Old 10-05-2020, 04:33 PM #61
TRUSTYAXE's Avatar
TRUSTYAXE TRUSTYAXE is offline
TRUSTYAXE will become famous soon enough TRUSTYAXE will become famous soon enough
TRUSTYAXE's Avatar
Originally Posted by Bayou_Pro View Post
Yeah I didn't know if there was a nut I had to get to in there or if they just threaded in. Got lazy and didn't go back and do it. Might throw then on tomorrow if I have time. Thanks.
I pulled the trigger on the energy suspension bump stops for the front. I just wanted to be sure these are correct as they say rear, and see how they are holding up?
What bump stops are you running?-ee457712-efb6-4db4-aad5-63efb2ab8062-jpg
2015 TRDPRO SUPER WHITE ~ ROOF RACK DELETE ~ REAR SEAT DELETE ~ LED ANYTIME FOGS ~ DRL DISABLE ~ DOMETIC CFX-28 ~ BORLA CAT BACK ~ SPRINT BOOSTER V2 ~ aFe MOMENTUM GT INTAKE ~ OTHER JUNK N STUFF
TRUSTYAXE is offline   Reply With QuoteReply With Quote
Old 10-05-2020, 04:47 PM #62
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
just installed these exact ones on my car over the weekend. i did not jack the car up and getting enough clearance to screw them in with an allen wrench was a huge PITA. ended up cutting down a wrench with a dremel to make it all work. definitely an upgrade over stock though
tm965 is offline   Reply With QuoteReply With Quote
Old 10-05-2020, 06:05 PM #63
TRUSTYAXE's Avatar
TRUSTYAXE's Avatar
Ok thanks for the sanity check. It does look like I can get away with not busting out the jack. They managed to forget my mounting bolts even though the bag was sealed, I’ll pick some up tomorrow.
What bump stops are you running?-5e62a1b6-3766-4d65-bb78-8aa4ca71ef55-jpg
Old 10-05-2020, 08:53 PM #64
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
Have handy a pipe wrench or a channel lock wrench to take the stock BS off. Fyi the energy suspension screws used allen bolts, so a socket with matching allen head might be handy as well depending on the option of the bolt you choose. Just keep in mind your tool or socket used has to clear the ID of the bushing. A single L shaped allen key can be too short on one end to use and the long end can be too long, it might make contact with the LCA so that is why your T4R brothers lift theirs for the clearance to install these bump stops.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 10-05-2020, 09:23 PM #65
TRUSTYAXE's Avatar
TRUSTYAXE's Avatar
Originally Posted by Akkording View Post
Have handy a pipe wrench or a channel lock wrench to take the stock BS off. Fyi the energy suspension screws used allen bolts, so a socket with matching allen head might be handy as well depending on the option of the bolt you choose. Just keep in mind your tool or socket used has to clear the ID of the bushing. A single L shaped allen key can be short on one end to use and the long end can be too long and will make contact with the LCA so that is why your T4R brothers lift theirs for installing these bump stops.
Thanks I appreciate the tips, I’ll bust out the jack if I can’t sneak an Allen socket in there. I’m thinking these channel locks will suffice.
What bump stops are you running?-e30f78dc-74af-4534-8724-88f81f38bced-jpg
Old 10-05-2020, 09:50 PM #66
Akkording's Avatar
Akkording's Avatar
Right On
Old 10-06-2020, 08:33 AM #67
Unless you have the perfect height wrench it will likely just be easier for you to jack it up. They also forgot my bolts as well.
Old 10-06-2020, 01:51 PM #68
Anand Anand is offline
Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough
To add to the trend, I've been running the DuroBumps since early last year, no complaints
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
Anand is offline   Reply With QuoteReply With Quote
Old 10-16-2020, 02:54 PM #69
perf0rmance perf0rmance is offline
perf0rmance will become famous soon enough
Best bang for buck below
Fronts:
Energy suspension bushings
Rear Bump Stops - Toyota 4Runner - 8.9104
Rears:
OEM toyota bumpstops
48306-60201 & 48036-60011
*** you need one for each side***
I made the mistake and ordered 2 of one side (rear bumps), not realizing they're side specific. I don't believe anyone had clearly noted this so I'll save you guys the expense lol
perf0rmance is offline   Reply With QuoteReply With Quote
Old 10-16-2020, 03:14 PM #70
TRUSTYAXE's Avatar
TRUSTYAXE's Avatar
Originally Posted by perf0rmance View Post
Rears:
Are these taller than the stock rears?
Old 10-16-2020, 03:23 PM #71
Yup, hence the "upgrade".
Old 10-19-2020, 08:20 AM #72
fungusbrain fungusbrain is offline
Real Name: T.J.
fungusbrain is on a distinguished road
Real Name: T.J.
I just installed Timbren Active Off-Road Bumpstops front and rear.
I have Kings all around.
I measure 3.5" between the rear bump stops and the axle now. Do I need some sort of spacer to get it closer to the axle?
It doesn't seem like they would engage because it looks like my shocks are compressing 3.5" max. At least that's what the "clean area" on the shock shaft measured.
2016 Limited 4x4 Magnetic Gray
fungusbrain is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 09:51 AM #73
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Originally Posted by SnowYeti View Post
I contacted DuroBumps and they have tooled a shorter version for the rear, for those of us doing 0”-2” lifts. Not up on their sight yet, I am going to email him back today to find out the status. I will post the reply. I am dong a 1” lift in back with Eibach springs, so these would be perfect
Email sent.
Reading through his original reply he does say this new version will be perfect for a 1” lift.
The longer ones most certainly do not work with an Eibach pro lift kit. I have to see about returning or exchanging mine.
delloro is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 02:37 PM #74
How tall are the rear Timbren bumpstops? I've got the Lexus bumps installed.
Which Kings do you have? I've got standard length (OEM series).
Which rear springs are you running too? I'm on Icon 2" springs
Old 10-20-2020, 03:12 AM #75
Real Name: T.J.
Real Name: T.J.
The Timbren's are a little over 5" tall.
I have the remote reservoir Kings in the back with the ToyTec 2.0 Superflex springs. Should be around 2"-2.5" Lift in back.
air , bump , purchasing , running , stops
Energy Suspension 8.9104R rear bump stops in place of front bump stops Akkording 5th gen T4Rs 66 01-16-2024 12:10 AM
Bump stops crashman 4th Gen T4Rs 24 05-16-2018 09:55 AM
Bump stops lhsoulrebel 3rd gen T4Rs 9 08-14-2013 11:36 PM
Bump Stops for 94 4x4 rrands1 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-15-2011 11:09 PM
Do I need new bump stops or UCA's masson74 3rd gen T4Rs 11 09-22-2011 11:26 PM
