Old 05-17-2019, 11:05 PM #1
DaddySteve DaddySteve is offline
DaddySteve is on a distinguished road
King Lift SwayBar contacting the radiator brace
1st post. I've been following this forum for the past year. Alot of great information. Just finished installing a King lift purchased from Flithy Motorsports. My orginal plan was to go 2.5" front and 2" rear lift. Install went smooth however ran into a problem. At 2.5" of lift the drivers side sway bar was making contact with the radiator support bracket. Even with the supplied spacers installed. So I reduced the lift to just under 2" and left my stock REAR springs and 1" spacers installed. Now there is maybe 1/16 of clearance between the radiator brace and the drivers swaybar. Flithy spoke to King and they advised to add a thick washer to the radiator support spacers. Anyone else heard of this problem? The Lift rides great btw. Fantastic improvement over stock.
2018 4runner TRD Offroad Prem Non KDSS
Thanks
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
DaddySteve is offline   Reply With QuoteReply With Quote
Old 05-17-2019, 11:41 PM #2
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
Originally Posted by DaddySteve View Post
At 2.5" of preload the drivers side sway bar was making contact with the radiator support bracket. Even with the supplies spacers installed. So I reduced the preload to just under 2" and left my stock spring and 1" spacer installed. Now there is maybe 1/16 of clearance.
Confused about a few things here. Are you talking about 2.5" of preload from 0", or are you talking about 2.5" of lift? Two totally different things.
How are you running stock springs with King COs? Why are you running a 1" spacers with COs at all? I'm very familiar and have spoken to Filthy several times and this doesn't sound like anything that he would recommend.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 05-18-2019, 02:47 AM #3
Sorry for the confusion. Yes you are correct Bayou. I updated the post and with pics. 2.5" Lift not Preload and Stock springs/spacer are in the Rear. Thanks
Old 05-18-2019, 03:30 AM #4
Bayou_Pro's Avatar
Bayou_Pro's Avatar
Looking at the pics, it's odd that you look to have a lot of clearance on one side but not the other. Are you sure the SB spacer brackets are on the correct way? Are you sure the bar in centered on the truck? Haven't really heard of the issue with Kings myself.
Paul
Old 05-18-2019, 09:53 AM #5
Yes, everything installed correctly. It appears the sway bar is not symmetrical. The bend on the drivers side is different than passenger. Filthy says he had another 2018 Off-road Premium with the same issue recently. But these are the only 2 he has heard off. Toyota list 2 different part numbers for sway bars for this model. Sport suspension and non Sport. Not sure what the difference is.
Old 05-18-2019, 10:48 AM #6
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
Look into KDSS radiator braces. They are different.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 05-18-2019, 11:14 AM #7
atchcraft's Avatar
atchcraft atchcraft is offline
atchcraft will become famous soon enough atchcraft will become famous soon enough
atchcraft's Avatar
Contact at that location is pretty normal, with that setup. You can notch that brace, buy an aftermarket brace (there’s one out there somewhere, don’t remember who makes it) or just remove them all together. I don’t believe that a KDSS equipped truck has those. I have an aftermarket front skid and I think that that is going to be plenty of support. Plus, it’s going to give me quite a bit more ground clearance.
atchcraft is offline   Reply With QuoteReply With Quote
Old 05-18-2019, 12:31 PM #8
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
kdss trucks have those brackets, but the swaybar is nowhere near them. The swaybar attaches to the fixed link and the piston, rather than the frame.
The OME BP-51 kits tended to contact there, so along came the BP-51 fit kit:
Arb sway bar rub fix!!! Bp-51 fit kit
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 05-18-2019, 12:41 PM #9
atchcraft's Avatar
atchcraft's Avatar
Yup, that’s the one. I have zero experience with KDSS, so I’ll keep my mouth shut.
Besides keeping the radiator out of the fan, on a mild impact, I wonder how useful these actually are?
Old 05-18-2019, 12:46 PM #10
jrandom's Avatar
jrandom's Avatar
Don't sweat it @atchcraft . KDSS trucks absolutely have them, I have worked on my front end dozens of times. I can confidently say they are there and they are different.
The bend is further forward to the radiator than a non-kdss sway equipped truck. It is exactly why my aftermarket front skid (RCI v1) is totally different than the non-kdss version. As for support I think it would help with the whole front valence as that is all stamped sheet metal.
Correct, they are no where near them in a flat non-articulated stance but do come closer when one or the other front side is “tucked”.
Holy sh!t the welds on those look drunk as fk! I would have sent that kit back.
2013 TE w/ KDSS Nav
Old 05-19-2019, 05:04 AM #11
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
The brace acts as KDSS piston limit strap.. preventing all that gained droop from pulling it apart
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 04:21 PM #12
Wigglepuppy Wigglepuppy is offline
Wigglepuppy is on a distinguished road
Sorry to dredge up an old thread. . . what did you end up doing???
I have the exact same problem with some Fox 2.5 coilovers. . . 2014 TEP, no kdss. . . sway bar relocation bracket pushes sway bar so far forward that it hits radiator brace on driver side (correct. . . sway bar is not symmetrical).
Seems like spacers, washers, spacers and more spacers are the only answers I'm getting.
2014 TEP, BFG 275/70/R17 AT T/A KO2, Front: Fox 2.5 Coilover w/Resi and DSC (883-06-130), Dirt King UCA's (boxed/heim), Dirt King LCA's; Rear: Fox 2.5 w/Resi and DSC (883-26-006 - Tundra Shock Mod'd for 4Runner) w/Icon 2" coils, RCI Alum Skids, Pelfreybilt Sliders, Frontrunner Slimline 3/4 . . . Rear bumper valence removal mod for better exit angle (okay. . . it actually ripped off while wheeling )
Wigglepuppy is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 06:56 PM #13
Seattle206's Avatar
Seattle206 Seattle206 is offline
Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice
Seattle206's Avatar
You want the OME BP-51 suspension support bracket. It replaces the driver side support bracket giving you extra clearance between the sway bar and support bracket. With this bracket you don't need to those support bracket spacers which in turn gives you back some clearance between the ground and front skid plate.
Seattle206 is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 07:15 PM #14
Spot on!!! Got that brace and it fit perfectly!!
Old 07-06-2020, 09:04 PM #15
keller's Avatar
keller keller is offline
keller is on a distinguished road
keller's Avatar
If anyone needs one (BP51 bracket) i got one in a bucket doing nothing. let me know.11
keller is offline   Reply With QuoteReply With Quote
king , lift , preload , radiator , stock
Spindle contacting my spring wtf? Could use some help!? ellner357 3rd gen T4Rs 14 07-27-2020 01:06 PM
3" Lift Question - Swaybar and Driver side lean d0nkeyxpunch 3rd gen T4Rs 7 07-11-2017 02:20 PM
Stupid question, but will front swaybar links work in on the rear swaybar? BlackCat914 3rd gen T4Rs 10 11-15-2012 08:22 PM
BudBuilt - Anyone have any success contacting them? brockeverly 5th gen T4Rs 58 04-04-2012 07:46 PM
Contacting Steve @ XenonDepot XenonDepot General Discussions 0 04-14-2010 05:49 PM
