05-21-2019, 12:16 PM
#16
Real Name: KE0OIC
Real Name: KE0OIC
Originally Posted by Grape Ape
Meh, I paid that much for my Garmin watch and it's worth it considering the other 4 less expensive ones I bought that were subpar.
Which tablet are y'all buying that's $400 that provides topo information, off grid boundries information, satellite messaging and pitch and roll information?
Any GPS-enabled Android tablet that costs $400! Here's one for $150 that would work fine and do all that stuff: https://www.amazon.com/Lenovo-Androi.../dp/B07DPV4RNK
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
05-21-2019, 01:49 PM
#17
$400 gives you all kinds of Android options, even $200-$250 will get you a really good unit. And these will run whatever other apps you want, not just a single use device. $400 could give you a nice tablet, rugged case, ram mount setup and still have cash left over.
05-21-2019, 02:04 PM
#18
As plenty have said, TONS are available... As for the satellite messaging function, it ONLY works if you have your inReach bluetooth paired to it, but at that point ANY phone or tablet w/ bluetooth works with the exact "satellite messaging" functionality.
Additionally, for those saying feeling that Garmin's topo maps are so much better, the Earthmate app, which is what is used for interfacing an Android/iOS device and the inReach satellite device), gives you access to Garmin's mapping (incl. multiple map layers), satellite tracking data, etc, etc.
Essentially Garmin is charging ~$300-500 for combining things that are readily available, and removing some features (such as making it "single use" vs. a multi-use tablet)
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
#19
Real Name: Dave
Real Name: Dave
Garmin Overlander topo map wayfinding
Here's a link the Garmin Overlander, sells for $700:
Garmin Overlander™ | Navigation for Overlanding
How does this compare to the Garmin Oregon 750t GPS for $500 ?
Or the Garmin inReach Explorer+ 2-Way Satellite Communicator, typically $450 can be found on sale for $400 ?
Or the Oregon 700 for $400:
Garmin Oregon(R) 700 | Hiking GPS
The ideas here for using an iPad or android pad and a GPS ap sound great. What about using an iPad2 with these same aps? Has anyone tried an iPad? I have an iPad 2 sitting around.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
05-21-2019, 02:07 PM
#20
Yeah it should be clarified that the Garmin overlander doesnt do satellite messaging alone, that requires you to also have an inreach... the exact same as with iOS/Android
05-21-2019, 02:19 PM
#21
Real Name: KE0OIC
Real Name: KE0OIC
I'm not really clear on if Backcountry Nav is available for iPad. There is a new version that I think is? It's a bit confusing. But Gaia works on iOS and there are other apps available too.
The main attribute you need on your tablet is GPS. You can add it, but it's certainly cleaner if it's built in.
I don't use a tablet myself - I just use my phone. I suppose a bigger display is always better but I have a fairly beefy phone (Galaxy S9) and it's more than adequate. I have all of Colorado cached in Google Maps, and in Backcountry Nav I have several maps that cover all of Colorado plus a bit of New Mexico, Utah and Wyoming.
Past:
05-21-2019, 02:35 PM
#22
Real Name: Dave
Real Name: Dave
Thanks MossJenks,
Yes, if an android does GPS and NAV easier than that's the way to go. There's an android similar to the one you linked above with 4 GB RAM and 64 GB of SSD storage for about $320 on Amazon. See the same link you posted and select the 4GB/64GB 10" model.
05-21-2019, 02:37 PM
#23
I currently use my iPad for navigation when on trips. Gaia is available on iOS as are HEMA and many others. If you don't have a Wifi only iPad you would need to download your routes over Wifi and use a Bluetooth GPS puck. It works great..For a couple of hundred $$ you can probably pick up a used Android flagship tablet (late 2017 or 2018) with external storage and with GPS so that is probably cheaper if you are going for something that is only for the car/trips.
05-21-2019, 02:50 PM
#24
The discussion happening here is 95% of the reason why I bit the bullet and bought the T8. I run offline cached google maps on it for street nav and Gaia with downloaded offline maps for offroad nav. This past weekend on Death Valley back roads it worked flawlessly. I mapped out our route ahead of time and it turned out to be perfect in the park. Downloaded the Gaia topo, NPS visitor map, and satellite with labels and the 3 combined gave me 100% of the info that I needed for the trip on a screen larger than an iPad Mini, and no RAM mounts to mess with or take up space. The GPS has also proven to be extremely accurate over the last couple of months that I've used it.
It has its quirks and I know it's a somewhat controversial topic, but for this type of thing - which is the reason I bought it - I've been 100% happy so far. Since it's pretty much just an Android tablet dressed up to look like a head unit it also obviously works fine with iOverlander, InReach messaging, and anything else I may want to install and it's much cheaper than this Garmin thing.
Edit: Oh, and no worries having or potentially leaving LiPo batteries in a potentially very hot car. That's something I'm always concerned about here in the desert. It's a great way to have a vehicle fire in the summer.
05-22-2019, 03:19 PM
#25
The Oregon/inReach are not in the same class and not comparable to the Overlander.
The Oregon is a 3", 240x400 pixel screen. Tiny compared to the 7" of the Overlander, which has >5 times the screen area of the Oregon 3 (4 in^2 vs 21 in^2).
Oregon can give you turn-by-turn. But it doesn't have voice prompts, tell you what lane to be in, give you a picture of the intersection, etc. Also, you have to buy the $60 map for turn-by-turn - doesn't do it out of the box.
The 750 adds a camera and 2GB of internal memory. Both useless features in my book (it has an SD card slot). The 750t adds a 100k topo basemap. You can get maps just as detailed for free.
The inReach Explorer+ has an even smaller screen, at 2.31" 265x200 pixels (2.6 in^2). It doesn't do turn-by-turn directions. The Explorer+ gives you basic mapping/tracking capabilities and ability to communicate by satellite - it is not an automotive style GPS or even a good hiking GPS.
05-22-2019, 05:25 PM
#26
I've used a tablet with View Ranger and it's just meh. You have to download the detailed maps of the area before going and you are limited in how much you can download. The one trip I used it for was to Ocotillo. I just barely got the whole area in only to find out we were really going to Fish Creek Canyon which I did not download. The GPS was spotty even in open areas.
I guess I could just go Lowrance.
05-22-2019, 05:33 PM
#27
just FYI the Garmin Overlander also requires downloading those maps in advance via wifi
how did you run out of space on your tablet, 256GB micro SD cards are like $50
05-22-2019, 06:07 PM
#28
Thanks for the heads up. I just started looking into it but I agree that they are just looking to cash into the overderping crowd.
I believe it was the limitation of the app, not the tablet because I had a large capacity SD card in it.
05-22-2019, 06:36 PM
#29
Are you sure that the Overlander requires 100% of the topographic map data to be downloaded and not just the extra features?
05-22-2019, 07:30 PM
#30
Real Name: Tom
Real Name: Tom
Funny timing. I just ordered the newly released Galaxy Tab A yesterday, for this exact purpose. 1900x1200 10 inch display, 3GB RAM and 64GB storage expandable to 512GB. It can run 2 apps side by side, so I am hoping to have Gaia (or Wayze) and Torque going at the same time. Not to mention I can bring all of the music, movies and game I (or the wife) could ever need. For $280 it seems like a good value, and when you consider the uses outside the 4Runner, the value goes up even more. I also like the idea of having all of the same apps on my phone as a backup in case of a failure. Coming up with a mounting solution will probably be the worst part. The Overlander seems like a cool concept, but for $700, I just can see the value when you consider all the other options available. I mean my Dobinsons 2" suspension was $810 lol.
2012 Trail (KDSS), Falken Wildpeak AT3W (E) / General AltiMAX Artic's, Level 8 MK6 (0), Pilot stubby, Max Liners
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
