Old 11-13-2020, 05:01 PM #106
jrandom's Avatar
jrandom jrandom is offline
jrandom is a glorious beacon of light jrandom is a glorious beacon of light jrandom is a glorious beacon of light jrandom is a glorious beacon of light jrandom is a glorious beacon of light jrandom is a glorious beacon of light
jrandom's Avatar
Originally Posted by DEUS-MACH1NA View Post
instagram.com/timbren_industries
that fine but insta' fluff and what @comtn4x4 is asking, at least in my mind are a little different.
I checked their feed and saw a couple of Toyotas, not much in the way of actual suspension snaps (seriously like >5% of the posts are and that's it) but more like poser/ing truck porn that you see everywhere ad nauseam and one good example of 4th gen "2-bolt install". The more specific product/model info is in line with what people that actually research products prefer to see
Just cus joe on the 'gram uses it doesn't really mean a thing to the "other 50%" you usually have to know if joe races trucks or is just some "influencer" getting free products for promos.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 11-13-2020, 05:13 PM #107
jrandom's Avatar
jrandom's Avatar
Originally Posted by timbren-industries View Post
Our bump stops are designed to hit square and reduce the impact of the bump. Let us know if you have any other questions!
Thanks for the response! Forgive me if this seems like a silly question, so is there a good average distance you should have from the bottom of the stop to the top of the dif? I mean, there must be an optimal distance. It seems that too much or too little distance and you don't get the full "active" benefit, right? Understanding of course that there other factors involved but most of this generation truck lifts range from 0-3" so using those as baseline is pretty acceptable IMO, only outliers are lifting in the +4" range.
Like this FJ has what looks like a 2" spacer, of course we have no idea what lift they are running apart from the fact they stuffed 37's on it (outlier )
Login • Instagram
2013 TE w/ KDSS Nav
Old 11-13-2020, 05:15 PM #108
anomalous's Avatar
anomalous anomalous is offline
anomalous will become famous soon enough
anomalous's Avatar
Originally Posted by NotaTRD View Post
I installed the energy suspension bump stops in the front a few days ago. Only able to do street testing for now, but I did take some sections of the road at a speed that I knew would cause contact between the bump stops and LCAs and things felt relatively normal, no harsh bottom out like I would have expected with the OE stops. Feels more stable taking turns now as well.
I took it on a few quick off road sessions over the past weekend, and it does feel like the compressions are more controlled now. There's a section of drop off that used to feel more sudden, where now even though I went over a lot quicker than I usually do felt more squishy/controlled.
I'm trying to understand if this is a job that a better suspension could be doing. Wouldn't better suspension be able to give the same feel of a controlled stop ? is adding progressive bump stops a way to get the feeling of a better suspension ?
∙ Toyota Racing Development ∙ Magnuson Superchargers ∙ Underdog Racing Development ∙ Baja Designs ∙ Bilstein ∙ Dirt King Fabrication ∙ Eibach ∙ FN Wheels ∙ Toyo Tires ∙ PIAA ∙ Whiteline ∙ Focal ∙ Directed Electronics ∙ Stinger ∙
anomalous is offline   Reply With QuoteReply With Quote
Old 11-13-2020, 07:00 PM #109
perf0rmance perf0rmance is offline
perf0rmance is on a distinguished road
Anyone looking for a pair of toyota rears?
I ordered 2 of one side by mistake. Since I needed the other side still, I ordered 2 so I'd have matching sets.
perf0rmance is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 01:31 PM #110
timbren-industries's Avatar
timbren-industries timbren-industries is offline
timbren-industries is on a distinguished road
Originally Posted by comtn4x4 View Post
I bet some photos of your 4Runner products would be greatly appreciated. If you have a side by side with OEM I think that would give everyone some good perspective also
Here is a good side by side you were looking for!
What bump stops are you running?-125496438_417748992580120_4646344860957818180_n-jpg
timbren-industries is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 01:37 PM #111
Login Instagram
These are great questions! Roughly there is 4-6 inches between the bottom of the stop to the top of the dif. Where the active comes in is when it begins to squish, taking strain off the springs and dampening the bump. Our bumps have enough flex in them to go almost flat. OEM bumps have no squish and are much higher putting more strain on your suspension and spring setup. Does this give you the answers to your questions?
Old 11-16-2020, 01:47 PM #112
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is just really nice comtn4x4 is just really nice comtn4x4 is just really nice comtn4x4 is just really nice comtn4x4 is just really nice
comtn4x4's Avatar
Thanks for the picture and your replies. I think this will really help everyone make good decisions.
Can you speak to "extended" bump stops? There are lots of opinions on this topic. Is extension a necessity? Would you consider your bump stops extended with the additional active (compression) aspect?
'13 TE w/ KDSS, 4:56 Gears, Radflo 2.5" front and rear. Eibach 700# Front, Dobinson C59-701V Rear, Sonoran Steel KDSS Trac Bar, BlackGate Customs KDSS Blocks. Fuel Revolver Rims 17x9 +1 mm 5" Backspace, Cooper ST Maxx 285/75r17, Hefty Fabworks Aluminum Front Bumper and Full Skids, C4 Fab Dual Swingout Rear Bumper, OPOR Sliders
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 06:46 PM #113
ForwardFlight ForwardFlight is offline
ForwardFlight is on a distinguished road
shot you a pm
ForwardFlight is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 07:36 PM #114
Originally Posted by ForwardFlight View Post
shot you a pm
replied
Old 11-17-2020, 11:55 AM #115
You can interpret an extended bump a few different ways. The sheer size of our bump stops could be considered as extended especially with how short OEM bumps are anything bigger could be considered extended. As long as they perform the way they are intended and actually make a difference then that's all you need. Ours definitely cover a large amount of space for a number of different applications and suspension setups.
air , bump , purchasing , running , stops
Energy Suspension 8.9104R rear bump stops in place of front bump stops Akkording 5th gen T4Rs 51 10-08-2020 05:59 PM
Bump stops crashman 4th Gen T4Rs 24 05-16-2018 09:55 AM
Bump stops lhsoulrebel 3rd gen T4Rs 9 08-14-2013 11:36 PM
Bump Stops for 94 4x4 rrands1 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-15-2011 11:09 PM
Do I need new bump stops or UCA's masson74 3rd gen T4Rs 11 09-22-2011 11:26 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
