Old 08-05-2020, 12:27 AM #46
avo1789's Avatar
avo1789 avo1789 is offline
avo1789 is on a distinguished road
avo1789's Avatar
Had them on for a week and they feel great! I ordered the 1.5" rears that are meant for stock to mild lift. Running them with Kings set to 0 preload and stock rear springs.
Sent from my SM-N960U using Tapatalk
avo1789 is offline   Reply With QuoteReply With Quote
Old 09-25-2020, 04:16 PM #47
JsinLegacy's Avatar
JsinLegacy JsinLegacy is offline
JsinLegacy will become famous soon enough
JsinLegacy's Avatar
Pardon my ignorance but is it necessary to upgrade these with a 3" lift? I know it can't hurt to do it but if its not necessary then I wouldn't mind waiting a bit and use the money for another item.
JsinLegacy is offline   Reply With QuoteReply With Quote
Old 09-25-2020, 04:28 PM #48
bbinkley's Avatar
bbinkley bbinkley is offline
bbinkley is on a distinguished road
bbinkley's Avatar
Originally Posted by The_Green_Wang View Post
Awesome guys! Thank you. Was thinking of getting the wheelers but wasnt sure. I'll definitely look into energy suspension. Running 3inches of lift with stock bumps stops and well...they need to go. My rear is especially stiff when going over speed bumps etc
Sent from my SM-N950U using Tapatalk
I threw on the Timbren bump stops a few months back and aside from the fronts being difficult to take off initially I really like the way they feel on and off-road. Just enough squish while maintaining stability. They need a few more trips on them but so far I love them!
bbinkley is offline   Reply With QuoteReply With Quote
Old 09-27-2020, 10:42 AM #49
bearflorian bearflorian is offline
bearflorian is on a distinguished road
Which Gen 4Runner do you have? Hoping to find shorter rears for my 5th gen but website only shows the ones for 2”+ lift.
Thanks
bearflorian is offline   Reply With QuoteReply With Quote
Old 09-27-2020, 11:20 AM #50
comtn4x4's Avatar
comtn4x4 comtn4x4 is online now
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Thanks
Check out these from Sonoran steel. They're a modified Daystar bump stop
Competition Rear Bump Stops [5thGenRearBumpStops] - $140.05 : Sonoran Steel Fabrication LLC, Toyota Truck Parts
comtn4x4 is online now   Reply With QuoteReply With Quote
Old 09-27-2020, 02:14 PM #51
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Originally Posted by comtn4x4 View Post
Been running these in the rear and durobumps in the front. Pretty pleased with the results!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 09-27-2020, 04:42 PM #52
comtn4x4's Avatar
comtn4x4's Avatar
That's what I run also. Excellent setup. Keeps close to stock up travel in the rear.
Old 09-27-2020, 09:55 PM #53
total chaos mounts, king hydraulic threaded body 2" bumps. back end is glorious in high speed dips and small "jumps"
Old 09-28-2020, 12:51 PM #54
avo1789's Avatar
avo1789's Avatar
@bearflorian I'm running these on a 5th gen. You can check out SDHQ they have the short version for the rears.
Since the last post I have upgraded my rear sprjngs to the Bilstein B12's and the ride feels even better on and off road.
Old 09-28-2020, 03:29 PM #55
Thanks, I see them now on the SDHQ website but not on toyotabumbstops.com.
And thank you to the others that suggested the Sonnoran Steel option, I will look into them.
Bear
Old 09-29-2020, 07:21 PM #56
what are you guys recommending for the front? currently just running 6112's but when they blow Kings will be installed. Plasticguy bumps? i refuse to lose up travel/change the shock valving by having the bumps in constant contact so timbrens are a no go.
Old 09-29-2020, 10:29 PM #57
comtn4x4's Avatar
comtn4x4's Avatar
Duro Bumps claim to be stock length is my understanding.
I think that's what you're wanting? I'm not familiar with any other products that are.
I think I have my stock bumps lying around, I'd have to compare to be sure
Old 09-29-2020, 10:36 PM #58
Here is a photo of the stock vs durobumps. Though the durobumps are taller, they are designed (as claimed) to compress to stock height. I found I haven't lost any noticeable loss in up travel after installing them. Also take a look at the screen still I captured from a video demonstrating the durobumps! see video here around post 30 seconds --> @plastics_guy bumpstops - YouTube
What bump stops are you running?-compression-jpg
Old 09-29-2020, 10:43 PM #59
comtn4x4's Avatar
comtn4x4's Avatar
Thanks for chiming in @SpeedyKevin . Saved me from digging through my whole garage. I have made the same observations. Uptravel is the same as OEM however the stop is much softer
Old 09-30-2020, 09:30 AM #60
cool that's what i was expecting from those ones. a nice progressive bump instead of the rock hard OEM stop lol.
Dirt King Fabrication has a hydraulic bump stop kit for the front end on a stock width setup but they won't be releasing it for a while as they have bigger products they want to get to market first :/
air , bump , purchasing , running , stops
Energy Suspension 8.9104R rear bump stops in place of front bump stops Akkording 5th gen T4Rs 66 01-16-2024 12:10 AM
Bump stops crashman 4th Gen T4Rs 24 05-16-2018 09:55 AM
Bump stops lhsoulrebel 3rd gen T4Rs 9 08-14-2013 11:36 PM
Bump Stops for 94 4x4 rrands1 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-15-2011 11:09 PM
Do I need new bump stops or UCA's masson74 3rd gen T4Rs 11 09-22-2011 11:26 PM
