Old 05-14-2019, 08:21 PM #1
BCMUSA's Avatar
BCMUSA BCMUSA is offline
BCMUSA is on a distinguished road
BCMUSA's Avatar
Vibration gone when cornering
Hello all, a few days ago I posted saying I have steering wheel vibration and a wobble.
The wobble was pretty much fixed with a road force balance and tire pressure adjustment.
However I still have a CONSTANT vibration in my steering wheel.
Can start feeling it at 40mph+ and never goes away unless I go under 40. It's not a bad vibration, but its there and never goes away and its driving me nuts. It feels like I'm holding an electric toothbrush.
I noticed something these last two days of driving. Whenever I take a bend on the freeway, for the entire time that I am on that bend, the vibration is gone. As soon as I'm straight again, it comes back. What the heck can this be?
Also, is it crazy for me to think this vehicle should have zero vibrations in the steering wheel?
I should also mention that I feel the vibration coming from the bottom of the steering wheel. If I put my hand on the steering column, I can feel it there pretty good.
Vehicle going into dealership tomorrow, and I may possibly get new tires if they cant fix it.
I haven't slept in a week. Had just traded in my 19 Tacoma for tons of problems with it, and now this one.
I appreciate the feedback.
BCMUSA is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 09:00 PM #2
yardsale's Avatar
yardsale yardsale is offline
yardsale is on a distinguished road
yardsale's Avatar
Personally, I think it is all in your head. Brand new Tacoma and brand new 4runner with the same problem? Highly unlikely. Just relax and enjoy your vehicle.
yardsale is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 09:11 PM #3
BCMUSA's Avatar
BCMUSA's Avatar
Wrong. 1 advisor, 2 tech's, and the foreman himself agreed my Tacoma had issues. They just couldn't figure it out. I got tired of taking it in and traded it in for this one.
On the 4runner I may be hypersensitive, but there's definitely a vibration. Wife feels it too, she just says it's not something that would bother her personally. It does bother me though.
I just found this: Buzzing noise/vibration in steering wheel
Dude is saying the exact same thing I am, although on mine I highly doubt it's the bearings as the vehicle is brand new, but who knows.
Old 05-14-2019, 09:18 PM #4
JSparky's Avatar
JSparky JSparky is offline
JSparky will become famous soon enough JSparky will become famous soon enough
JSparky's Avatar
I havenít been following your vibe posts, but have you looked into the front diff needle bearing issues some Toyotaís have? Itís common among Tacomaís and 4Runners with part time 4wd. East Coast Gear makes a bushing swap for it. Relatively easy to diagnose. Hope that helps.
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 09:28 PM #5
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a jewel in the rough 2016 4Runner SR5 is a jewel in the rough 2016 4Runner SR5 is a jewel in the rough 2016 4Runner SR5 is a jewel in the rough
MY GARAGE
Real Name: Chris
MY GARAGE
What tires are you running? What size are said tires? Have you had the alignment checked? Stands to reason that issues that go away when cornering may be due to a bad alignment.
2016 4RUNNER SR5 PURCHASED NEW JANUARY 29TH 2017 - OEM TRD PRO SUSPENSION WITH 3/8 TOP HAT SPACERS & 1" TOYTEC BAJA SPRING SEATS FOR A TOTAL OF 2.5" LIFT, 2" CORNFED SPACERS IN THE BACK, FX PRO WHEELS, 295/70/17 MICKEY THOMPSON ATZ P3, WEATHER PACKAGE, NAVIGATION, LED INTERIOR LIGHTS, TRD INTAKE WITH AFE PRO DRY FILTER, TYGER SLIDER STEPS, TOYOTA BLACKOUT EMBLEM KIT, TRD PRO GRILL, POLY FRONT AND REAR SWAY BAR BUSHINGS, OEM 3RD GEN REAR SWAY BAR LINKS, REAR DIFF BREATHER MOD, RCI ALUMINUM FRONT SKID, OEM ALUMINUM OIL FILTER HOUSING UPGRADE, OIL CATCH CAN.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 09:31 PM #6
tristero's Avatar
tristero tristero is offline
Real Name: Justin
tristero will become famous soon enough
MY GARAGE
tristero's Avatar
Real Name: Justin
MY GARAGE
@BCMUSA
Can you list your mods, or lack of, in your sig? Super helpful for everyone, just FYI.
I had this issue on our GX. Tried balancing, but it didn't solve it fully. Getting the alignment dialed in with everything zeroed out with as much positive caster as possible should help alleviate the vibrations.
First is the tire balance. Which you've done.
Second, Good alignment
  • +4 Caster
  • 0 Toe
  • 0 Camber
Improper caster will lead to steering shimmy. With the factory injected rubber bushings in the LCA, they will move around quite a bit. Which creates a bunch of oscillation that travels to the steering components.
Last step would be dialing in your PSI specific for tire and environment. Won't help a ton, but it will help.
BTW, love your products. Good luck trying to find a decent alignment tech.
This is a known issue that has plagued toyota 120/150 platforms. Feel free to look into it.
Specific to alignment issues:
And
2010 4Runner SR5 Magnetic Gray: Radflo / Icon + Metaltech / Total Chaos / Dirt King / SCS Stealth 6 / BAMF Sliders + Pelfreybilt Bumper / PRINSU / Indel B / 2014+ IS 350 Retrofit
2012 GX460 Premium Black Onyx: Stock af
tristero is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 10:01 PM #7
BCMUSA's Avatar
BCMUSA's Avatar
Guys thank you very much for the input. I really appreciate it.
I am fully stock.
I will definitely get alignment checked.
Old 05-14-2019, 10:15 PM #8
BCMUSA's Avatar
BCMUSA's Avatar
Originally Posted by JSparky View Post
I haven’t been following your vibe posts, but have you looked into the front diff needle bearing issues some Toyota’s have? It’s common among Tacoma’s and 4Runners with part time 4wd. East Coast Gear makes a bushing swap for it. Relatively easy to diagnose. Hope that helps.
TOYOTA 8" CLAMSHELL CV AXLE BUSHING
Is this it?
How is it diagnosed?
Thank you
Old 05-14-2019, 10:48 PM #9
renau001 renau001 is offline
renau001 is on a distinguished road
No, youíre not out of line for expecting no buzzing vibrations in your steering wheel. I had a tire balance steering wheel shake and the front diff needle bearing. Now both resolved. Not once would I have ever described at as a buzz. The front diff needle bearing issue is diagnosed by seeing if the cyclic groan goes away in 4wd.
2016 Trail Edition Premium w/ KDSS. LT265/70R17 BFG KO2s, Ceramic Pro, TSO pro grille, sliding cargo tray, WeatherTech floor liners, '10-'13 trail running boards.
Nobody cares about your vehicle as much you do. DIY Maintenance Quick Reference
renau001 is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 11:24 PM #10
The_Green_Wang's Avatar
The_Green_Wang The_Green_Wang is offline
The_Green_Wang has a spectacular aura about The_Green_Wang has a spectacular aura about
This has been an issue for awhile and is seen in a lot of members here. I had this as well, when reaching about 50-60mph the steering wheel vibrates but once you go past 60 or lower down it disappears and doesnt reappear until you stop and go again. I pretty much accepted it, and somewhere between the 3 different changes in shocks it disappeared. Cant say for sure if it was that or due to getting alignments everytime but one of the two stopped my issue.
Sent from my SM-N950U using Tapatalk
The_Green_Wang is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 11:28 PM #11
BCMUSA's Avatar
BCMUSA's Avatar
I'm glad yours went away. Mine is constant pretty much anything over 40mph. However once I reach 70 it's less noticeable.
I noticed on mine today that some of these rims have a ton of balancing weights on them. One had like a 6" strip taped inside plus another weight clamped on the rim. Doesn't seem normal?
Anyways, tomorrow it's going to dealership and we will see what they say.
Either way my plan is to get an alignment and request they do what the member here suggested, probably get new tires, and get those RFB as well.
I want to love this thing, but this buzzing type vibration is driving me nuts. I can feel it come and go in the gas pedal too.
bend , driving , steering , vibration , wheel
2005 Sequoia Stalls after cornering (solved) xcmountain80 All Other Vehicles 3 05-29-2019 09:47 AM
Vibration ( I know-another vibration thread) jreask 4th Gen T4Rs 1 03-16-2018 02:14 PM
Off-Road Cornering Lights pefiln 4th Gen T4Rs 2 07-01-2015 07:15 PM
Improve SR5 cornering (sway bars, Bilstein shocks?) Arterisk 5th gen T4Rs 12 06-29-2011 09:24 AM
'09 sport transmission slip when cornering captain72 Problems & Warranty Issues 2 10-17-2009 10:37 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
