05-15-2019, 04:20 PM
Bilstein B12 Spring Kit 1-1.5" Rear Suspension Lift - Reviews?
Has anyone actually installed this new B12 rear spring kit for the 1-1.5" lift (normal load)?
I'm so close to purchasing these so I've been looking for reviews all over the inter-webs, and can't find any.
If you have installed them, or even the 1.5-2" or the 1.5" heavy load, please let us know your thoughts.
Pics/reviews would be most appreciated!!!
2019 TRD Pro | IG: @trdprocat | RSG Sliders | Falken Wildpeak AT3W | Morimoto/XD LEDs | CTX Tint
past: '18 4Runner TRD ORP... RIP, Kaiyo!
'07 4Runner SE... SOLD
'02 4Runner SR5 4WD... SOLD
05-15-2019, 07:06 PM
Real Name: joe
Real Name: joe
im getting ready to install them this weekend i will post some pics after i get the lift installed
05-15-2019, 07:26 PM
Looking forward to seeing the results! I have the 1” springs on route now. The 6112/5160 shocks are on back order so unfortunately I will have to wait for those before install. I’ll post my results with photos, but you would have probably made your decision by then.
2018 TRD Off-Road, KDSS, 285 KO2s C, 6112/5160 + B12 rear - 2.5"/1", 1.25" Spidertrax Spacers, Greenlane Off-Road Aluminum Sliders
05-15-2019, 08:28 PM
Are you just wanting 1” of lift and no additional load capacity? I talked to the bilstein engineers about these springs before I did my lift. I would have bought them but they weren’t available. I got tired of waiting and bought the Eibach 1” springs that have a 10% stiffer rate. The Eibachs were also cheaper.
2022 Limited 4x4 Silver
2017 TRD Offroad. Barcelona Red, 265 BFG KO2, Eibach Pro-truck 1.6/1, Shrockworks sliders-TRADED
05-15-2019, 09:10 PM
What's the Billstein's spring rate?
05-16-2019, 05:43 AM
When I asked, Bilstein said factory rate. They never gave me a number.
05-17-2019, 02:59 PM
Hey
@ Harrisnc
... The only extra 100% constant load is that stupid sliding cargo tray and then 75% constant load I have is my 65lb lab, ~50lb bike rack with 1-2 bikes coming in at an additional 20-40 lbs. So I guess that adds an extra 155 lbs, then 5-8 times a year we add an extra 150lbs of camping crap on to that. So I'm still way under the 400lb constant.
Thoughts?
Do you have a good shop up in CLT? I'm down in Spartanburg.
05-17-2019, 04:04 PM
I’ve had my bike rack, 3 bikes, kid and less than 200lbs of gear in mine and it still has some rake. Daily driving, I can tell it’s firmer butit I don’t know how much of that is the shocks.
As far as shops, I do most of my own work. There are two shops here that I’ve used but I’ve had issues both.
05-20-2019, 10:13 PM
Real Name: joe
Real Name: joe
just installed bilstein 6112 at setting 6 and 4 with 5100 in the rear and the bilstein 1" rear spring and it sits almost level and the ride is so much better then factory i will try to post pictures when i can upload them
05-21-2019, 09:21 AM
Hey
@ 18 trd off road
... how did your install go? Any pics?
Thank you!!!
10-04-2020, 01:51 AM
Real Name: Tristan
Real Name: Tristan
So I'm ready to add a lift to my 4th gen. I've read the ome springs can be a little too stiff especially in the back, and saw these b12s ... They look promising. Curious to hear everyone's thoughts as well. Thanks
2005 SR5 4WD: V8 - Doug Thorley headers, Bilstein 5100s, Slee offroad steel brake lines, Tundra brake swap, JBA upper control arms, 33s on RockTrix wheels, etc.
05-20-2021, 07:58 AM
On backorder
Like everything Bilstein mines on backorder but it sounds like it’ll ship any day now after waiting 5 weeks. I opted for the heavy duty with 5100 all around because I plan to use it for a tow vehicle for a 4000lb trailer in the summer. Tongue weight droops my stock rear suspension down to the bump stop and is well over 400lbs. I’ve carried my small snowblower on a hitch carrier and thought the camper would be similar, but it’s way more sag than I’m comfortable driving at highway speed.
I’ll post pics when done.
2010 SR5 4x4
