
Morimoto LED projector headlights Johnnyek9 5th gen T4Rs 51 05-19-2020 01:01 PM
03 with 06 OEM projector and Morimoto 2stroke 2.0 LEDs raamaudio 4th Gen T4Rs 2 12-25-2018 03:43 PM
Morimoto D2S 4.0 Projector Retrofit jlstick2 3rd gen T4Rs 3 05-25-2018 12:01 PM
FS: New Morimoto Projector kit. $250 Shipped rolling7high For Sale: T4R Items 1 10-25-2016 06:45 PM
Morimoto Mini D2S Projector Install emmwhat 4th Gen T4Rs 25 07-26-2013 09:45 AM
