Old 05-14-2019, 04:36 PM #1
dot_tom's Avatar
dot_tom dot_tom is offline
Real Name: Tom
dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all
dot_tom's Avatar
Real Name: Tom
eimkeith PCK kit Install/Review
I recently installed the Eimkeith PCK. Axle was 1” off center with 3” rear springs. Now the axle is centered. Rear suspension cycles much better. Doesn't feel as bound up. Took this off road and the rear feels much smoother. Everything is in place as it should be.
The PCK fit perfect. Prepped the parts and welded them up. Took roughly an hour from start to finish. I would recommend removing the rear spring for better angle when welding the spring side of the mount. Also, keep an eye on the brake lines and hoses in that area. I unbolted them and moved them away as best I could.
There are now 3 positions for the pan hard bar from OEM to 3" lift. I would suggest this for anyone with a rear lift. Great product at a great price!
Buy here: PCK (Panhard Correction Kits) – eimkeith.com
2017 4Runner TRD OR - Progress Thread
295/70/17 BFG KM3, SCS F5 17x9 -38, Front 5100 Rear MT Icon, Dobinson 314 & 701V, Gobi Stealth, RSG Sliders, ECGS 4.56's, Demello Front bumper, Coastal Off Road Rear Bumper
IG: dot_tom
dot_tom is offline   Reply With QuoteReply With Quote
Old 10-21-2021, 06:06 AM #2
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Got my PCK installed at the truck shop in SD.
Fixed these issues:
centered rear axle, due to having a 3+ inch lift, my axle had shifted 1/2 inch passenger side. After install, my axle is now perfectly centered.
Fixed my rear axle bumpsteer or axle hop. I would also get a wobble or butt wiggle when going over freeway expansion joints at over 70 mph. Not very confident inspiring. This was due to having overly stiff springs / oversprung, and having a lift greater than 3 inches in the rear. Now, my vehicle tracks normally.
Driving in soft sand / powder dirt, my rear end would track sideways or fish tail even in 4hi, and i kept getting bogged. This fixed that issue.
panhard is now completely parallel with the axle/ground. Less body roll, less chance of roll over in theory.
Overall, not terribly expensive or time consuming to install. Just find a good welder.
cheers.
eimkeith PCK kit Install/Review-pck-jpg
Old 10-21-2021, 09:46 AM #3
CajunMikeR's Avatar
CajunMikeR CajunMikeR is offline
CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice
CajunMikeR's Avatar
I didn't wait to encounter issues before installing one. The small shop that I used to install my lift also installed the PCK, lower link skids, and did a BMC at the same time. As this was my first 4Runner, I did a lot of research before settling on a lift and associated equipment, the PCK was a no brainer.
2019 MGM TRD ORP
Dobinsons IMS 3in lift, FN f(x) Pros 17x8in 0 offset, 285/70 C load Nitto Ridge Grapplers, and all sorts of other fun stuff
shootn4runner on IG
CajunMikeR is offline   Reply With QuoteReply With Quote
Old 10-21-2021, 10:08 AM #4
PCK makes spending hundreds on panhard bars pointless, AND has better geometry. such a great upgrade.
Old 10-21-2021, 12:03 PM #5
mrblah's Avatar
mrblah's Avatar
yeah i figured this out after i bought i wasted my money on a adjustable panhard bar...ROFL.
Old 10-21-2021, 02:06 PM #6
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice
blksubykid's Avatar
my panhard bar came with the kit, so it was a perfect time to complete the PCK when I upgraded my rear links
blksubykid is offline   Reply With QuoteReply With Quote
Old 10-21-2021, 03:23 PM #7
TRDHULK's Avatar
TRDHULK TRDHULK is offline
TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold
TRDHULK's Avatar
Yep, did this too and love it. OP, I like how you smoothed out the welds to make it look more OEM.
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
TRDHULK is offline   Reply With QuoteReply With Quote
Old 10-21-2021, 11:23 PM #8
to be fair, upgrading the bushings is never a bad thing
Old 08-09-2022, 05:40 AM #9
StomblinBear StomblinBear is offline
StomblinBear is on a distinguished road
so should I even replace my panhard bar?
i'm going to the EimKeith PCK and Treaty Oaks KDSS spacer kit... once everything is installed, would I even need to replace the stock panhard bar?
StomblinBear is offline   Reply With QuoteReply With Quote
Old 08-09-2022, 12:58 PM #10
NorthPark NorthPark is offline
NorthPark will become famous soon enough NorthPark will become famous soon enough
I have the icon bar and am looking at the PCK as well. Mine with just the adjustable bar is not enough to get everything centered, I know of another KDSS owner that had to do both the PCK and the adjustable bar to really get things aligned. As always, just depends on your 4runner
NorthPark is offline   Reply With QuoteReply With Quote
Old 09-02-2022, 07:50 PM #11
tls3601 tls3601 is offline
Real Name: Tom
tls3601 will become famous soon enough tls3601 will become famous soon enough
Real Name: Tom
Wonder if I ever went back to stock ride height, would the pan hard correction bracket still clear at full compression on a 5th Gen? Thanks. Tom
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
tls3601 is offline   Reply With QuoteReply With Quote
eimkeith , great , pck , rear , spring
Ironman 4x4 Lift Install and Review Tinman1985 Classic T4Rs 5 01-21-2022 12:48 PM
Panhard Correction Kit install - Shout Out to @eimkeith DaMonkey 3rd gen T4Rs 4 07-18-2018 12:29 AM
881 906 HD Install Review/Issues Bishard 3rd gen T4Rs 2 12-17-2012 08:54 PM
Spartan locker install and review KidVermicious Classic T4Rs 48 10-02-2012 02:30 AM
SPC UCA Install/Initial Review honda_nos 4th Gen T4Rs 6 01-04-2012 12:57 AM
