05-14-2019, 04:36 PM
Real Name: Tom
Real Name: Tom
eimkeith PCK kit Install/Review
2017 4Runner TRD OR - Progress Thread
295/70/17 BFG KM3, SCS F5 17x9 -38, Front 5100 Rear MT Icon, Dobinson 314 & 701V, Gobi Stealth, RSG Sliders, ECGS 4.56's, Demello Front bumper, Coastal Off Road Rear Bumper
IG: dot_tom
10-21-2021, 06:06 AM
Got my PCK installed at the truck shop in SD.
Fixed these issues:
centered rear axle, due to having a 3+ inch lift, my axle had shifted 1/2 inch passenger side. After install, my axle is now perfectly centered.
Fixed my rear axle bumpsteer or axle hop. I would also get a wobble or butt wiggle when going over freeway expansion joints at over 70 mph. Not very confident inspiring. This was due to having overly stiff springs / oversprung, and having a lift greater than 3 inches in the rear. Now, my vehicle tracks normally.
Driving in soft sand / powder dirt, my rear end would track sideways or fish tail even in 4hi, and i kept getting bogged. This fixed that issue.
panhard is now completely parallel with the axle/ground. Less body roll, less chance of roll over in theory.
Overall, not terribly expensive or time consuming to install. Just find a good welder.
cheers.
10-21-2021, 09:46 AM
I didn't wait to encounter issues before installing one. The small shop that I used to install my lift also installed the PCK, lower link skids, and did a BMC at the same time. As this was my first 4Runner, I did a lot of research before settling on a lift and associated equipment, the PCK was a no brainer.
2019 MGM TRD ORP
Dobinsons IMS 3in lift, FN f(x) Pros 17x8in 0 offset, 285/70 C load Nitto Ridge Grapplers, and all sorts of other fun stuff
shootn4runner on IG
10-21-2021, 10:08 AM
PCK makes spending hundreds on panhard bars pointless, AND has better geometry. such a great upgrade.
10-21-2021, 12:03 PM
yeah i figured this out after i bought i wasted my money on a adjustable panhard bar...ROFL.
10-21-2021, 02:06 PM
my panhard bar came with the kit, so it was a perfect time to complete the PCK when I upgraded my rear links
10-21-2021, 03:23 PM
Yep, did this too and love it. OP, I like how you smoothed out the welds to make it look more OEM.
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
10-21-2021, 11:23 PM
to be fair, upgrading the bushings is never a bad thing
08-09-2022, 05:40 AM
so should I even replace my panhard bar?
i'm going to the EimKeith PCK and Treaty Oaks KDSS spacer kit... once everything is installed, would I even need to replace the stock panhard bar?
08-09-2022, 12:58 PM
I have the icon bar and am looking at the PCK as well. Mine with just the adjustable bar is not enough to get everything centered, I know of another KDSS owner that had to do both the PCK and the adjustable bar to really get things aligned. As always, just depends on your 4runner
09-02-2022, 07:50 PM
Real Name: Tom
Real Name: Tom
Wonder if I ever went back to stock ride height, would the pan hard correction bracket still clear at full compression on a 5th Gen? Thanks. Tom
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
