Originally Posted by Humble Leader
looks like valve cover gaskets need to be replaced. valve covers only leak (I believe) when the engine is on and when oil is moving around so you likely won't notice any drips. I had the dealer do mine with the spark plug gaskets and cam shaft seals as well. might as well do them all at the same time
in terms of worried - it doesn't look like you've lost enough oil to be causing engine damage. but still fix it
Valve cover is actually above the leak. This is cam tower from what I have read. Not an easy fix.
