Originally Posted by Jivewalker
Use a bottle jack under the kdss piston to manipulate it up and down. Fasten one side at a time, use a drift pin through the holes at top of bracket. Don't cross thread bolts, it's easy. GL
^This
I have undone/done my KDSS sway bars a bunch of times. Really similar to above.
Floor jack under the piston (or whatever you have)
Only undo one side at a time
I use a ratchet strap in the hole in the frame cab-side over top of the LCA to the sway
Thread the bottom bolt first.
2013 TE w/ KDSS Nav
=-> Get yer
Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just
want to go "Pro"
