07-25-2023, 09:33 AM
#166
Originally Posted by frocio99
Really cool info here. I wonder if anyone has experience with King Shocks? Are they worth the price ?
the king 2" threaded bumps work great on the rear with total chaos fab mounts. it's a long afternoon install especially if you cycle the axle to make sure you set the bumps properly. But, theyre fantastic at damping and controlling bottoming out and keeping the rebound in check.
front duro bumps are still going strong for me. :Shrug:
09-08-2023, 11:04 AM
#167
Just ordered a set, front and rear. 64K miles, very light use, original shocks/springs. Noticed rear sag under light load, front end dive and body roll. Have you seen a noticeable difference since installing them? Thanks!
#168
Blue front and rear
09-20-2023, 02:47 PM
#169
Bump stops with 5100's
Just purchased a set of 5100's front/rear and will keep original springs. 2013 w/ 62k miles, lot's of nose dive and body roll with stock. When the shocks are installed, would there be any benefit from upgraded bump stops? Like sumo springs? Got a great deal on the shocks, the sumo springs are pricey. Thanks in advance
09-20-2023, 02:55 PM
#170
are you planning to keep it stock height or level it at all? I run energy bump stops and am lifted about 2.5". they made the truck feel much more progressive on big bumps rather than jarring as it engaged the bump stops. the feeling of stock vs energy bump stops is like the feeling of hitting a curb vs being on a boat and starting to go up a swell, if that makes sense. without the lift, however, i feel like the truck would just be constantly sitting on the longer bump stop and might negatively affect the ride quality and handling.
2021 MGM 4Runner TRD Off Road, KDSS
Eibach | Falken | CaliRaised | Sherpa| Joe's | Rago | Odyssey | Redarc | Rigd | Waterport | Baja Designs | Diode Dynamics | MaxTrax | Level 8 | OVS | S-Tech | Midland | Dr. KDSS | ARB | JLT | Anzo
2022 MGM Corolla Hatchback 6-speed
2010 Black/Black C63 AMG, 460 whp (I miss this car every day)
09-20-2023, 04:52 PM
#171
Originally Posted by chrisridebike8
are you planning to keep it stock height or leve it at all? I run energy bump stops and am lifted about 2.5". they maked the truck feel much more progressive on big bumps rather than jarring as it engaged the bump stops. the feeling of stock vs energy bumper stops is like the feeling of hitting a curb vs being on a boat and starting to go up a swell, if that makes sense. without the lift, however, i feel like the truck would just be constantly sitting on the longer bump stop and might negatively affect the ride quality and handling.
I am going to keep it at stock height
09-20-2023, 09:34 PM
#172
i'd trim them down a step. otherwise like mentioned, they'll probably be engaged constantly, which will make it feel stiffer.
09-22-2023, 11:54 AM
#173
Originally Posted by 4skrunner
I just put the energy suspension 8.9104g units on my front end. They feel great so far. With my 6112s at 2” in the front and these bumps, I can blast through dips and over speed bumps and it truly soaks it all up. My rear end on the other hand… does not keep up. With stock shocks and bumps.
Hi All. I’ve been reading this forum and I would like to put on some ES bump Stops on my 4Runner. I have this same set up, 6112 with a 2” lift on a 5th gen. I’m looking at ES web site but I don’t see the 8.910g. Can someone tell me what is the correct part number for the 5th gen? The 9.9135 looks the closest but I’m not sure if this is too tall. Thanks
Energy Suspension
2016 TRD Pro Quicksand
09-22-2023, 11:49 PM
#174
Energy Suspension
It is 8.9104r (r is for red, g is for grey/black i think).
09-23-2023, 03:47 AM
#175
I got that but when I go to the website I don’t see that number. It goes from 3.9… to 9.9….
Energy Suspension
I guess I’ll give them a call on Monday.
09-24-2023, 03:21 PM
#176
Energy Suspension
I’ll look for the amazon link that me n my buddies purchased from later this evening. You want red or blac?
09-25-2023, 12:11 AM
#177
Black if available but red is ok too.
Thanks
09-25-2023, 03:52 AM
#178
Thanks
Amazon.com
09-25-2023, 05:53 PM
#179
Thank you very much. For clarification I see these are for the rear but I assume this is what people are using on the front of their 4Runners? If so what do you recommend for the back?
09-25-2023, 08:39 PM
#180
Yeah we all run em in the front, even the hardware fits and does pretty dang good performance so good that i have no intention of ever changing them out.
whats your budget on the rear ?
I'm running icon hydrobumps in the rear, and had timbren's in the past (still like them). They both work well but they are so expensive.
My buddy is running lexus take offs (not sure what it is) and airbags and likes that combo. Honestly, i probably go that route if I had to do it all again.
When it comes to bumpstops i don't believe that there is some magical pixie dust that makes one piece of rubber better than someone else.
