Old 08-17-2019, 02:32 AM #46
Tejas Tejas is offline
Tejas is a jewel in the rough Tejas is a jewel in the rough Tejas is a jewel in the rough
I would love to run one of these but I already have my ARB Dual Compressor in that spot on the Slee mount. That spot seems to be the most popular place to mount anything under the hood.
The product looks great and I am sure it'll do well, just sad I can't utilize it.
Tejas is offline   Reply With QuoteReply With Quote
Old 08-17-2019, 01:34 PM #47
SD Offroad SD Offroad is offline
Real Name: Derek
SD Offroad is on a distinguished road
Real Name: Derek
Originally Posted by GX4SEVEND View Post
How does this compare to the Overland Equipped? That’s what I’m currently running with a blue seas fuse box. Ability to run different units?
The Fuse Block Mount Tray will be available within a month or so, but as tomb_rnr says, Their product is not for the Switch-Pros SP9100.
Originally Posted by tomb_rnr View Post
I’m not to familiar with Overland Equipped. But looking at their product it’s not designed to mount a switch pro. Am I wrong?
This particular mount is designed to mount the switch pro as it was intended to be mounted, vertical.
I believe you are correct. I looked at the product as well... unless I am missing something. Thanks for answering.
Your install looks like you did a great job ! Nice clean 2019... I like it !
Thanks for the feedback ! Yeah that ARB is a beast for sure. I do not think there's any additional room after that install.
SD Offroad is offline   Reply With QuoteReply With Quote
Old 08-18-2019, 01:43 AM #48
tomb_rnr's Avatar
tomb_rnr tomb_rnr is offline
tomb_rnr is on a distinguished road
tomb_rnr's Avatar
I just finished the complete install today. I'll try to take pics and share them here.
2019 4Runner TRD Off-Road Premium
tomb_rnr is offline   Reply With QuoteReply With Quote
Old 08-18-2019, 09:31 PM #49
tomb_rnr's Avatar
tomb_rnr's Avatar
Here is the finished install.
Switch Pro 9100 Vertical Mounting Solution-img_3835-jpg
Switch Pro 9100 Vertical Mounting Solution-img_3836-jpg
Switch Pro 9100 Vertical Mounting Solution-img_3837-jpg
Old 08-19-2019, 07:48 PM #50
Real Name: Derek
Real Name: Derek
(images not shown as they are directly above)
WOW, very nice professional looking job ! I'm very please as to how it came out ! Thanks for sharing the results.
Old 08-20-2019, 02:20 AM #51
Real Name: Derek
Real Name: Derek
Originally Posted by Louisiana Overland View Post
I am interested in purchase as well. 10 or 12 circuit blue sea. What will the pricing look like?
Just for this version of the Mount Tray, $100-120, but I'm hoping to keep it lower if i can (Mount Tray only, BS items will be additional).
Here is a possible layout for the Fuse Block version in the works. It will accommodate the Blue Sea 6 or 12 Fuse Block with pre-drilled holes and one circuit breaker as shown. There would be slots on both sides of the Fuse Block (not shown).
Any thoughts or comments ?
Switch Pro 9100 Vertical Mounting Solution-fuse-block-concept-w-busbar-cb-1-jpg
Old 08-20-2019, 06:26 PM #52
tomb_rnr's Avatar
tomb_rnr's Avatar
Your product helped me achieve it.
Old 08-25-2019, 01:17 PM #53
Real Name: Derek
Real Name: Derek
Fuse Block Mount Tray in Stock Soon
Hi, so the Fuse Block Mount Tray will, as pictured above, be available in a couple weeks. The only thing not shown in the photo are the slots on the left and right sides of the fuse block.
Old 08-28-2019, 01:15 AM #54
Real Name: Derek
Real Name: Derek
Fuse Block on Current Mount Tray
I had a request to see if the Fuse Block would fit on the current Mount Tray. If you wanted to drill holes, this is what it would look like...
Switch Pro 9100 Vertical Mounting Solution-fuse-block-mount-tray-concept-2-jpg
Old 08-30-2019, 05:28 PM #55
PHORUNR PHORUNR is offline
PHORUNR is on a distinguished road
I have a BS 12 circuit w/ negative fuse block and a 10 gang busbar. I came across your thread today and was curious if they'll work on your mount?
If so, how can I order one? Thank you!
PHORUNR is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 06:13 PM #56
Real Name: Derek
Real Name: Derek
So, this one pictured is the current Mount Tray available designed around the Blue Sea BusBar (as pictured - holes drilled) and the Terminal Block - the Blue Sea Fuse Block is covering that part. If you drill the holes for it, there you have it as pictured.
Additionally, the Fuse Block Mount Tray that is being manufactured right now will have the holes drilled for it and a slot on either side of the Fuse Block if you can wait a couple weeks.
If you want this one, PM me your name and email address and I can send you an invoice to pay and I'll ship it next day generally depending on when its ordered/paid.
Old 09-03-2019, 02:42 AM #57
Do you have a rough ETA on the new tray? I will most likely hold out for that one. I like the idea of being able to keep all the cables organized on both sides.
Old 09-03-2019, 09:53 AM #58
Real Name: Derek
Real Name: Derek
Rough is 2 weeks. I am hoping for sooner. I'll definitely be posting here when they are available.
Old 09-05-2019, 01:39 AM #59
Sounds good! You can put me down for that one!
Old 09-07-2019, 11:34 AM #60
Real Name: Derek
Real Name: Derek
Should be getting the Fuse Block and the Blank Mount Trays in next week sometime.....
Thank you for those that have purchased the Terminal Block Mount Tray. Please post pictures when you get it installed !
mounting , pro , sp9100 , switch , vertical
sPod HD or Switch Pros 9100 Tejas 5th gen T4Rs 17 05-29-2019 02:34 AM
Solution for 40'' Light Bar on Gobi Rack w/ 2 front vertical support bars.. cmilviper 5th gen T4Rs 1 08-22-2018 02:36 PM
FS: IL, Switch Pro 9100 Switching set up, $395 BNIB Shipped chitown4x4 For Sale: T4R Items 2 08-09-2018 02:34 PM
New Solution to mounting your Hi Lift on a Gobi Stealth! SOcalTRAIL 5th gen T4Rs 23 05-06-2018 03:25 PM
