Old 06-02-2019, 12:28 AM #16
ProfessorP's Avatar
ProfessorP ProfessorP is offline
ProfessorP is a jewel in the rough ProfessorP is a jewel in the rough ProfessorP is a jewel in the rough ProfessorP is a jewel in the rough
ProfessorP's Avatar
I installed one of the Wireless CarPlay Kenwood head units a week ago.
Crutchfield has a dash kit that matches the dark gray metallic factory dash without any need to paint.
The iDatalink Maestro was very easy to flash/program. All of my steering wheel buttons work perfectly.
I drilled a 1/2” hole in the dash kit plastic and snapped the mic in place so only the last 1/8” ring of it shows. I recommend a step drill bit like the kind you use for sheet metal. The mic now looks like a small button with holes surface mounted to the left of the screen. I did have to cut the little ball off the side of the mic in order to snap it in place.
I mounted the Kenwood GPS antenna right behind the little round cover that holds the wire for an automatic headlight sensor at the front edge of the dashboard. I drilled a small hole at the edge of the plastic cover to allow the antenna wire to pass through with the cover in place.
If you get an error message telling you that the speed sensor wire needs to be connected in order for Wireless CarPlay to work do the following (talked to a Crutchfield tech for an hour before we figured this out):
1. Find the pink wire on the Kenwood side of the wiring harness.
2. Locate the little, thin, white in-line “box” that says S Sensor on the pink wire.
3. Cut the pink wire on either side of the little white “box.”
4. Reconnect (crimp or solder) the ends of the pink wire. Cover any exposed wire with electrical tape or heat shrink tubing.
5. Turn the head unit on and the speed sensor error message continues. Drive around a little so the speed sensor communicates with the head unit and Wireless CarPlay will start functioning properly.
I already helped one T4R member with this issue. Trust me it works. Your Wireless CarPlay may work at first, but when it quits the next day follow the steps above.
ProfessorP is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 01:50 AM #17
Dr. Monkeypants Dr. Monkeypants is offline
Real Name: I didn't go to Monkey Medical School for 8 years to be called Mr. Monkeypants
Dr. Monkeypants is a jewel in the rough Dr. Monkeypants is a jewel in the rough Dr. Monkeypants is a jewel in the rough
I just put an Excelon in my car. They have adapters for everything except the factory mic. So I made a bracket to put the Kenwood mic in the factory location:
Custom hidden mic bracket for aftermarket head unit
2019 Nightshade with a little custom stuff
Dr. Monkeypants is offline   Reply With QuoteReply With Quote
Old 09-30-2019, 11:39 AM #18
jerrito jerrito is offline
jerrito is on a distinguished road
Greetings! I’m a new to the forum. I installed the Kenwood DMX906X in my 2003 4Runner, non JBL, non RDS but can’t get the wireless CarPlay to work.
I found the Purple/Red wire in two locations under the driver side kick panel and tap into both locations but the wireless CarPlay didn’t work. Is the Purple/Ref the correct wire and right location to tap into it.
Thanks!
jerrito is offline   Reply With QuoteReply With Quote
Old 09-30-2019, 11:57 AM #19
tylertenny's Avatar
tylertenny tylertenny is offline
tylertenny will become famous soon enough
tylertenny's Avatar
It works with the factory backup camera? I'm hesitant to get an aftermarket head unit because I don't want to lose the backup camera and steering wheel controls. I'm not as concerned about the navigation.
tylertenny is offline   Reply With QuoteReply With Quote
Old 09-30-2019, 12:39 PM #20
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
Thanks!
I'm going to assume you are looking for VSS wire.
violet/red
ECM behind glove box, white 35 pin plg (E7, 2nd from bottom), pin 17
Note: On models with navigation, it is also purple/red at the radio, gray 5 pin plug, pin 3.
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 09-30-2019, 03:17 PM #21
mogg851 mogg851 is offline
mogg851 is on a distinguished road
My DNX995S has the factory camera without issue. I think that's true with most units. However with the iDatalink and a kenwood unit on at least the later model 5th gens (2018 ORP) I got dynamic backup lines on the backup camera (factory lines are still there, but ignorable) and have full customizability of the buttons on the steering wheel.
mogg851 is offline   Reply With QuoteReply With Quote
Old 11-16-2019, 12:24 PM #22
Brianseave Brianseave is offline
Brianseave is on a distinguished road
@MikeYQM are you happy with your Kenwood? Would you recommend it?
Sorry for being off topic.
I'm in the process of upgrading my stock stereo and looking for a good one.
From my research Kenwood is a good option. But can't make up my mind. All the reviews I've read so far are hype garbage. Actually I've tracked down a site that tells it how it is. I was eyeing the Kenwood DDX9704S double din thanks to the review.
Can you tell me how bad the is the screen glare? What about the price is there enough value to justify it?
I'm open for suggestions
Brianseave is offline   Reply With QuoteReply With Quote
Old 11-16-2019, 02:53 PM #23
SnowYeti's Avatar
SnowYeti SnowYeti is offline
SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough
SnowYeti's Avatar
I installed a Kenwood Echelon with iData Link this summer and love it.
Crutchfield does have and adapter kit for the factory GPS and satellite antennas. They didn’t know until I told them they had it. Ug. So the only thing you need to deal with is the mic. I installed mine behind the rear view mirror, works great and out of sight
Bought USB plugs that snap into Toyota factory switch locations. Replaced the factory one in the center console and the blank right below the ignition for the Apple Car Play, phone mount right above it (very convenient)
MUCH better nav and maps
Easier updates to maps, no dealer required
Apple car play
Bigger better screen
Dynamic backup lines that are adjustable
TPMS pressure for each tire!
Passenger can enter a address while moving
Really so much better in every way
KENWOOD Head Unit Install Questions-96e40205-1fec-4944-9546-afad4fa34aa7-jpg  KENWOOD Head Unit Install Questions-24ea6523-3226-4210-9397-9c2135f04a7c-jpg  KENWOOD Head Unit Install Questions-8bd755c6-0b54-4c2e-85e5-b29c1dc49253-jpg
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
SnowYeti is offline   Reply With QuoteReply With Quote
Old 11-16-2019, 04:46 PM #24
CrazyMike's Avatar
CrazyMike CrazyMike is offline
CrazyMike is on a distinguished road
CrazyMike's Avatar
@SnowYeti
Did you get the plastic surround painted? Or did you manage to find one already painted?
https://photos.smugmug.com/photos/i-fP97x8D/0/S/i-fP97x8D-S.jpg
2016 4Runner TRD Pro in Super White, BFG 275/70R17, Gobi Stealth, CVT Mt. Shasta Extended Summit Series RTT, Genesis Off Road Dual Battery System
CrazyMike is offline   Reply With QuoteReply With Quote
Old 11-16-2019, 10:36 PM #25
SnowYeti's Avatar
SnowYeti's Avatar
Originally Posted by CrazyMike View Post
@SnowYeti
I had it painted. Okay match. $100
Old 11-17-2019, 12:35 AM #26
KP Texan KP Texan is offline
KP Texan has a spectacular aura about KP Texan has a spectacular aura about
Just installed my Kenwood DMX905S this past week and it's awesome! Made sure to install the latest firmware, and haven't noticed any hiccups. Also used the Maestro RR and am highly impressed by that as well. My build thread is here, but let me know if you have any questions!: My Basic Stereo Build - 2012 Limited
2012 Limited, 4WD, Classic Silver Metallic
2018 TRD ORP - Sold
2006 Sport Edition - Sold
KP Texan is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 12:31 AM #27
nerfkhat nerfkhat is offline
nerfkhat is on a distinguished road
I just installed a dmx905s as well and love that thing. I had a alpine for only a few days before i decided to switch to the kenwood. But everything works that I had w oem (backup camera, gps, usb aux port) except the oem mic like one other said.
nerfkhat is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 06:46 PM #28
cobouldering cobouldering is offline
cobouldering is on a distinguished road
@SnowYeti - What adapters did you use for factory antennae and factory XM radio?
cobouldering is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 10:13 PM #29
SnowYeti's Avatar
SnowYeti's Avatar
I will look up my receipt tomorrow and let you know
Old 10-02-2020, 05:07 PM #30
SnowYeti's Avatar
SnowYeti's Avatar
Sorry about the delay. The kit was not on my invoice since they threw it in so I had to call.
Here it is:
iDatalink ACC-SAT-TO2
iDatalink ACC-SAT-TO2 Satellite radio and GPS antenna adapters for select Toyota vehicles at Crutchfield
antenna , gps , head , kenwood , microphone
Sub install to stock head unit questions flyinhawaiian01 5th gen T4Rs 31 01-05-2024 07:12 AM
Kenwood DDX470 Head Unit Install singleshot 4th Gen T4Rs 22 01-21-2014 01:47 PM
FS Kenwood Head Unit $200 Kenwood Excelon KDC-X995 CD Receiver Desert Fox For Sale: T4R Items 4 05-26-2013 02:34 PM
99' Head Unit install questions. Doodlydo Engines / Suspension / Wheels / Tires / Audio / Accessories 1 08-24-2010 11:38 PM
Where's your brain?! (& other head unit install questions) atomic punk Engines / Suspension / Wheels / Tires / Audio / Accessories 0 02-14-2005 11:23 PM
