Old 06-03-2019, 10:07 PM #16
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
That's pretty decent news, no? Relatively inexpensive bolt-on sensor rather than a major mechanical. Yeah, it's on you but still.
5thToy is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 11:02 AM #17
assassin assassin is offline
Real Name: M
assassin is on a distinguished road
Real Name: M
So Oil Pressure Sensor Switch is leaking and it leaked all over the timing belt so they want to replace that too. Apparently its all over the timing belt so they want to replace that too, but since something that was not under power train (oil pressure sensor switch) leaked over the timing belt all is out of pocket.
assassin is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 11:13 AM #18
arehman11 arehman11 is offline
arehman11 has a spectacular aura about arehman11 has a spectacular aura about
You should find a new dealer, these engines don't have a timing belt.
2017 MGM TRD Off Road Premium
arehman11 is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 12:11 PM #19
Thermal Thermal is offline
Thermal is on a distinguished road
rofl
Thermal is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 01:15 PM #20
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
I agree with above comments: find new dealer….
I would also let them quote the replacement of “nonexistent” timing belt and then report them to Toyota corporate for scamming…
In addition, if they are actually right (obviously very doubtful now) about oil pressure switch leak, then I believe you are the first (or one of the first one) that had that issue on 5th gen 4.0 engine…
Again, I would definitely recommend second opinion…
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 01:27 PM #21
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
Man, you gotta hand it to these ripoff artists. Even the Liar in Chief would have a hard time rolling so many lies into one statement. Lie 1: all the sensors on the engine are part of the powertrain. Lie 2: somehow an unrelated part failure hurting the powertrain voids the powertrain warranty and obviously Lie 3 is replacing a non-existent part. Man, that's a doozy right there! LOL
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 01:32 PM #22
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Just an FYI - it's unlikely you need a new pressure sensor if that is the leak. You should simply remove, clean threads, coat threads with blue loctite (toyota 1344) and re-install. 11 lb ft of torque. You'll need a 24mm deep socket to remove. Otherwise it probably takes about 30 minutes to do this job. It is quite unusual to have a leak there and I would still seek a second opinion on this one. If it is - it's a very easy fix.
Good luck.
Old 06-04-2019, 03:40 PM #23
vondy21's Avatar
vondy21 vondy21 is offline
vondy21 is on a distinguished road
vondy21's Avatar
And if it were dripping on the timing CHAIN why would that matter? The chain is lubricated by engine oil.
Maybe they are talking about the serpentine belt?
2017 TRD Off-Road Premium
Magnetic Gray - KDSS
Stock suspension, Michelin Defenders LTX MS
vondy21 is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 04:19 PM #24
Deep_palancar's Avatar
Deep_palancar Deep_palancar is offline
Deep_palancar will become famous soon enough
I'm gonna speculate that the call for the belt replacement is a miscommunication somewhere in the relay chain.
I'm sure they mean the serpentine belt. If it is oil soaked then recommending replacement is the right pro call to avoid a service come-back. As a DIY I'd just clean it with brake cleaner.
The sensor can be had for less than $20 at almost any parts store. It is easily accessible through the right wheel well, just remove a splash flap and you can see it. As others have stated it takes a 24mm deep socket and blue 242 locktite. It's a 30 minute job including the locktite cure time.
Also, despite what others are saying, sensors and switches are NOT covered under the >36k- <60k powertrain warranty. The covered items are specifically
itemized.
Deep_palancar is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 05:01 PM #25
Mack1611 Mack1611 is offline
Mack1611 is on a distinguished road
So, I have an oil leak in the same general vicinity. I replaced the Oil Filter Housing gasket and it did slow my leak but not stop it completely. I will try the sensor next and if that doesn't work it's on to the Front Crank Seal.
Mack1611 is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 02:50 PM #26
LUTD4x4 LUTD4x4 is offline
LUTD4x4 is on a distinguished road
Originally Posted by davester00 View Post
I had a rear main seal leak @ 42K. Mine is probably the 4th or 5th one I’ve heard about in a 5th gen
Just had my rear main seal repaired at the dealer... 2018 TRDPRO with 24k 😑😑😑 Some baby back bullshit right there.
LUTD4x4 is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 03:20 PM #27
Wizzard Wizzard is offline
Wizzard is on a distinguished road
You can always use a thicker oil as a band-aid. This engine specs up to a 40w depending on climate. Most on BITOG use a 5w-30 in this motor, others use 40w. Anyone who tells you that "the oil passages are designed for 0w-20" is a sign they are clueless. Good luck.
TRD Pro
Wizzard is offline   Reply With QuoteReply With Quote
Old 06-07-2019, 11:49 AM #28
Real Name: M
Real Name: M
1000 miles later leak is still there pretty sure I just got scammed
Old 06-07-2019, 12:08 PM #29
Are you saying the dealer replaced the sensor and serpentine belt, and that you have an oil leak at the oil pressure sensor after 1000 miles? Or are you saying they performed that work and there is a yet to be defined leak?
Old 06-07-2019, 12:13 PM #30
Real Name: M
Real Name: M
They completed the work I needed to drive back home and didn’t want to risk leaking oil as I was driving.
Still a leak somewhere.
coming , experienced , leak , oil , start
V8 Engine Leak beach146 4th Gen T4Rs 16 01-31-2018 04:26 PM
95 3.0 Gas Leak Only When Engine is Running forerunner95 Classic T4Rs 5 04-01-2015 09:00 AM
Gas leak under engine? mistersnowman97 Classic T4Rs 7 07-15-2014 09:30 AM
Possible engine oil leak? Auce 3rd gen T4Rs 5 04-09-2014 08:28 PM
Coolant leak behind engine graeaglecrawler Classic T4Rs 4 10-09-2011 09:34 PM
