06-25-2019, 11:06 PM
#61
Originally Posted by Terrapod
Received yesterday - installed this morning. Please note - I decided to use some nasty 3M VHB tape instead. It was a little thinner and a lot more sticky than the tape that came with it. It is now on there permanently.
Can you remove 3M tapes if you take the ladder off?
06-25-2019, 11:45 PM
#62
Real Name: Andrew
Real Name: Andrew
Just ordered the ladder with 2 side steps and the Rotopax mount
@andyadventuring @samadventuring
'18 TRD Off-Road
06-26-2019, 08:48 AM
#63
Real Name: Chad
Real Name: Chad
Technically - everything is removable.
If you're not familiar with 3M VHB - use the tape that comes with it. Some types of VHB will take paint off.
2016 TE - 2.5 Icon Stage 2 Ext Coilovers, Icon 2.0 Remote Res rear shocks - RCI sliders & skids - Custom front LED in-grill mount - Rigid - General ATX 275/70 - SCS Wheels, Terrapod RTTx, Raingler, Baja Designs, Rhino Rack.
06-26-2019, 09:08 AM
#64
Real Name: Andrew
Real Name: Andrew
I suspect the tape that comes with it will take paint off, too. I was considering putting some clear paint protector underneath. Does that sound like a good idea?
'18 TRD Off-Road
06-26-2019, 09:24 AM
#65
Real Name: Chad
Real Name: Chad
No. The tape that comes with it will release (I have done this twice now). It takes effort, but from what I could see it won't mess up the paint.
06-26-2019, 10:37 AM
#66
That is a bad idea. The tape would only be as strong as the vinyl you use there and it not a good adhesion surface. You just need to make sure you dont use the 3m tape that says “permanent bond”.
06-27-2019, 01:02 PM
#67
Real Name: Caleb
Real Name: Caleb
Originally Posted by slprciv
Got the replacement top plate. Fit perfect! thanks Caleb
@ C4 Fabrication
That's great to hear guys, glad they are fitting well!
Owner/Operator of C4 Fabrication. specializing in custom built Toyota off-road products. www.c4fabrication.com
07-21-2019, 06:47 PM
#68
Finally got around to installing mine today.
1. New plate had zero issues laying flat and even though it is close no scraping
2. I sent the entire hardware packet to PCbolts.com to have matte black powder coated. As usual the quality and CS were outstanding. I have done a lot of hardware with them and none of it has chipped while torquing down, and 100% coverage
3. When I had my clear mask installed I had them throw on a patch above the first step location. Highly recommend doing this, there is very little toe room.
4. Installed the C4 recommendation for new struts. Really these are a must imo. They are a little longer though. Making the clearance to my Rhino rack pretty tight. I have my rack pushed forward about 1/4” from touching the shark fin.
Great product, design and quality. Love the rubber steps
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
07-21-2019, 10:54 PM
#69
2. I sent the entire hardware packet to PCbolts to have matte black powder coated. As usual the quality and CS were outstanding. I have done a lot of hardware with them and none of it has chipped while torquing down, and 100% coverage
Throw a loaded gascan on that ladder... you’ll need even beefier struts
07-21-2019, 11:05 PM
#70
just curious what uses people are getting out of the ladder?
I was considering getting one and thought it would be useful for getting to the RTT to help make setup easier, but it seems like standing on the rear bumper is just as good, and with the RTT up there I cant walk on the rack anyway because there is no space.
only use I can think of for myself is adding rotopax for gas/water
07-21-2019, 11:17 PM
#71
OP, your pictures are too big to see what's going on. If you use the IMG tags on Imgur and add an 'h' before the .jpg in the link, it'll resize them nicely.
Example using your first pic:
Find the Imgur IMG code on the Imgur page of your pic. Copy it. Paste it here, but add an 'h' right before .jpg like this:
[IMG https: //i.imgur. com/jXOzpRL h.jpg /IMG]
I left spaces and brackets open in that link because the forum is trying to “fix” it for me even though all I want to do is show an example.
Then, your pics will be forum friendly like this:
2012 SR5 4WD 3rd Row
Build/Adventure thread
Nitto TG G2 LT265/70R17 review thread
07-22-2019, 08:49 AM
#72
For me, RotoPax (mostly water) and I have an X-cover RTT on order and if I want to load items on top of it I think getting better access will help. Then maybe a shovel
But I have to admit, I struggled with buying a ladder. So many Range Rovers around here with ladders and no rack. If C4 had not come up with this design I wouldn’t own one. But is it a need...no
07-22-2019, 09:06 AM
#73
Real Name: Jeremy
Real Name: Jeremy
Makes me happy in this day and age to see a business standing by their product and making it right for their customers..while I certainly don't need a ladder, it definitely adds to the cool factor and if I decide to buy one it will be from C4..
side note, I've looked through this entire thread and not one pic on anyone standing on that ladder..how about it??
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
07-22-2019, 09:48 AM
#74
Thanks for the reply! I have a smittybilt xl tent on my rack now and there is no room to walk up there or even to store anything really. There is basically no room for anything else, not even rotopax on the roof. I may consider the ladder simply for rotopax if anything. I thought there would be more room up there, but as it stands it seems it would nullify the usefulness of the ladder except for accessories.
07-22-2019, 10:58 AM
#75
Real Name: Andrew
Real Name: Andrew
My cargo area holds my campsite, photography gear, clothes, and some misc. regularly needed things. My entire second row belongs to my dog. So I have 2 cases on the roof for things I don’t need as often: tools, misc. emergency stuff (ex: tire patch kit), camp shower, dirty clothes, day hiking pack. I will also use the roof as a photography platform in some cases.
But mostly the ladder will just look cool.
'18 TRD Off-Road
