05-30-2019, 08:47 PM
#16
thanks for all the great ideas. it definitely brings in a lot of factors and things to think about. I do aggree that the modularity of plug and play units would be easier. as well as only havingt 4 open spaces for AOB switches in the trd orp dash. That would mean I am limited to my current plans.
Just many factors to consider as well as possible additions in the future.
05-30-2019, 09:12 PM
#17
I was running a home made distribution system that used AOB switches. I would say, it wasnt hard and was an interesting and fun experience. I'm now running apollointech system along with switches that are mounted onto a 3D printed mount. Much more cleaner and tactile vs the OEM switch location and AOB switches.
Will be mounted a volt meter to the OEM Toyota SOS button location.
Sent from my SM-N950U using Tapatalk
05-30-2019, 11:25 PM
#18
Real Name: Bob
Real Name: Bob
This is a great thread guys! Wish I knew all this info before I started my project and bought something.
I wanted the convenience of using the OEM blank switch locations AND having an additional switch panel but I did not want to use the blank area below the A/C controls since I have an amateur radio there.
I researched the:
Schrockworks Bussman
Switch pros 9100
sPod Bantam
eBay Bussman knockoff
DIY methods
The Bussman was ok but no switch button panel.
I liked the switch pros button panel but that unit could not accommodate using AOB switches in the blanks.
The 8 switch Bantam could be daisy chained with 3 more units for up to 32 accessories with one touch screen and could use AOB buttons for 1 or 32 remote switches! BUT it is in the price gouging range!
eBay knockoffs were the same as the Shrockworks Bussman
The DIY was out because I’m too busy with other stuff than to design something even though I’m quite capable.
I chose the sPod Bantam with touchscreen but had a hard time due to its excessive and over priced cost! I agree with the others that the touch screen is quirky but it’s works. I have yet to find a suitable location that I like. The engine compartment switch is small and has all the overload protectors without the need for relays and fuses. Very current technology. It appears to have all electrical protection circuits water proofed and board is water resistant. The screw connections are protected but neither water proof or resistant.
I recommend it, but put up with a less than state of the art touch screen or get the push button panel and limit your switches to 8.
2018 TRD ORP, MGM, Xpel 35% Tint, Xpel Clear Bra, In-Dash 2m/70cm Icom Radio, Dual-band 1/4 wave antenna with Rago Mount, sPod Bantam, 2 x 32" behind the grille LED lightbars, Cali Raised 3-way Fog Lights.
Sold: 2011 SR5
06-02-2019, 01:31 PM
#19
So I priced everything out for a DIY using AOB switches and here is how it would play out vs the other options including estimated install/assembly time:
complete DIY starting with blank cheap relay box: $250-275 + 4-6 hours of wiring.
Pros: cheaper, can wire any way I want, easy maintenance of bosch relays etc.
Cons: lots of DIY time, not as clean install, no bluetooth, limited to 6 devices.
DIY Using Shrockworks Bussman and prewired kit: $300-350 + 2-3 hours of wiring.
Pros: cheaper, can wire any way I want, easy maintenance of bosch relays etc., save some time vs from scratch, bussman is better than univeral relay box.
Cons: lots of DIY time, not as clean install, no bluetooth limited to 5 devices.
Spod Touch: 750 + 1 hr wiring
Pros: very easy install, very modular, clean and nice looking install and controls, bluetooth
Cons: Price, could get water damaged.
Switchpros: 600-700(with mounting) + 2 hrs labor
Cons: Price, could get water damaged, not as clean as spod due to all the wiring, not as modular as spod.
Overall, I think DIY is cheapest option but not as clean and limited modularity, Switchpros falls in between DIY and Spod for combination of price, features, ease and cleanliness of install. Spod is the most expensive option but easy and clean install and more modular in the long term.
I dont have the immediate need for it yet since I am waiting on the roof rack and lights etc, but I think that I will end up going the spod touch route since it would be a long term investment for me. I don't like buying new cars, so I would plan to keep the 4runner for 20 years most likely or as long as it does not fall apart.
06-04-2019, 09:31 PM
#20
Real Name: Bob
Real Name: Bob
Nice write up Sir! While the sPod Bantam is incredibly expensive, I am very very pleased with it. I take way too much time installing everything but in the long run, the system is excellent.
The bigger sPod switching system does not appear waterproof, but the SPod Bantam has a different design. The only thing partially exposed are the 8 positive and 8 negative connections for the accessories and the 10 optional connections for 8 AOB switches, the low voltage override, and a hot switching circuit.
I paid $845 less a 5% discount, however, there was a group buy here a few weeks back that resulted in a fairly nice discount. Might keep watching to see if that pops up again.
I mounted the Bantam on a Stainless PowerTray that makes this a professional looking install.
Sold: 2011 SR5
06-11-2019, 10:18 PM
#21
Some way over due photos of my Feniex 4200 Mini controllers...
First two are the front controller, last is the rear controller...
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
06-12-2019, 01:02 AM
#22
Take a look at the S-Tech Systems. I did a review here that may be worth a look. Custom OEM style or Rocker Switches w/ housing, Power Module, wiring, custom engine bracket, 5 year warranty for under $400. Had mine for a few months now and couldn't be happier
[IMG]
2016 Trail Premium | F: King 2.5 RR Ext | Rear: Icon 2.0 w/ Dobinson Coils | JBA UCA's | FN F(X)Pro Wheels Matte Black | Nitto Ridge Grappler 285/70/17 | Coastal Offroad Front & Rear Bumper | RCI Aluminum Skids | RSG Angled Sliders | Xenon HID | S-Tech Custom 6 Switch Housing
06-12-2019, 09:10 AM
#23
@ ehcanadian
I did see your review and took a look at that product. Though the relay box they are using is the exact same part i was going to use and it costs $6 on amazon. I did consider that in my diy and it would cost about half what the stech sells for if i built it myself, and i would use the aob switches that actually fit in the oem slots.
For someone without the electrical knowledge and skills it is a good economical solution but i couldnt justify the price since I can build pretty much the exact same system with better switches for much cheaper.
06-12-2019, 02:11 PM
#24
some really good info here.
06-17-2019, 09:20 PM
#25
so while I was looking for a spod or switchpro I ended up getting a switchpro 9100 for a great deal, so that is what I will end up installing!
It just arrived and I havent installed any of the lights yet or got my roof rack in so I will wait a bit longer.
Here is what I have so far(not all installed):
s2 sport pair rear(installed)
2 pairs of s2 flush mounts for the SSO rack(not yet installed)
rear power bank for RTT power(installed but not wired)
looking to get:
dual s8 baja designs in grill light bars
hidden winch setup
06-18-2019, 11:58 AM
#26
I considered this as an alternative to the expensive setups because of the price. Can't really beat it! Looks good!
'17 MGM Off Road Premium package. 5100's, Dobinson's coils, Icon UCA's, Morimoto 2Stroke LED Low Beams, Rigid Radiance Fogs, Orange Boxx Fab rear racks.
Coming soon: Winch/Bumper, CB, lights, sliders and skids.
06-18-2019, 02:00 PM
#27
Real Name: Shwell
Real Name: Shwell
I went the 6 Gang Waterwich setup from Amazon.. I paid $115 at the time.
I looked at all the options i could find, and like a few of them quite a bit, but I couldnt justify the cost (To the wife mostly). In the 1 year of ownership, I have only used my aux lights 3 times.
As I upgrade my lights, I may upgrade the switch as well.
'18 TRD ORP 5100's Gobi Rack OME Springs
And a bunch of other stuff I dont really need!
06-18-2019, 03:55 PM
#28
Real Name: Chad
Real Name: Chad
I really wish the Waterwich one would come in a different color LED. That green / yellow is awful.
2016 TE - 2.5 Icon Stage 2 Ext Coilovers, Icon 2.0 Remote Res rear shocks - RCI sliders & skids - Custom front LED in-grill mount - Rigid - General ATX 275/70 - SCS Wheels, Terrapod RTTx, Raingler, Baja Designs, Rhino Rack.
06-19-2019, 10:14 PM
#29
I agree. I didnt want to go with most of those amazon setups because of the light color.
As far as use, I use the rearr lights every time I go camping and plan to use the sides often as well, which is why the bluetooth was important to me. I try to go camping every other weekend almost year round as long as there is no rain storms or snow in the forecast and temps are above freezing during the day.
06-20-2019, 09:09 AM
#30
Wow.... the roof/grille/ditch/fogs get used daily (I use fogs as "DRL's" also), rear lights every time I go into reverse, ground lights anytime I'm parked at night, and side scene lights at least every few days for some reason or another
