BCMUSA
Can you list your mods, or lack of, in your sig? Super helpful for everyone, just FYI.
I had this issue on our GX. Tried balancing, but it didn't solve it fully. Getting the alignment dialed in with everything zeroed out with as much positive caster as possible should help alleviate the vibrations.
First is the tire balance. Which you've done.
Second, Good alignment
Improper caster will lead to steering shimmy. With the factory injected rubber bushings in the LCA, they will move around quite a bit. Which creates a bunch of oscillation that travels to the steering components.
Last step would be dialing in your PSI specific for tire and environment. Won't help a ton, but it will help.
BTW, love your products. Good luck trying to find a decent alignment tech.
Originally Posted by yardsale
Personally, I think it is all in your head. Brand new Tacoma and brand new 4runner with the same problem? Highly unlikely. Just relax and enjoy your vehicle.
This is a known issue that has plagued toyota 120/150 platforms. Feel free to look into it.
Specific to alignment issues:
Originally Posted by BCMUSA
I noticed something these last two days of driving. Whenever I take a bend on the freeway, for the entire time that I am on that bend, the vibration is gone. As soon as I'm straight again, it comes back. What the heck can this be?
And
I should also mention that I feel the vibration coming from the bottom of the steering wheel. If I put my hand on the steering column, I can feel it there pretty good.
