05-24-2019, 02:23 PM
Cargo Cover
I have a 2018 4Runner Limited with the 3rd row option. I'm searching for a cargo cover and found an OEM one on eBay but the description says it is not suitable for 4Runners with a 3rd row. Anyone know if this is the case for all 4Runners where if you have a 3rd row then the cargo cover won't work? Or maybe it's just that particular listing?
Are there any aftermarket covers that someone can recommend?
Thanks in advance.
05-24-2019, 03:50 PM
i would say yes it should work. here's a vid of a SR5 with third row and cargo cover. perhaps the seller is saying you cant use the cover while the third row seats are in use
fast forward to 5:25
Third row seats w/ cargo cover
Thanks in advance.
05-24-2019, 04:32 PM
Have a third row and mine came with one. Not sure if there are different sizes. I never use it though because no place to put it when the third row is up.
05-24-2019, 09:28 PM
Thanks for the information and the link! Yeah, that actually makes a lot of sense.
Great, thank you for confirming!
05-24-2019, 11:06 PM
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
06-07-2019, 06:55 PM
06-08-2019, 10:10 AM
Do you make a cover that extends all the way to the 2nd row seats?
Seems like the factory cover leaves a gap there for the seats to recline.
Originally Posted by Raingler_Nets
We build a couple types and can also custom if you have something (like hybrid cargo net, cover, MOLLE comparable etc)
06-10-2019, 03:20 PM
We have done an extended version that ran down to the floor before as a custom piece. Let me know if you'd be interested in one, we can do.
06-11-2019, 11:36 PM
Thanks, I plan to get something ordered up shortly (probably a cargo net but we'll see).
____________
'97 SR5 (sold)
'16 LE
06-18-2019, 04:46 PM
This is what I did to extend my cargo cover to the 2nd row. I no longer Velcro it to the 2nd row seat but just let it hang. when items are pushed in it covers them fine and makes it easy to fold the 2nd row seats.
Tonneau cover, finished what Toyota started
06-18-2019, 06:01 PM
Am I the only one who uses a $4.99 tarp? It also doubles as an awning, tent, ground cover and privacy screen.
Blue Tarp - 7 Ft. 4" X 9 Ft. 6" Weather Resistant Blue Tarp
2023 TRD ORP w/KDSS. Red again.
This 2016 TEP w/KDSS is a big step up from the 1986 Subaru GL wagon I used on the Outer Banks beaches for 14 years. That thing would go anywhere in the sand on 185/70-13 tires. Dual range 5 speed, factory skid plate, 3 position manually adjustable rear shocks and armored exhaust. All factory, including the white spoke wheels. The front sub frame finally rusted apart.
06-18-2019, 07:15 PM
Does this have "quick disconnects"?
06-19-2019, 01:22 AM
We can certainly do have some for this. Add a couple pair of the C109W hooks and it will.
Here's a few of a cargo net style if you don't need the hidden part of the Codura panel one.
06-19-2019, 08:32 AM
i use a black sheet, with just the stock tint it's dark enough that the black sheet disappears and you can't tell it's covering anything
