Old 11-13-2019, 04:23 AM #16
T4R03 T4R03 is offline
T4R03 is on a distinguished road
Originally Posted by matoolie View Post
As long as the camber and toe end cam bolts/plates are not moving you should be OK. Mine would pop with the exact scenarios you described and I only have 45k on my truck, so I would think your bushings should be OK. I am sure the bushing movement causing the pop is less than you think and sounds like it is. I marked all my alignment plates before I torqued my bolts and nothing moved.
Sorry to reply to a older thread but I did have a question for ya since it seems like I have the same problem and was only able to torque down the bolts closest to the rear of the vehicle. Didn't help that it's 15 degrees out but would it be a problem you think if I drove like this for two more weeks? I got an alignment about 4 months ago and the popping started yesterday after getting my A/T tires installed. They're pretty aggressive and heavy.
T4R03 is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 05:07 PM #17
matoolie's Avatar
matoolie matoolie is offline
matoolie has a spectacular aura about matoolie has a spectacular aura about
matoolie's Avatar
I would think it will be OK. The noises are inappropriate slipping within the bushings (metal washers, sleeves, brackets) instead of just the rubber, which is designed to flex and twist....quietly.
As long as the noise is just occasionally and random and not over every bump or movement of the suspension should be OK.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
matoolie is offline   Reply With QuoteReply With Quote
front , left , lift , miles , springs
Help with suspension sound after SS 1.2 Lift manualdr5 3rd gen T4Rs 9 12-14-2018 09:45 AM
V6 MPG after lift -- Does this sound right? Cornelius 4th Gen T4Rs 15 08-26-2014 11:24 AM
3" Lift for $600 sound good? spoiler900 3rd gen T4Rs 11 06-15-2013 02:37 PM
Got a quote on installing a 2.5" Daystar lift today...this sound about right? Duck'n 4th Gen T4Rs 13 06-20-2012 05:13 PM
4Runsports Lift and Sound upgrades!!! 4runsport 3rd gen T4Rs 18 05-24-2010 06:57 PM
