09-20-2021, 01:27 AM
#121
Originally Posted by mrblah
You sold me on dem hydrobumps...
going to run them in conjunction with the timbrens.
thanks for the advice broski.
interesting to run them with the timbrens. curious how it feels.
09-20-2021, 05:27 AM
#122
lol.. hydrobumps still sounds nicer than hydraulic bumpstops..
hydrabumps just doesn't have the same ring to it
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
09-20-2021, 05:29 AM
#123
most of the time.. nothing. Hitting that speed bump way faster than you should is the 'aha' moment
09-20-2021, 09:45 AM
#124
i love my king bump stops. but with timbrens seems odd, since they engage so early. Maybe redundant? or like youll never make full use of a hydraulic bump stop.
09-20-2021, 09:46 AM
#125
haaha...note my signature.
09-20-2021, 01:15 PM
#126
I hear ya. It sounds really odd..lol.
It's mainly for the redundancy, and to experiment which is better. I got rid of my airbags when I upgraded my springs, and my OEM spring/rubber cone isolators got modified (aka destroyed in the process). I figured toyota engineered the bump stop and spring isolator to work in tandem, and I didn't want it to replace the factory spring isolator with factory again.
I do love my timbrens, but they do have a tendency to rebound more than I like when going over moguls. Usually, when my vehicle is empty (oversprung) and going over moguls. You get this weird isolating affect, as the driver and passenger side bottom out at different rates and times, enough to unsettle the suspension and the vehicle. I know the hydrobumps will fix that by itself...but since i have both..i wanna experiment..lol.
I figure i'll try it with both timbrens and icons. Have timbrens soak up the beginning of bottoming out, and the icon acting like a jounce to stop that weird isolation. IF that doesn't work, i gotta get my kings revalved..and I really don't want to do that.
Also, having both, i can test which one separately and/or combined. I'll get my money's worth either way if i decide to sell one or the other.
cheers.
09-20-2021, 01:33 PM
#127
Not gonna seem odd when you roll up on that g-out you didn't see coming at 50mph!
Many dez vehicles have bump zones in their bypasses, but also run air bumps. Can't have enough oh $hit compression control when running at speed.
09-20-2021, 05:20 PM
#128
yeah true. lol
09-20-2021, 06:15 PM
#129
Real Name: Kirk
Real Name: Kirk
Wheeler's and....?
Currently running the Wheelers superbumps up front. A more linear change from the red silicone ones...
Will probably go with the Wheelers rear units once the rear towing suspension is added...or perhaps Timbren for the rear...Will make that decision once I can measure final spring height.
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
09-21-2021, 10:13 AM
#130
It seems having both would stack well if you have a heavy tail end.
I tell you though, as anyone that has switched out can attest, factory bump stops just plain suck. The biggest difference, I switched out the fronts with durobumps a quite few years years ago, night and day.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
09-21-2021, 10:40 AM
#131
I've tried to search and haven't found the answer: are upgraded bump stops needed only for those with aftermarket suspension, or do they also provide a more progressive "stop" for those of us w/ stock suspension?
2019 TRD OR | Front Runner rack | Shrockworks sliders
Gone
2015 Trail
2000 SR5
09-21-2021, 11:31 AM
#132
I sound like a broken record telling people this so often, bumpstops make a night and day difference in how smooth and controlled suspension feels, for everyone not just off roaders.
See above. Even going through dips and if you ever tow or load the vehicle up with weight, such a smoother experience when you compress the suspension down. Durobumps are fairly inexpensive and great customer service.
Sumosprings also seem like a good product. Will be trying those out for my F150 at some point.
09-21-2021, 03:39 PM
#133
It may depend on the bump stop. Some have specific disclaimers recommending use only with a suspension lift, otherwise the bump stop will hit sooner and limit up travel.
Sent from my Pixel 4 XL using Tapatalk
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
09-21-2021, 04:12 PM
#134
yes, potholes, dips, speed bumps, steep driveways, and intersections with drainage ditches..... will bottom out your suspension if you don't slow down, and will happen way more frequently with those still rocking OEM suspension.
Everyone can benefit with aftermarket bump stops. If you just pop your head behind your front wheel or right above your rear axle..you will notice a nice, visible, polished area on your paint (either on front LCA or rear axle)... that means you are smacking your bump stops in your daily commute..which is normal by the way. It also means, you will benefit from a upgrade too. OEM bump stops are so bad, you might as well pretend they aren't there.
Bump stops is one of the best upgrades I have ever done, thats why i'm moving up to air bumps, hydrobumps, grease bumps (LOL). No more "OOOH SHIEET" moments as I fly across a intersection with massive drainage ditches, or as other posters mentioned, big giant holes that like to suddenly appear when you mobbing it in the desert.
Bump stops range from dirt cheap to stupid expensive, but even the dirt cheap ones are a night and day improvement over OEM.
09-21-2021, 04:23 PM
#135
With those durobumps, did you have to mess with the bump stop extensions that came with your TC LCA?
