Old 05-21-2019, 06:49 PM #16
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
get a 4th gen!
rwh963 is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 07:32 PM #17
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
Originally Posted by Dillusion View Post
Man diesel's down here must sound different than the ones in Indy.
I for sure wouln't live with it.
No kidding, you and me both. I've had 3 diesels and NONE of them sounded like my 4runner. I'm wondering if the OP knows what a diesel actually sounds like. No offense meant.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 07:45 AM #18
hallcs hallcs is offline
Banned
hallcs will become famous soon enough
Banned
No offense taken, of course the motor sounds nothing like a full on diesel motor but if you stand from a distance a diesel motor has a distinct clatter noise that is unique. If you start up a gen 5 or a gen 6, 4.0L engine and listen carefully you can hear that clatter which sounds slightly similar to the clatter made by a diesel. My 4.0L is a little louder than the 2019 but very close in volume to the other 2016 4.0L I listened to at the dealership. I noticed some of the comments coming in have nothing to do with my question about oil viscosity and if anyone has tried using a thicker oil to quite this noise down, only the debate of my ability to distinguish the sound of a diesel engine. Maybe it's that the people questioning that can't hear from their sisters screaming in their ears during rutting season?
hallcs is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 08:05 AM #19
Bayou_Pro's Avatar
Bayou_Pro's Avatar
On a serious note. I have an engine building background and have worked for Toyota Service for 6 years. I would not recommend changing to a heavier oil, from a bearing clearance standpoint and from a VVTI standpoint. Yeah some people have run 5W20 but this only effects cold start but going to a 5W30 will be a all around thicker oil. On a very tight tolerance engine this will result in higher oil pressure and reduced lubrication to the bearings. Will it hurt something, well I can't answer that but I wouldn't risk it.
You could try a few different oils to see if that would change the sound. It's expensive but you might pick up some Redline 0W20 and give it a try. It's quieter in my CTS-V then Mobil 1. I haven't tried it in the 4Runner yet. About to change the oil and catch a sample to have analysis done to compare Toyota oil to Mobile 1 and then Redline. Just curious TBN numbers between them.
Good luck.
Paul
Old 05-22-2019, 08:24 AM #20
Banned
Banned
Thank you, that's the kind of info I'm looking for. I will stay with the 0w20 as recommended. I think i'll use the Mobil 1 that has been recommended by others. After looking at and listening to other engines mine does not sound much different than other GEN 5 4.0L engines. It is something I need to get used to, I came from a GEN 4 which did not make a sound except fan and exhaust. I was concerned, but now feel better. I did not want to pay the dealership money just to hear it's normal engine noise.
Old 10-09-2019, 08:09 AM #21
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
Good luck.
^^^^^ This^^^^^
Redline is a True group 4 and 5 synthetic base oil with a high moly content added to the additive package. Moly is a fantastic additive and has a plating affect on internal parts, But, needs heat + pressure + TIME to do its thing. Guys on the Ram forum have done some really impressive things reducing engine noise (Hemi Tick) using Redline oils. If you go the Redline route give it 500-1500 miles for the moly to do its thing.
PQIA just tested the Toyota 0w20 and its LOADED with moly, 700+ppm. That's huge!!!! But I'm not sure if its a group 3 base oil (fake synthetic) or a true group 4-5 synthetic base. Either way both look go on paper!
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 04:48 PM #22
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
I've had a few people comment on how noisy the 4.0L is, it has a bit of a clatter for sure at idle compared to other engines, but sounds nothing like my diesel.
Another friend with a 4.0L Tacoma says his sounds very similar, it sounds like they are just noisy motors?
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 05:42 PM #23
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Older technology will do that.
You should hear my 99 Accord DD.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 07:10 PM #24
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
I run 0/20 and 5/20 but you won't hurt it with 10/30 if it's above freezing, It's a lot hotter in my valley than Puerto Rico! The noise is not from metal on metal contact, so you aren't going to silence it with heavier oil. It is a product of the way the engine architecture is laid out.
83Mule is offline   Reply With QuoteReply With Quote
Old 04-19-2020, 10:46 AM #25
VTSR5 VTSR5 is offline
VTSR5 is on a distinguished road
Originally Posted by hallcs View Post
...If you start up a gen 5 or a gen 6, 4.0L engine and listen carefully ...
Hol up...are you from the future? Do they keep the roll-down lift gate window?
'12 SR5 w Milemarker Hydraulic winch on a custom hidden mount.
VTSR5 is offline   Reply With QuoteReply With Quote
Old 04-19-2020, 11:15 AM #26
steelevo steelevo is offline
steelevo is on a distinguished road
Funny that you mention an older Honda Accord. I’ve had all of my Honda/ Acura cars develop valve tick over time. The problem lies with the valves not auto adjusting. A valve lash adjustment every 50k miles would fix the issue.
I never had this issue with my 2.4L Tacoma, but I did have a valve adjustment issue on my 98 Supra. After an adjustment was done, the ticking sound reduced significantly.
I wonder if Toyota is having the same valve adjustment issue on the 4.0L?
steelevo is offline   Reply With QuoteReply With Quote
0w20 , 5w30 , engine , purchased , sr5
2016 trail wheel weight? sf jakey 5th gen T4Rs 7 12-04-2018 08:01 PM
Diesel coming in 2016 SilverRidgeRunner1 5th gen T4Rs 32 09-23-2015 08:19 PM
2016 Sequoia diesel???? MadeInMaine General Discussions 19 08-15-2015 09:39 PM
2016 Tacoma Diesel MarkinWMich General Discussions 14 12-19-2014 10:25 PM
86 22RET diesel sound at low RPMs Black_TurboSR5 Classic T4Rs 14 03-11-2013 10:22 AM
