Old 05-11-2019, 02:44 PM #1
FourRunner08 FourRunner08 is offline
FourRunner08 is on a distinguished road
4Runner Rattle Noise
Hello!
I have a 2019 TRD Off Road 4Runner with 750 miles on it. I have a clunk/rattle in the front end when going over sharp speed bumps, and ruts in the road (such as breaks in pavement, or going on/off of a bridge).
I have two recordings... One of my suspension HERE ( YouTube )
I have one of the outside, too HERE ( YouTube )
I have tried the following things:
Removed Front AND Transmission skidplates
Removed the mudflap in the wheel well
Removed the plastic wheel hubs on the TRD Off Road wheels
Checked the clips on the upper control arms and sealed them in place
They also torqued all suspension components to factory specs
They "insulated" my skid plate which was useless since I told them it happens without skid plate on it... HEH
Thanks
LOVE my 4Runner, HATE that it rattles already!
FourRunner08 is offline   Reply With QuoteReply With Quote
Old 05-11-2019, 03:15 PM #2
TOYO74's Avatar
TOYO74 TOYO74 is offline
TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about
TOYO74's Avatar
Sounds like a thin metal rattle to me.
Have the you checked the thin metal heat shields around the catalytic converter and around the exhaust pipes in the engine bay?
May be some others in that area but those are the ones I can think of that are close enough to front to be heard if they are rattling.
I also hate rattles! Good luck!
TOYO74 is offline   Reply With QuoteReply With Quote
Old 05-11-2019, 04:06 PM #3
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
I have gravel on top of my gas tank skid plate. Kinda sounds like that.
You could check your hood latch too. Thereís rubber adjusters on either side that you can turn by hand. Itís one of those things that sounds like itís coming from elsewhere
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 05-11-2019, 10:27 PM #4
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Well I had a rattle I couldn't figure out until someone on here posted a thread about it. Not sure if your rattle is it, hard to tell from the video, but there is a thin piece of dark grey fabric (I think it is a splash guard) in the driver wheel well that has the letters AE cut out on the bottom of it that is attached with 4 plastic pins. The very top one by my UCA was the culprit. As a quick check I just sprayed some WD40 on it. Stopped the squeak immediately. Permanent fix is to find some two sided foam tape and put it between the metal and the piece of fabric and then run the pin through it to secure it so it won't move. Never would have figured it out had it not been for a topic on this forum.
I just re-checked your post and you said mud-flaps in your wheel well so that may be the same thing I am talking about. I thought you might have mean the mud-flaps that prevents mud from slinging up on the side of the truck.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 06-15-2019, 12:49 AM #5
Georgiey22 Georgiey22 is offline
Georgiey22 is on a distinguished road
Have the same squeak and itís getting under my skin. I thought it was maybe my rear driver side shock. Any luck?
Originally Posted by FourRunner08 View Post
Hello!
Thanks
2016 T4R SR5 Premium + Bilstein 6112 Coilovers front + Bilstein 5100 Rear + TRD 17" rims + 265/70R17 Nitto AT Grappler G2's + Tinted Windows + OEM Running Boards + Rigid Industries D2 Driving Lights in OEM Fog Light location
Georgiey22 is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 01:22 AM #6
Jarheadoo7's Avatar
Jarheadoo7 Jarheadoo7 is offline
Jarheadoo7 will become famous soon enough
Jarheadoo7's Avatar
Common rattles not mentioned yet are the LCA alignment bolt not torqued to 130FtLbs. It may be close and close causes rattles. Also sway bar mounts not torqued. might be worth a check.
Jarheadoo7 is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 10:24 AM #7
nb rob's Avatar
nb rob's Avatar
Hey Georgiey,
I had a mystery squeak and occasional rattle from the rear. I had a friend jump up and down on the trailer hitch while I crawled underneath. It turns out that it was the lower mount of the driver side rear shock. There was a tiny bit of slop. Basically the misalignment spacers were just a whisker narrower than the post that they mount to. When the bolt was torqued tight, the misalignment spacer could still wiggle around and make noise.
I found a 1/32 spacer washer at Home Depot of all places (after looking everywhere) that solved the problem completely for $0.75. It goes on the post, and then the shock, and then the retaining bolt. Itís worth checking out if thatís where your noise is coming from.
Old 06-15-2019, 10:50 AM #8
blanchard7684 blanchard7684 is offline
blanchard7684 is on a distinguished road
that sounds a lot like typical ball joint or suspension rattle.
Given what has been done so far, I'd be looking for something loose.
I know the skid plate has been covered, I would check the other skid plates first.
then check under hood for things loose. brackets, hood latch, wire harnesses, even the engine and "radiator" cover.
I watched the videos again...I wonder if one of the shocks is making that noise internally...
blanchard7684 is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 01:52 PM #9
Originally Posted by nb rob View Post
Hey Georgiey,
Thanks pal. I thought I found the issue because my Kings were making my skid rub the radiator brackets. Replaced the TRD skid plate with the OEM and added a new spacer. No more rub but the squeak is still present and is definitely coming from the rear. I need to remove the rear Kings and find my problem.
Old 06-15-2019, 06:16 PM #10
Salvo Jimmy's Avatar
Salvo Jimmy Salvo Jimmy is offline
Real Name: Ted A Hamilton
Salvo Jimmy will become famous soon enough Salvo Jimmy will become famous soon enough
Couldnít resist
4Runner Rattle Noise-ab14616e-102f-419a-a551-31bf891c483f-jpeg
Ted A. Hamilton
(aka Salvo Jimmy)
Salvo NC / Hampton VA
2016 SR5 4WD 3rd Row Seat
Only MOD. Curt 31367 front hitch receiver.
Salvo Jimmy is offline   Reply With QuoteReply With Quote
Old 06-19-2019, 06:38 AM #11
any news on this?
Old 11-01-2019, 10:59 AM #12
ryanbt's Avatar
ryanbt ryanbt is offline
ryanbt is on a distinguished road
ryanbt's Avatar
I have the EXACT same rattle that just started in my 2014 Limited with 60K miles and it's driving me absolutely crazy. I've tried most of the suggestions in this post and it won't go away. So far the only way I've 'fixed' it is to crank up the stereo. lol. Did this ever get resolved by anyone?
CURRENT: '14 Limited Mag Gray, '17 Limited Mag Gray, '19 Mercedes GLC300, '08 Urban Runner | SOLD: '96 4runner SR5, '08 Urban Runner, '14 Limited Blizzard Pearl
ryanbt is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 11:25 AM #13
Spungus's Avatar
Spungus Spungus is offline
Real Name: Eric N.
Spungus is on a distinguished road
Spungus's Avatar
Real Name: Eric N.
Do you feel it in the steering column or is it just the noise that you hear?
'17 TRD Pro. TRD intake, Borla Touring Exhaust, Toytec Aluma 2.5, Superflex 2.0 rear coils, total chaos UCAs and LCA's, RCI sliders and underbody armor
Spungus is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 11:44 AM #14
ryanbt's Avatar
ryanbt's Avatar
It's just the noise that I hear. I don't feel anything at all, which makes me believe it's annoyance and not something serious. It's coming from the front passenger wheel area. My Dad is going to drive it later on and I'm going to sit in the passenger seat and see if I can isolate it any further. The noise is exactly like the OP's video taken from the suspension. Noise started randomly a week ago and then quit for several days, and now it's back. So it could be temperature related, too since both times it's been doing it the temps were in the 30įFs. I've wiggled all of the heat shields and found one that was loose and fixed that, but I still have the rattle.
Old 11-01-2019, 12:10 PM #15
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
I had the most annoying squeaking coming from drivers side front somewhere, it got to the point where I was considering trading in the 4runner for a newer one then I came across this post:
https://www.toyota-4runner.org/2825358-post23.html
Turns out that was exactly what mine was, the little plastic piece rattled so much it took the paint off the metal behind it. I used double sided tape, and better clips and it went away.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
4runner , removed , road , skid , suspension
Another sunroof rattle noise Trendari 4th Gen T4Rs 11 05-11-2021 02:10 PM
Rattle noise! dwb 874runner Classic T4Rs 4 02-07-2013 10:55 AM
2010 4Runner SR5 Rattle Noise When in Gear.... Is it normal? newbie5thgen 5th gen T4Rs 10 04-10-2012 07:01 PM
5th Gen Rattle Noise newbie5thgen Problems & Warranty Issues 11 04-11-2011 10:38 PM
Weird noise (rattle like) hulk311 Problems & Warranty Issues 1 02-04-2010 01:34 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
