C4 FABRICATION SLIDERS & FUEL TANK SKID
I finally was able to install my C4 Fabrication Rock Sliders and Fuel Tank Skid! These are super stout and a really well thought out design. The quality of the welds and attention to detail really shows in Caleb’s work.
I had been researching rock sliders for some time. There is a wealth of information in
HerT4R
thread (
Consolidated Slider Thread). I reviewed the options and decided the C4 Fab sliders were for me. The details can be found on their website (
C4 Fabrication), but here are the main reasons I chose the C4 Fab sliders.
Why C4 Fab?
1) 100% bolt-on design to existing tapped holes
2) The rear part of the slider kicks out to give a more functional step
3) Main slider support legs are welded in at a 45 degree angle. This helps prevent the sliders from getting hung up on sharp rocks and provides more clearance
4) Front portion of the tube is mitered at an angle, allowing you to slide up and over an obstacle. Other designs have a squared off tube attachment, which could more easily get hung up on a stump or other obstacle.
5) Price. The sliders are really well priced for all of the features designed in ($625 with step plates)
I decided to also purchase the Fuel Tank Skid to protect this vulnerable piece. Since this is also my daily driver, I did not want to go full armor and add the extra weight. While this skid is heavier than the Aluminum skids available out there, the design attributes were worth the extra weight. The other designs I reviewed left the front portion of the fuel tank still exposed. The C4 Fab design provides a full enclosure with a ramp feature in the forward approach. I am really happy with it! I also have the TRD Front Skid and that's about it for me as far as armor goes. I may consider something like RCI's TRD integration skid, but that would be it.
The sliders and fuel tank skid ship with a raw steel finish, which needs to be addressed so as not to develop rust.
Prep, Prime, Paint
1) Clean machine oil residue off using mineral spirits. Get as much off as possible to make sanding easier.
2) Abrade the surface using 80-120 grit sandpaper. I used 100 grit with my Makita vibrating sander. This worked great on the fuel tank skid since it is mostly flat surfaces. The sliders were a bit more challenging as there are more pieces to address and some tight nooks. I did my best to get down to the raw metal.
3) Blow loose dust particles off using compressor or air gun
4) Wipe down surface again. I used alcohol.
5) Scotch brite surface until metal becomes brighter color. This ensures you get the residual oxidation off.
6) Blow loose dust particles off using compressor or air gun
7) Wipe down surface again. I used alcohol at first, but then found the Duplicolor prep spray worked better.
8) Applied 3 coats of Rustoleom primer (RTA9205). Let cure 24 hrs.
9) Applied 6 coats of Duplicolor flat black paint (DA1605). Let cure 7 days
10) Applied 5 coats of Duplicolor Bed Armor. This was done on the sliders only to give some extra traction when using the step plates in mud or snow. This stuff took forever to dry. I let it cure for 5 days.
I’m sure I made some mistakes when painting as this was the first time I’ve ever painted something like this. I have painted my house, but never raw steel. I think I was supposed to sand the cured paint before applying the bed armor, but we will see how it holds up. It was pretty windy a couple of days when I was priming/painting. I am sure I wasted at least 3 cans of paint due to the wind.
This was A LOT of work! I wore a respirator the whole time due to the metal debris. Sure I saved a couple of bucks and got some experience and satisfaction from DIY. But if I had it to do over again, I would have sent the sliders out to be Linex’d.
Installation
The installation was pretty straightforward.
Fuel Tank Skid – Attach the 3 hanger arms to the skid first. Use a floor jack to move it into place. Once you have all the factory bolts holding the skid in place where it fits good, then tighten up the mounting legs where they attach to the skid. I ran into a little issue where I had everything shifted to one side of the slot, which provided very little clearance from one of the bolts to the fuel tank. I loosened it back and up and shifted things to the other side and I have enough clearance now. I could also flip the bolt around since the bolt head is lower profile than the nut/lock washer.
Sliders - As for the sliders, they are pretty easy. You just have to remove the forward most e-brake cable bracket bolt so that the bracket hangs loose. Twist the bracket up so it doesn’t snag on the sliders as you lift them into place. All of the 8mm bolts that came with the sliders thread into the holes in the side of the frame rail. Once the slider is in place, the e brake bracket gets bolted back into the same hole on top of the slider plate.
That’s it! I am really happy with the quality of these C4 Fabrication products and with the install. I highly recommend taking a look at these.
Wild_Turkey Build Thread
2015 SR5 Premium 4x4 / 3rd row seat: Bilstein 6112/5160 @2.5"F/2"R // Total Chaos UCA // C4Fab Rock Sliders / Fuel Tank Skid / Lo Pro Winch Bumper // 17x8 FN F(X) Pro Wheels // BFG AT KO2 275/70R17 // ARB Compressor/ Fridge/ Rear Air Locker // KC HiLites // James Baroud Grand Raid // Canvasback cargo liner // Rear Diff Breather Mod
