Old 05-19-2019, 11:27 AM #1
PCRIDE4RUNNERORG PCRIDE4RUNNERORG is offline
PCRIDE4RUNNERORG is on a distinguished road
Winch suggestions - weight ratings
On the 20184R with a warn semi-hidden bumper what winch would you suggest for basic recovery, mostly the vehicle itself. I’m not clear on the weight weighting. Would I need a winch that supports the weight of the vehicle? In this case it seems the minimum would be 6000 lb winch?
Trying to keep the weight in consideration given the bumper and winch will add a good amount of weight. I’d want a synthetic rope as well.
Any suggestions on a winch that won’t break the bank would be appreciated
PCRIDE4RUNNERORG is offline   Reply With QuoteReply With Quote
Old 05-19-2019, 11:41 AM #2
peteknows peteknows is offline
peteknows is on a distinguished road
Rule of thumb is 1.5 times GVWR so typically people would recommend 10,000 pounds for the 4Runner.
2018 Super White TRD Off Road
peteknows is offline   Reply With QuoteReply With Quote
Old 05-19-2019, 11:54 AM #3
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Don't cheap out, get a good one with plenty of capacity. I was stuck in a snowbank last month and looking at a tree across the way. A winch would have had me out quickly. I waited for a built Jeep to pull me out.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 05-19-2019, 11:56 AM #4
CF_Machete's Avatar
CF_Machete CF_Machete is offline
CF_Machete has a spectacular aura about CF_Machete has a spectacular aura about
CF_Machete's Avatar
10k is pretty standard. I went ith a 12k b/c the price and weight was marginaly more and it was the same size
Troner envy... the struggle is real!
CF_Machete is offline   Reply With QuoteReply With Quote
Old 05-19-2019, 12:07 PM #5
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
I might be wrong but if you are asking this question, are you sure you actually need a winch in the first place?
Maybe you will wheel in forested areas in spring, etc, but it is question worth asking.
Are recovery boards and chains insufficient for the intended use? Chains can go a long way in mud. Recovery boards have a good rep for sand though I have never used mine.
A winch is hard-core equipment that requires careful maintenance and use. It is very hard to stay current on how to do something, if it is only used once every couple a years. And then there are the on road disadvantages.
If it will be needed with some regularity, then that's different.
My 2c
Old 05-19-2019, 01:33 PM #6
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
I think that might be a little dramatic.
I've had winch on my daily driver since about 1990. I can't recall any on road downsides unless you're anal about weight/mpg.
Keep in mind, a winch has many more uses than just vehicle recovery. Once it's mounted you'll find all sorts of uses for it.
You can't go wrong with a Warn. I own 2 of them. Personally for my 5th Gen. I went with the Zeon Platinum 10-S I love the wireless remote (except for the battery life sucks) I use mine almost monthly for loading trailers, unloading trailers, pulling stumps, straightening fences, hoisting an elk (or two!!) and just all around general stuff.
On my 3rd Gen I have a XD9I. Both great winches, that never let me down.
If you're going to invest in a tool, don't limit the usage to just in case, emergency type usage only. That's just nuts.
nglayton is offline   Reply With QuoteReply With Quote
Old 05-19-2019, 01:50 PM #7
MAST4R's Avatar
MAST4R's Avatar
Well, yeah, that's exactly what I am saying, buy a winch if you know you will actually use it, don't buy a winch just because it may be used one day.
Since you have had a winch for decades, would you need to ask on a forum what rating is needed if you change vehicle? I don't think so. But a person who needs to ask that question may not need a winch at all.
Old 05-19-2019, 02:16 PM #8
Thanks. I’m not real sure a I need a winch at this time. Just trying to understand the usage and weight ratings for now. My thought was if I did get the warn bumper, to get a winch installed while it’s all apart, but it seems easy enough to add later. I agree probably recover sleds and a comealong will probably new sufficient for now.
Follow up on this, with added weight of a bumper and winch, I hear that will drop the front end a bit. I have the Bilstein 6120, would one upgrade the coil or just put a spacer in, or increase the lift height? My guess is the former.
Old 05-19-2019, 02:34 PM #9
MAST4R's Avatar
MAST4R's Avatar
@nglayton obviously knows his stuff and can help you with usage.
As for the coils, maybe ask that question in the 6112 thread to get more visibility. They do now offer a heavier spring, I am not sure if the 6112 that goes with it is any different. But I am sure you will find someone in the 6112 threads to give you a precise answer. Probably less likely if you wait on a response in this thread.
Old 05-19-2019, 02:47 PM #10
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
If you have room to go up on your clip setting them just do that. If you are already maxed out then you'd need to upgrade to the 650# springs. Lots of guys are doing the upgrade of they are adding bumpers and winches.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 05-19-2019, 03:01 PM #11
comtn4x4's Avatar
comtn4x4 comtn4x4 is online now
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
All the input everyone has provided is great. One big factor for me to "needing" a winch is will you be out alone. If not, you probably don't, recovery straps would be plenty. Come alongs are a great idea but a pill to use. I'd go the recovery board route and don't get too crazy. If you're not intending to get stuck you can generally avoid it.
As far as new coils or re working your suspension goes this is where the worm hole begins. I'd try and plan your mods out to see where you think your going and get it all in order. For me, about a year after I lifted my truck I added a full bumper and winch and my lifted suspension could barely handle it. It only got worse from there, do one thing, adjust another etc. It's fun but can be difficult to get everything dialed in without a big expense all at once.
Bottom line yes you will probably need new coils if you add all that weight to your front end. You can get new coils for your front end. Brand doesn't matter pick what you want. However, as you build the weight up on the front end the dampening of the OEM similar Bilstein coils won't be sufficient to handle the load and those will need replaced also to get the performance back in line.
comtn4x4 is online now   Reply With QuoteReply With Quote
Old 05-19-2019, 03:10 PM #12
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
Imo, a 9K would be perfect for a 4Runner. Harbor Freight for a good price or Warn if you don't care and run a synth line to save weight over a 12K that weighs a lot on the front end.
83Mule is offline   Reply With QuoteReply With Quote
Old 05-19-2019, 03:51 PM #13
jmf_tracy jmf_tracy is offline
jmf_tracy is on a distinguished road
come up Seal Gen2 9.5rsi
Here is the one that i have.
Seal Gen2 9.5rsi
I really like it.
http://www.comeupwinch.com/Archive/_...1612204275.jpg
jmf_tracy is offline   Reply With QuoteReply With Quote
Old 05-19-2019, 04:45 PM #14
nglayton's Avatar
Real Name: Neal
nglayton's Avatar
Real Name: Neal
Also excellent deciding factors, and valid reasons to own a winch, especially the one I bolded about being out alone or even not alone but perhaps, the only one with a winch within a day or several hours drive. (yes, that's me as well)
'Be Prepared' isn't just the boy scout motto, they are words to live by.
Old 05-19-2019, 04:56 PM #15
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice
blksubykid's Avatar
Running 6112s on highest setting (with KDSS) with a C4 lo pro and 10k winch. Ride isn’t too bad but it seems abit more floaty after installing them. Ride height didn’t drop much but I am strongly considering 650lb springs in the future.
blksubykid is offline   Reply With QuoteReply With Quote
bumper , suggestions , vehicle , weight , winch
Static weight ratings? dasrowboat 3rd gen T4Rs 0 08-11-2017 10:40 AM
springs for added front end weight (winch/Bumper) sinks88 5th gen T4Rs 15 03-28-2017 05:44 PM
Winch Ratings sigepbiker Off-Roading 3 03-11-2017 04:19 AM
Winch suggestions Fizban 3rd gen T4Rs 12 11-18-2015 06:23 PM
Weight Distributing Hitch suggestions RPS13 4th Gen T4Rs 18 08-11-2014 12:57 PM
