Old 05-18-2019, 12:47 PM #1
Nick B Nick B is offline
Nick B is on a distinguished road
Cooling System Flush/Refill
My 2010 TE just turned 9 years of ownership and 54,000 miles .
Is it ready for a cooling system flush and refill with new coolant ?
Thanks in advance.
Nick B is offline   Reply With QuoteReply With Quote
Old 05-18-2019, 01:08 PM #2
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
100K is the recommended interval, but I did mine recently at 55K and 6 years. The old coolant looked OK, but I feel better about it because I plan to keep it a long time.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 05-18-2019, 02:00 PM #3
mikey's2010SR5's Avatar
mikey's2010SR5 mikey's2010SR5 is offline
mikey's2010SR5 will become famous soon enough mikey's2010SR5 will become famous soon enough
I am in the school of drain and refill. Had a power steering pump crack with a flush.
And 9 year old truck with 54k. Dang it’s brand new.
mikey's2010SR5 is offline   Reply With QuoteReply With Quote
Old 05-18-2019, 04:47 PM #4
mustangr2 mustangr2 is offline
mustangr2 will become famous soon enough
Thanks in advance.
2010 with 54000. I need to stop driving mine or something. My 17 has like 40k on it already. Lol. I would do the flush since it’s been 9 years. It won’t hurt anything.
mustangr2 is offline   Reply With QuoteReply With Quote
Old 05-20-2019, 10:05 AM #5
Cajun_TRD's Avatar
Cajun_TRD Cajun_TRD is offline
Cajun_TRD is on a distinguished road
Cajun_TRD's Avatar
Drain, Flush with distilled water, drain, fill with Toyota coolant.
I wouldn't put a chemical flush in it, too harmful and not needed for with this low of mileage.
I flush mine with distilled water. Fill it up, take a drive to get it warmed up and make sure the thermostat opens. Run heater. Drain and fill with Toyota coolant and you're done.
At 100k drain, put on new hoses, fill with distilled water, flush, drain, and fill with Toyota coolant.
My F150 daily driver has 400k miles. I've changed the coolant every 50k miles and hoses+coolant every 100k and the radiator passages still look like new. Never used chemical flush. Distilled water is $0.99 a gallon and OEM coolant is cheap. It may sound like overkill but its cheap insurance to never have cooling issues.
TRD OFFROAD PREMIUM WITH SOME STUFF BOLTED TO IT
My Fuelly Log
Cajun_TRD is offline   Reply With QuoteReply With Quote
Old 05-20-2019, 01:16 PM #6
MAXISTYLES's Avatar
MAXISTYLES MAXISTYLES is offline
MAXISTYLES will become famous soon enough
MAXISTYLES's Avatar
No Distilled Water Flush
I would not use distilled water to flush the system as you will never have a true required ratio of water/coolant since some water will remain in the system. I just drained the coolant including engine block drain plugs and filled it with Toyota OEM coolant, already pre mixed. Easy Peasy.
MAXISTYLES is offline   Reply With QuoteReply With Quote
Old 05-20-2019, 04:13 PM #7
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
The system won't retain much water and it's not THAT critical. If you end up with a 45/55 mix that's fine. Plus this guy lives in South Florida so freezing's not really an issue.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 05-20-2019, 06:13 PM #8
TrkyMfns's Avatar
TrkyMfns TrkyMfns is offline
TrkyMfns is on a distinguished road
TrkyMfns's Avatar
I just did mine at 100k. It's very straight forward. I did a drain and refill with OEM coolant.
2011 SR5/P 4WD Blizzard Pearl - 285/70/17 Falken Wildpeak AT3/W - Bilstein 5100 Lift @ 2.5 - SPC UCA's - Two-Tone Katzkin Interior - 15% Lumar Pinnacle Ceramic Tint - Canvasback Liner - Husky Weatherbeater Liners - Phillips Interior LED's - Completely upgraded ICE.
TrkyMfns is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 08:06 PM #9
Is the proper coolant available from the parts store or is it a dealer only thing ?
Also is there a link to a do it yourself write up on this ?
Old 05-22-2019, 03:34 PM #10
MAXISTYLES's Avatar
MAXISTYLES's Avatar
Yes, Toyota Coolant
I recommend getting Toyota OEM coolant from the dealer or elsewhere.
DIY maintenance quick reference - Toyota 4Runner Forum - Largest 4Runner Forum
Above link should tell you most everything you need to know about changing your coolant.
coolant , cooling , flush , refill , system
Cooling system flush, ridding of nasty green stuff silver4est 3rd gen T4Rs 20 04-06-2018 02:59 PM
How many times to flush the cooling system? ShooterMcGavin 3rd gen T4Rs 45 06-21-2017 12:54 PM
cooling system flush freshley 3rd gen T4Rs 5 09-03-2013 03:41 PM
Cooling System Flush - Any Watch-Outs? alphamikefoxtrot 3rd gen T4Rs 4 05-29-2012 12:11 PM
Cooling system flush runrunner 3rd gen T4Rs 3 04-03-2010 06:30 PM
