Old 05-21-2019, 08:49 AM #1
hallcs hallcs is offline
Banned
hallcs will become famous soon enough
Banned
2016 v6 SR5 Dreaded Diesel sound, oil weight question
Had a 2001 2wd V6 SR5, purred like a kitten, was heart broken to put her down. Just Purchased a 2016 2wd V6 SR5 with 70k on her from dealer. I noted a little knock on startup when I purchased but was told the Gen 5 4.0L was noisy machine. Its not getting worse, no knock with load but man this thing sounds like a diesel at the stop light. Feel like im driving a 30 year old farm truck.
My question is has anyone ran like a 5w30 over the recommended 0w20 and if so has it helped in any way with the engine noise. I've been reading and not sure if Toyota is recommending the 0w20 for MPG or if that engine needs that thin of an oil. When I questioned Subaru about my 2017 outback they said 5w30 was fine but may have issues starting it on really cold days.
hallcs is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 08:55 AM #2
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
mine has been like that since i bought it brand new, the rental i drove for a week before deciding to buy was the same
use the oil toyota says to use
jhguth is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 08:56 AM #3
ryan87 ryan87 is offline
ryan87 is on a distinguished road
Cold engine has a small tick but goes away when warmed up. Its normal
2012 TE
ryan87 is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 08:59 AM #4
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
my 2018 has done the same since the day I bought it.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 09:02 AM #5
mustangr2 mustangr2 is offline
mustangr2 will become famous soon enough
I think it pretty common with this motor to sound this way. From what I read from everyone. Mine is similar especially when it’s cold.
mustangr2 is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 10:35 AM #6
kcp1158 kcp1158 is offline
kcp1158 is on a distinguished road
Try switching brands of oil.
kcp1158 is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 10:45 AM #7
Banned
Banned
I'm still on the dealer oil change. Any suggestions? Mobil 1 or do you have a brand you like
Old 05-21-2019, 10:54 AM #8
CavPro's Avatar
CavPro CavPro is offline
CavPro has a spectacular aura about CavPro has a spectacular aura about CavPro has a spectacular aura about
CavPro's Avatar
I've read all the oil change threads which made the job much easier for the first time. I had a slight tick with the OEM oil which I changed at 5.3k. I used the 0w-20 Mobil 1 labeled for toyota, and I expected it to be louder based on what I read here, but it is noticeably quieter than my OEM oil was even with zero miles on it. We'll see as I get miles on this oil change.
I also think this thing is quiet but all my heavy lifting is done with a 7.3
CavPro is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 01:01 PM #9
Tuco S.'s Avatar
Tuco S. Tuco S. is offline
Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about
Tuco S.'s Avatar
I skimmed through the owners manual when I first got mine. I seem to recall a reference to 5w-30 being approved for use in Puerto Rico. I doubt Toyota makes a different engine specifically for Puerto Rico, so I would consider a 5w-30 to be safe to use in any warm climate. You might see a small reduction in fuel economy if you use all 5w-30.
I still have 5 liters of 5w-30 VW 507 spec oil (it's almost a 5w-40) sitting on the shelf. I'll probably add a liter of that for each oci until it's gone, mixed with a quality 0w-20.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
Tuco S. is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 01:18 PM #10
BCMUSA's Avatar
BCMUSA BCMUSA is offline
BCMUSA is on a distinguished road
BCMUSA's Avatar
So I know I will probably get crap for this, but I've had great luck with Lucus products in the past.
Try putting in one of these:
High Mileage Oil Stabilizer
See if it helps at all.
2019 4X4 T4R OR. Nitto Terra Grappler G2
BCMUSA is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 01:35 PM #11
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
I'm honestly not sure why people say its normal if it sounds like a damn diesel.
Mine is pretty quiet. Granted I've only got 4k miles on it but it does not sound anywhere near as loud as some people describe.
I've always used Royal Purple.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 01:41 PM #12
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
Use the correct weight oil, it makes a big difference.
We bought our 5th gen used, dealership (not Toyota) said they just did an oil change on it as they do with all their cars, I drove it a few thousand kms and then did my own oil change, wished I'd done it right away. Engine made better power, and the vvti felt like it worked afterwards! They likely put in bulk barrel 5w30 or whatever they had laying around it it, and it was a dog compared to after with the correct weight oil in it.
If you find it noisy, try a different brand of oil. They are kinda noisy at idle though, compared to a lot of other current gas engines.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 02:10 PM #13
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
The 4.0 may not be a silky smooth dead quiet engine but it should not sound like a diesel at all. My 16 had 41K miles and didn'temake any kind of noise resembling a diesel, a tick yes but not loud. I'm running Toyota 0W20.
BTW run the recommended weight oil!!!
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 06:31 PM #14
Banned
Banned
I took off work early today for a different reason but had time to stop at the local Toyota dealer. I asked the salesman if he would walk out and do a cold start on a used 2016 4runner with me and a new 2019. They BOTH sounded just like mine, raised the hood and it sounds like a diesel engine. I was so relieved. I thought I had bought a defective vehicle.
Old 05-21-2019, 06:43 PM #15
Man diesel's down here must sound different than the ones in Indy.
I for sure wouln't live with it.
2018 TRD OFF ROAD
My Build
0w20 , 5w30 , engine , purchased , sr5
2016 trail wheel weight? sf jakey 5th gen T4Rs 7 12-04-2018 08:01 PM
Diesel coming in 2016 SilverRidgeRunner1 5th gen T4Rs 32 09-23-2015 08:19 PM
2016 Sequoia diesel???? MadeInMaine General Discussions 19 08-15-2015 09:39 PM
2016 Tacoma Diesel MarkinWMich General Discussions 14 12-19-2014 10:25 PM
86 22RET diesel sound at low RPMs Black_TurboSR5 Classic T4Rs 14 03-11-2013 10:22 AM
