Old 11-01-2019, 12:14 PM #16
ryanbt's Avatar
ryanbt ryanbt is offline
ryanbt is on a distinguished road
ryanbt's Avatar
I noticed the rear one in the passenger front wheel well, but just found the front one and a clip had pulled out. I'm going to wash it now, then try the double sided tape! I will report back!
CURRENT: '14 Limited Mag Gray, '17 Limited Mag Gray, '19 Mercedes GLC300, '08 Urban Runner | SOLD: '96 4runner SR5, '08 Urban Runner, '14 Limited Blizzard Pearl
ryanbt is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 02:26 PM #17
ryanbt's Avatar
ryanbt's Avatar
So far so good! It was that one little clip that had popped out. I put it back in and shoved in some double sided tape. You guys are awesome! Amazing how a stupid little clip can make so much NOISE.
Old 11-01-2019, 02:36 PM #18
Moving Chicane's Avatar
Moving Chicane Moving Chicane is offline
Moving Chicane is on a distinguished road
Any thoughts on if the "rubber hanging guards" are even necessary in that spot? I'd like to just remove it all together....
Already Gone.
Moving Chicane is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 02:40 PM #19
ryanbt's Avatar
ryanbt's Avatar
I was thinking the same thing. I might rip them right out next!
Old 06-12-2020, 10:09 PM #20
Okusputokus's Avatar
Okusputokus Okusputokus is offline
Okusputokus will become famous soon enough
I've been chasing some metallic rattles for a while. I'm thinking it's lateral play in my axles. Everything else has been replaced and it's still there, except my front axles, which seem fine, but I noticed today that I can laterally move them 1/4 inch or so using my hand. Just the axle shaft moves not the end joints. Anyway else try this? Please do and report back.! Wondering if it's normal or if my axles are worn. I use my rig mostly for trails so once i air down there is A LOT lateral movement and it drives me nuts!
Cheers
2014 T4R Trail👉*LOTS of MODS
Okusputokus is offline   Reply With QuoteReply With Quote
Old 06-14-2020, 10:27 PM #21
mrt6644 mrt6644 is offline
mrt6644 is on a distinguished road
Originally Posted by FourRunner08 View Post
Hello!
I have a 2019 TRD Off Road 4Runner with 750 miles on it. I have a clunk/rattle in the front end when going over sharp speed bumps, and ruts in the road (such as breaks in pavement, or going on/off of a bridge).
I have two recordings... One of my suspension HERE ( YouTube )
I have one of the outside, too HERE ( YouTube )
I have tried the following things:
Removed Front AND Transmission skidplates
Removed the mudflap in the wheel well
Removed the plastic wheel hubs on the TRD Off Road wheels
Checked the clips on the upper control arms and sealed them in place
They also torqued all suspension components to factory specs
They "insulated" my skid plate which was useless since I told them it happens without skid plate on it... HEH
Thanks
LOVE my 4Runner, HATE that it rattles already!
I have a new 2020 TRD Off Road Prem and every once in a while I notice a thin metal rattle. I only notice it when the window is open and Im idling or moving slowly. I dont know how often it is as I hardly ever have the window open in this humid heat. Usually when I'm in a drive through.
On my 2015 Trail I had that clunk issue that was never resolved. The dealers could never find it.
2020 4Runner TRD OffRoad Premium
2017 BMW R1200GS Rallye
mrt6644 is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 03:56 PM #22
fsaral77 fsaral77 is offline
fsaral77 is on a distinguished road
I think I have loose LCA bolts after an alignment. How can I torque these down without messing up my alignment?
2018 TRD Off-Road Premium - 5th Gen
fsaral77 is offline   Reply With QuoteReply With Quote
Old 08-12-2021, 04:38 PM #23
thekoopakid22 thekoopakid22 is offline
thekoopakid22 is on a distinguished road
I was experiencing a rattle as well and went searching for answers and stumbled upon this thread. After watching your videos it sounded exactly the same as mine. Only happens when going over bumps and windows have to be down to hear it. Though it was something with suspension for a while because it was only happening over bumps. I have a 2015 TRD Pro and just took it in for its 90k service. I was able to locate the source of the rattle for me. It was the "COVER ASSEMBLY, ENGINE UNDER, REAR". One of the bolts wasn't tightened down enough and was causing a rattle. .
[IMG]https://i.imgur.com/Btpb2Rw.jpg[/IMG
I realize this is an old thread but this may help someone else out!
thekoopakid22 is offline   Reply With QuoteReply With Quote
Old 08-16-2021, 12:59 PM #24
Happy you found your clunk! I have aftermarket skids and have checked those many many times. I removed my front sway which has helped but when wheeling I do continue to hear the clunk. It may be in the rear! The front sway, in theory, is stiffening the rig enough to make the clunk more frequent with lateral movement(over rocks, off-camber, etc), so again removing it reduces the clunks but IT'S STILL THERE! Someday I'll find it lol.
Old 08-16-2021, 02:20 PM #25
jgb21_98 jgb21_98 is offline
jgb21_98 is on a distinguished road
getting mine in a couple weeks, hope no ratttles either!
jgb21_98 is offline   Reply With QuoteReply With Quote
Old 08-30-2021, 10:09 PM #26
BorotHex BorotHex is offline
BorotHex has a spectacular aura about BorotHex has a spectacular aura about
4Runner Rattle Noise
I have so many annoying rattles in my 2021 that I’m probably going to get rid of it. I’ve had 24 cars in my life. This is my first ever Toyota, and probably my last. I’ve spent at least an hour every day for 3 weeks trying every trick I know and I’m getting nowhere. I’m starting to hate the car.
Good luck to those fighting with this, but I have to say I have never been so stumped and I have always been able to fix any rattles myself. Not on this one. They just seem to be unfolding right and left. Pisses me off.
Edit - If you have a popping sound at the passenger a-pillar, believe it or not the fitment is so bad that it is actually bound on my car. I used an interior trim tool to shove a microfiber towel in between and for now that popping beast from hell is tamed. A 1985 Ford Escort had engineering sufficient to not have the dash popping on the a-pillar. Disappointed because these are engineering issues, not assembly. It’s just not designed to minimize NVH and I have to say it’s shocking to me. I always thought Toyota’s were boring, but all this stuff was perfect. Not true.
I have not even started on the moonroof. I have rattles while it’s closed, different rattles when it’s fully opened, and a horrifying metal on metal binding tear/pop sound when it’s tilted. I love moon roofs so this is very annoying.
BorotHex is offline   Reply With QuoteReply With Quote
Old 10-06-2021, 12:29 AM #27
ChrisMo757 ChrisMo757 is offline
Real Name: Chris
ChrisMo757 is on a distinguished road
Real Name: Chris
My 2019 TRD OR Prem had several annoying rattles that really made me question the build quality of "newer" Toyotas. One was coming from the moonroof which turned out to be one of the little covers that expand on each side to hide the mechanical lifts. Also, one from the passenger side dash top speaker which required me to loosen the bolts that hold the speaker in place. I had one coming from the driver side striker plate which made the door creak/rattle. The fix was to barely loosen the bolt on the top and putting a piece of felt then tightening it back up. I also noticed a squeak coming from the non- KDSS front suspension on a mild off road trail. I sold it before I could get around to dealing with that one. Honestly my 4th Gen's feel better put together than the 5th gen.
Florida
Current 4R: 2009 Urban Runner 4WD
Previous 4Rs: 98 SR5 4WD, 02 Sport Edition 4WD, 06 Limited V8 AWD, 07 Sport Edition 4WD, 19 TRD Off Road Prem 4WD
ChrisMo757 is offline   Reply With QuoteReply With Quote
Old 12-02-2021, 12:19 AM #28
I have been fighting rattles for months. Dealer replaced the sunroof rail and all kids of stuff. Took two days. The loud structural popping when tilted seems fixed, but now there is a much more constant rattle they created.
They did find the dash buzzing/rattling that I had complained about and taken it in 3 times was a wire harness going through the firewall rattling.
But I got the truck back, hitting bumps and listening to all the rattles, and decided I can’t do it anymore. Drove straight to Honda and picking up a Ridgeline tomorrow. I don’t need a truck anymore anyway since I’m moving.
The dealer shuttle is a Sienna and I was shocked at the sliding doors knocking and popping. My loaner past two days was a Yaris and it rattled even far worse than my 4Runner. Having owned many, many new cars, 24 now in total, I can say that by far the worst interior quality is Toyota. No other maker comes close, and I even owned a 2019 Chevy Trailboss and multiple F150s and Mustangs. Closest is Honda, but that’s always been 1-2 rattles I easily fixed. These Toyotas have very serious interior problems. I don’t understand what is going on at Toyota. My mom had a 1993 Camry that never once rattled or popped, ever. I guess Toyota gave up.
First Toyota. Last Toyota.
Old 12-02-2021, 09:03 AM #29
Relentlesskaizen Relentlesskaizen is offline
Relentlesskaizen is on a distinguished road
Must be yours. Mine had one rattle that has since went away. I will take some rattles in stride knowing I bought a car to last. Either way I hope your Honda serves you well, I had a couple high mileage ones in my early 20’s and they took me everywhere with out trouble.
Relentlesskaizen is offline   Reply With QuoteReply With Quote
Old 12-02-2021, 01:41 PM #30
4runrr 4runrr is offline
4runrr is on a distinguished road
Hello!
Thanks
Did I see on your youtube comments that the rattle was from your brake pads?
4runrr is offline   Reply With QuoteReply With Quote
4runner , removed , road , skid , suspension
Another sunroof rattle noise Trendari 4th Gen T4Rs 11 05-11-2021 02:10 PM
Rattle noise! dwb 874runner Classic T4Rs 4 02-07-2013 10:55 AM
2010 4Runner SR5 Rattle Noise When in Gear.... Is it normal? newbie5thgen 5th gen T4Rs 10 04-10-2012 07:01 PM
5th Gen Rattle Noise newbie5thgen Problems & Warranty Issues 11 04-11-2011 10:38 PM
Weird noise (rattle like) hulk311 Problems & Warranty Issues 1 02-04-2010 01:34 PM
