Old 05-12-2019, 01:13 PM #1
WEAK_E90 WEAK_E90 is offline
WEAK_E90 will become famous soon enough WEAK_E90 will become famous soon enough
Post Suspension install question
So I installed icons front and rear on my car yesterday. I currently had spc uca and 5100 toytec lift. We swapped out suspension following the instructions along with install new ball joints on the UCAs. Took longer than expected so postponed the alignment (didn’t tweak anything to try to “get it close” just put everything back on to get me home.
Before driving home we measured in the parking lot and fronts were at 23.5... ok! Drove home and measured in the street... 25” ok my cv axles look whack so I’m not leaving it like this... got in and turned my wheels back and forth and the car settled back to 23.5... so I’m good? Went around the block came back- back around 24.5... turn wheels again and back to 23.5...
Is the issue is my wheels are not aligned is what’s causing this issue?
I did take my wheel spacers off the wheels too during all of this... don’t think that would matter...
The other thing I notice is when making a unturn after a certain point my steering wheel will Just “fall” like it continues the turn for me... didn’t feel like this before..
Hoping to get the alignment done early next week.
Thoughts?
Jealousy is ugly... Don't be ugly.
Tirdy5's w/ -70 F5's
WEAK_E90 is offline   Reply With QuoteReply With Quote
Old 05-12-2019, 03:17 PM #2
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
Get it aligned and make sure everything is right and torqued to spec.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 05-12-2019, 03:33 PM #3
4runnin4mylife's Avatar
4runnin4mylife 4runnin4mylife is offline
4runnin4mylife has a spectacular aura about 4runnin4mylife has a spectacular aura about
Thoughts?
With the steering wheel issue I would definitely say get it aligned first and then see how it acts? Since you gotta do that anyway... that's the easy answer. I can't give you any advice on what exactly it might be, but I will say that after i installed my icon stage 2 lift there was quite a bit of discrepancy in measurements depending on where I was parked. And it was my first adjustable coilovers so I measured a lot. For example, parked at work front left would measure 23.5, then in my drive way the front left would be 24.5. Then maybe 23" if one of my wheels happened to be on a separate slab of concrete than my other wheels. Just different scenarios caused quite the different readings. Once my suspension settled after a few thousand miles and a little offroad (use of the actual shocks and springs) the difference in measurements became where they may be less than 1/2" unless I am parked somewhere that manipulating the vehicle quite a bit. Hope that makes sense, but you definitely don't want to be sitting at 25" with jacked up CV's so just get it aligned and keep a close eye on it.
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
4runnin4mylife is offline   Reply With QuoteReply With Quote
Old 05-12-2019, 03:37 PM #4
Thanks for the info. I figured they need to settle... but it’s super weird that the height is high (25) then turn my wheels back and forth and now at 23.5... go around the block - back at 25” turn wheels back to 23.5...
Not sure if something is binding? Everything looks good...
Alignment is on for tomorrow
Old 05-12-2019, 05:01 PM #5
That is definitely odd that driving around then getting a measurement is 25, and then turning the wheels back and forth brings it down to 23.5. After that alignment,come back, and let us know if that does anything. I will be thinking of what it may could be in the meantime if the alignment doesn't fix it.
Old 05-13-2019, 08:14 AM #6
any ideas after sleeping on it? If were putting it on a rack just thinking what else could I look at and save time.
The front wheels are pretty positive camber... both look like \----/
Well hit the alignment first. Thought it would be good enough to hold me over until my tires come in because the car tracked fine but hopefully not
Old 05-13-2019, 01:02 PM #7
MTN4RNR's Avatar
MTN4RNR MTN4RNR is offline
Real Name: Max
MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough
MTN4RNR's Avatar
Real Name: Max
Definitely get things aligned, that will help a lot.
2016 MGM Trail Premium - KDSS
Explore4R.com
Building the MTN4RNR
Instagram --- life.to.the.max
Writer/Editor at Trail4Runner.com
MTN4RNR is offline   Reply With QuoteReply With Quote
alignment , back , home , issue , wheels
Suspension install DannyLlama So Cal 72 04-10-2017 02:36 PM
Suspension install help pauldavis 5th gen T4Rs 9 01-08-2016 11:05 AM
Bilstein Rear Shock Install vs. Stock Install Question HairyMan 3rd gen T4Rs 7 08-21-2015 09:51 AM
Light Racing UCA post-install question. KCcarguy 5th gen T4Rs 9 08-20-2014 01:14 PM
Post install question on axles 3rd Gen 4Runner Blueman2 3rd gen T4Rs 9 07-12-2011 11:56 AM
