Old 05-24-2019, 11:29 PM #1
Satweh Satweh is offline
Satweh is on a distinguished road
Cornfed lift 2 1.5 alignment question?
Just got my cornfed spacer kit installed, with k02 285s, loving the look. I still have stock uca. Is this alignment normal with stock uca and this mild lift. Thanks for the help
Cornfed lift 2 1.5 alignment question?-20190524_231543-jpg
Satweh is offline   Reply With QuoteReply With Quote
Old 05-24-2019, 11:35 PM #2
Will be posting pics of the rig tomorrow
Old 05-25-2019, 08:21 AM #3
Any help will be greatly appreciated
Old 05-25-2019, 09:27 AM #4
AINOMOATACO AINOMOATACO is offline
AINOMOATACO is on a distinguished road
Caster could use a bump. You are probably maxed out with the stock UCAs. Take it on the freeway and see if it wanders. You will know if aftermarket UCAs will be needed.
AINOMOATACO is offline   Reply With QuoteReply With Quote
Old 05-25-2019, 11:13 AM #5
TEujunga's Avatar
TEujunga TEujunga is offline
TEujunga has a spectacular aura about TEujunga has a spectacular aura about
TEujunga's Avatar
In general, the higher the lift, the more difficult it becomes to get caster and camber numbers within spec with stock UCAs. You should be able to do better than this with only 2" of lift, though. It doesn't look like the alignment tech made much of an effort to adjust the caster. It can be tricky and take much juggling of the alignment cam bolts to get the optimum balance between caster and camber (adjusting one affects the other).
I have ~2.5" of front lift, and the old-school mechanic I used didn't have a newfangled laser alignment rig -- just a bubble level held against the wheel flange. He was able to get +2.5º caster on both sides with 0º camber, but it took him a while. That's about the most that can be extracted from stock UCAs at that amount of lift.
Bottom line, try again with a more knowledgeable (or at least more thorough) alignment tech.
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
TEujunga is offline   Reply With QuoteReply With Quote
Old 05-25-2019, 11:53 AM #6
Thanks for the help
Old 05-25-2019, 11:54 AM #7
Any decently priced Uca suggestions? And how much is install usually?
Old 05-25-2019, 04:37 PM #8
Pic of the rig with the mild lift and 285s
Cornfed lift 2 1.5 alignment question?-20190525_151118-jpg
Old 05-25-2019, 05:22 PM #9
Off_Axis Off_Axis is offline
Off_Axis is on a distinguished road
SPC/Light Racing UCAs are the best bang for the buck... in my opinion.
As far as an install cost, depends on your choice of installer. Shouldn’t be more than a couple hours.
2019 TRD Pro
Cornfed Suspension 2”/1” spacer lift.
SPC/LR UCAs.
Toytec differential drop and sway bar relocate kits.
Still on stock wheels and stock 265/70R17 Nitto Terra Grapplers.
Oh... and 1” wheel spacers too.
Good luck.
I’m CDO like that (OCD alphabetically)...
Off_Axis is offline   Reply With QuoteReply With Quote
Old 05-25-2019, 05:45 PM #10
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
if it aint rubbing, and your tires are wearing evenly then leave your alignment alone.
Old 05-25-2019, 08:03 PM #11
Yea probably leave it as is unless I experience issues, but so far so good. No rubbing at all and drove it on the highway, felt normal, felt stock. Thanks for the feedback
Old 05-25-2019, 09:18 PM #12
alcomedic alcomedic is offline
alcomedic is on a distinguished road
Great looking rig! The 2/1.5 and 285's really gives a nice stance
alcomedic is offline   Reply With QuoteReply With Quote
Old 05-25-2019, 09:46 PM #13
Thanks, it’s night and day. I was in a debate about 275s or 285s, I’m happy I went with the 285s. To me the ride is the same as stock.
Old 11-06-2019, 10:25 AM #14
JJ_2020 JJ_2020 is offline
JJ_2020 is on a distinguished road
2019 TRD Pro
SPC/LR UCAs.
Good luck.
About to do this to my 2020 TRD Pro - thanks for sharing all these specs. Did you anticipate needing the ToyTec relocate kits and new UCAs, or did the install mechanic suggest them? I'm new to mods like this and want to make sure I ask the right questions of my mechanic?
Also, you think you have clearance for 285s?
Thanks in advance.
JJ_2020 is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 10:53 AM #15
the_fornicator the_fornicator is offline
the_fornicator has a spectacular aura about the_fornicator has a spectacular aura about
Is it just me or are you running a reverse rake?
And yeah, you won't get more than 1 degree of caster with stock UCAs if running >=2" lift in the front. Be nice to get to 4, but it'd be nice if life was that easy lol
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
the_fornicator is offline   Reply With QuoteReply With Quote
alignment , cornfed , lift , stock , uca
Lift/Alignment Question yotanut 5th gen T4Rs 2 04-02-2019 06:19 PM
Alignment after lift issues/question... KurtL 3rd gen T4Rs 2 10-18-2012 11:44 AM
Lift and alignment question jdebo 4th Gen T4Rs 4 01-01-2012 12:57 PM
Cornfed Lift with 22's Tire Size Question LV4R Engines / Suspension / Wheels / Tires / Audio / Accessories 1 03-16-2006 12:41 AM
question about cornfed lift?? DE 4Runner Off-Roading 1 02-15-2006 03:17 PM
