05-13-2019, 05:33 PM
BPF Aluminum Molle Rear Panels 5th Gen 4Runner
BULLETPROOF FABRICATION MOLLE PANEL PAIR FOR 2010+ 4RUNNER
Tired of having all your equipment loosely rolling around in the back? Want some extra space and have your belongings better organized? Well, we have a solution for you! Our all new storage rack is made from light weight aluminum and is tough as nails. This kit includes both driver side and a passenger side storage panels.
Features:
-Panel is made from 11 GA Aluminium.
-Bracket is made from 3/16s Aluminium.
-Laser cut.
-Black powder coated to protect against scratches.
-It mounts directly in OEM bolt location, not drilling.
-No custom fitting required (direct bolt on).
-Bottle opener on one side
-Weighs just 7 lbs both panels.
-T4R logos will both be facing inward.
-Panel includes All needed mounting hardware.
-Aluminum spacers.
-Drivers side and passenger side storage panels.
-Two mounting brackets.
Why Bulletproof Fabrication over the competition?
-Bulletproof Fab is the only company who makes their panels out of aluminum. The benefit of aluminum vs steel is no rusting, a fraction of the weight and dont have to worry about chipping your powdercoat!
-Shipping times on some panels can take upwards of 8 weeks! Not with bulletproof fabrication, as you will have your panels usually within 3 weeks!
-The built in bottle opener makes it easy to open up your favorite beverage while your on the trail or at the campsite.
06-13-2019, 06:56 AM
Anyone out there interested in a passenger side only?? I only want driver side and at this time BPF is not selling them as singles.
06-13-2019, 07:39 AM
Real Name: Bart
Real Name: Bart
Victory 4X4 sells them individually, unless you're set on these.
18 Trail. Cookie cutter built (SOLD)
14 SR5P (SOLD)
06-24-2019, 01:45 PM
Thank you for all of the orders!
06-25-2019, 01:07 AM
Did you buy yet? I'd be interested in splitting with you.
2014 LE - Attitude Black w/Redwood - MODS - Status Mastadon 20x9+5 Carbon Graphite w/Yokohama G015 275/55/20, TRD Pro Front End, RCI Aluminum Skids Bumper-Trans, Rhino-Rack Pioneer 76x49 Backbone System (Chopped to 68x49), GTR Carbide LED Headlamps, DD SS3 MAX Amber Fogs, Gibson Catback Side Exit Dual Tip Black Ceramic Exhaust, Tint: 20% Front/%35 Rear/Limo sunroof, Black Door Handle Covers -
06-25-2019, 09:26 AM
Does the original coat hanger still get used with these or is that eliminated with the install?
06-27-2019, 08:44 PM
You can use it if you want. You just need to trim the little tab on it.
06-28-2019, 05:33 PM
you can reutilize it!
07-02-2019, 08:04 AM
I pulled the trigger on a set, anyone interested in a passenger side only panel, shoot me a PM.
07-02-2019, 09:17 AM
you got pm
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
07-10-2019, 10:07 AM
I just installed the passenger side last night and this thing screams quality. I know other manufacturers make them in steel but this one being aluminum seems just as tough.
07-10-2019, 02:27 PM
Thanks for the review! We are glad to hear you are pleased with the quality. When designing the part, the consensus was there was no reason to choose steel over alum for this part, just adding unneeded weight.
11-28-2019, 11:10 AM
That’s how I feel. I’m kicking my own arse right now for ordering Rago. Senseless weight in steel. I’m returning them and will be ordering BPF today or tomorrow
11-28-2019, 12:04 PM
I’m sure BPF makes a great product, but “senseless weight”... seriously? There’s probably about an 8-10 pound difference between steel and aluminum in this application.
Aluminum probably does make more sense, but It’s hadly worth the hassle of kicking your own arse or returning the Rago panels just to save so little weight. It’s about as silly as bicycle enthusiasts insisting on carbon fiber seat posts in order to shave 4 ounces of weight off their bike.
If you actually plan on using the panels for storage, 8-10 additional pounds isn’t going to make a significant difference in the grand scheme of things.
Wow talk about first world problems.
11-28-2019, 12:49 PM
Any plans for a similar shelf system like rago. I didn’t get theirs because it’s steal
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
