Originally Posted by CF_Machete
There are probably a million threads on this, but don't drill your roof, you're just inviting water damage. You have a channel on either side of your windshield that you can run wires up and through as well as the grommets under the rear hatch. Way more Access ports than you will need without Drilling.
You realize that blocking that channel on the windshield also impedes water flow and could lead to a leak somewhere, right? If it’s done right, passing wires through the roof does not invite water damage. I work on fire apparatus as a career and not a single one of our rigs has water issues from running A LOT of heavy gauge wiring through the roof (emergency lighting, heavy duty scene lights and radio antennas). Neither do our patrol cars or public works units. All of these see extreme weather more than anyone’s rig on this forum, I’m willing to bet.
Can you do the windshield drain channel? Sure. Does it look bad? Subjective but I think it’s the easy way out and can look tacky on an otherwise clean rig.
At the end of the day, done right, both are probably okay. It if was my rig, I’d stare at the damn wires running down my windshield all the time. My ocd would get the best of me.
