Old 08-11-2019, 02:49 PM #31
Cbaker1911 Cbaker1911 is offline
Real Name: Chase C Baker
Cbaker1911 is on a distinguished road
Durobumps
These bumps are amazing and provide more control for those hard hits and even controlled wheeling. They were a huge upgrade to my rig and I am running the 3'' lift option from them.
02 4Runner SR5 Locker 4x4 - King Suspension Coil Overs - Icon UCA -DuroBumps - Bilstein5100 1.5-3" Rear Shocks - OME 3" Lift Springs - EimKeith PCK - Nolathane Bushings all around
Cbaker1911 is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 02:56 PM #32
SnowYeti's Avatar
SnowYeti SnowYeti is offline
SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough
SnowYeti's Avatar
Durobump rear 0-2” bump stop update
I received this last week, waiting to install these with my lift (1” Eibach)
Yessir, I am finishing up the tooling needed to release my first batch. Its taken much longer than expected due to life…
I appreciate you being patient and choosing Durobumps for your 4runner
Curtis Glenn,
Toyotabumpstops.com
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
SnowYeti is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 03:10 PM #33
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
I have 2.25"/2.0" lift with Durobumps on the front and Toyotec extensions plus stock bumps in the rear. I do need to do more with the rear still.
They were great until I upgraded my LCA's, I have fendered out a couple of times, more so because I didn't have through bolts long enough to go through the TC supplied extension and the Durobump. I found a pair of matching bolts in my toyota box and put them on last week. I have yet to get out and test.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 12:26 PM #34
headpaneer's Avatar
headpaneer headpaneer is offline
headpaneer will become famous soon enough
headpaneer's Avatar
Curtis Glenn,
Toyotabumpstops.com
That's great. Been waiting for these, also. Thanks for posting!
'16 Magnetic Grey SR5 Premium - FN 6-Shooters, 265 KO2s, TRD CAI, various other do-dads
So happy to be back in a 4Runner again! Previous Toys - '87, '89 and '93 4x2 Pick Ups, '03 4Runner, '08 Sequoia
headpaneer is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 08:17 AM #35
Unretired Unretired is offline
Real Name: Terry
Unretired will become famous soon enough Unretired will become famous soon enough
Real Name: Terry
Front Bump Stops Need BIG Wrench
Installed DuroBumps yesterday.
Coated threads with PB Blaster and went at it 30 minutes later.
Rears were easy.
Fronts would have been easy if I had the right tool.
Little Pipe Wrench and "normal" Channel Locks wouldn't cut it.
I broke a small strap wrench.
Ended up running to Lowes for a big pipe wrench and it was easy.
Front bumps are in the picture below and you'll see how you have to get the wrench on the metal-octagon flange
2016 SR5 - Wildpeak A/T3W 265/70R17SL or BFG K02 C Load 285/70R17; RSG Sliders; LFD Crossbars, Skid Plates & Hybrid Bumper; RCI Skids on Rear Diff, Lower Links & Shock Mounts; Engo SR10S Winch; Dobinson 700/701 IMS with 314/327 Coils +2.25" front +2.5" rear; Goat Armor; Redarc Brake Controller; Camping Hatch Mod; DIY Drawers & Sleeping Platform; Cheap 10" Light Bars in Grill; Front/Rear Camera Mod with Nav Input; Simple Nav/Comms - Garmin inReach Mini, iPad & Motorola FRS.
Unretired is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 05:51 PM #36
Moreno Moreno is offline
Moreno will become famous soon enough Moreno will become famous soon enough
This and that. All in all spent $140.00
Moreno is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 10:01 PM #37
Blueberry faygo Blueberry faygo is offline
Blueberry faygo is on a distinguished road
Are those the Lexus GX460 bumps? Are they direct bolt on?
Blueberry faygo is offline   Reply With QuoteReply With Quote
Old 06-26-2020, 08:37 AM #38
4runnerDFW1 4runnerDFW1 is offline
4runnerDFW1 is on a distinguished road
Running Duro bumps ordered direct.
No back plate so the product looks potentially less durable than oem. Specs wise they bolt up perfectly and are correct height. So far no issue riding smooth.
4runnerDFW1 is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 05:35 PM #39
Yes sir!!!!
Sent from my SM-G988U using Tapatalk
Old 06-28-2020, 10:29 AM #40
Yes sir!!!!
Cool thanks for following up, quick question. Are your kings extended travel front and rear? I have Kings also waiting to go on. I think we’ll be running a similar set up how much lift did you do front and rear? How’s the ride? And also what Uca did u go with? I have the jba and I’m hoping this is going to be a good set up. Just trying to find a good shop that’s not trying to price gouge. I’m getting quotes for over 1k to install which I think is ridiculous
Old 06-28-2020, 01:15 PM #41
I have kings extended all around. I have dobinson rear spring, cant remember which one. And i also do have the JBA HD.
Old 06-28-2020, 04:56 PM #42
Yes we’ll be running the same setup except I have the wheelers t13 rear coils.
How much lift did you do in the front? And can you give me an opinion on the over all ride post lift?
Old 07-01-2020, 01:22 AM #43
TRDHULK's Avatar
TRDHULK TRDHULK is offline
TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold
TRDHULK's Avatar
I got the fronts off Amazon for $40
And I got Toytec for the rear
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit the LinkTree on my Instagram for discounts on Rock Sliders,
Molle Panels, Ark Splash guards, Canvasback liners, Insta360 Cameras,
Camera Mounts, LED Bulbs, RRW Wheels, Power Washers, and more!
TRDHULK is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 01:57 AM #44
perf0rmance perf0rmance is offline
perf0rmance will become famous soon enough
Originally Posted by MTN4RNR View Post
Really happy with Durobump all around, here. Ride on and off-road has improved greatly over big bumps! I wouldn't hesitate.
Got an idea as to how tall the rears are?
perf0rmance is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 02:05 AM #45
Nice.. I'm looking to replicate this setup. Same question... do you have a measurement of how tall they are? Have you come into contact with them with your kings?
EDIT: How tall the rear bumps are.
air , bump , purchasing , running , stops
Energy Suspension 8.9104R rear bump stops in place of front bump stops Akkording 5th gen T4Rs 66 01-16-2024 12:10 AM
Bump stops crashman 4th Gen T4Rs 24 05-16-2018 09:55 AM
Bump stops lhsoulrebel 3rd gen T4Rs 9 08-14-2013 11:36 PM
Bump Stops for 94 4x4 rrands1 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-15-2011 11:09 PM
Do I need new bump stops or UCA's masson74 3rd gen T4Rs 11 09-22-2011 11:26 PM
