05-30-2019, 02:47 PM
Real Name: M
Real Name: M
5th Gen Engine Oil Leak at 50k
Before I start the oil filter canister and drain plug are not the source of the leak.
Have some dye and a uv light coming...was wondering if anyone has experienced an oil leak of any sort and would mention where it was coming from so I'd have some great places to start checking first.
05-30-2019, 02:58 PM
My valve cover was leaking on my 3rd gen a while back, but that was after 16 years and 250k miles. But maybe something is wrong with your gasket.
05-30-2019, 03:56 PM
I have a leak at 26K. Mine looks like it is the gasket between the oil filter housing and the block. I'll be changing this out this weekend. Clean the oil off with carb cleaner or something and go drive around for a while and keep checking for new oil.
05-30-2019, 05:38 PM
Real Name: M
Real Name: M
Thanks guys! Should I be using the specific engine degreased to clean up areas or is brake cleaner ok to use to spray on things?
05-30-2019, 06:22 PM
Real Name: Morgan
Real Name: Morgan
The timing cover inspection plate, is a known source of an oil leak, passenger side, front of engine.
2010 SR5 Blizz Pearl- Borla cat back, Firestone ride rite, Huskyliners, Afe Cai, Urd MAF, Gobi stealth with ladder, 5100s, icon 2" rear, toytec 1.6" front, TC UCA, HAF custom sliders, hand hold light mod, Led interior, stock rims and BFG KO2 265/70 C, Arb CKMA12- slider tanks w/ couplers, BD S8 10", opt7 40", BD dome light led in rear hatch
05-30-2019, 06:57 PM
Brake cleaner will work.
05-31-2019, 09:41 AM
Do you have any pictures of that oil leak? That would help to narrow it down.
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: http://www.toyota-4runner.org/5th-ge...estion-50.html thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
05-31-2019, 09:50 AM
Rms
I had a rear main seal leak @ 42K. Mine is probably the 4th or 5th one I’ve heard about in a 5th gen
05-31-2019, 11:04 AM
There's a thread about a rear mail seal leak being a quasi common occurrence on 5th gens. Hopefully covered under warranty for you.
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
05-31-2019, 02:00 PM
Real Name: M
Real Name: M
Hello everyone thank you for the input.
Really hard for me to take a picture of where its coming from but looks like either at the front crank or front passenger side where the hoses go from the oil pain to the block. The belt and pulleys are covered in oil.
Luckily this type of engine oil leak should be under the powertrain warranty as I am below 60k/5years.
Yeah I was freaked out as I remember only like 3-4 quarts of oil left when I changed it.
Going to have dealer look at it Monday and I will update you guys with what I find.
05-31-2019, 06:08 PM
Really hard for me to take a picture of where its coming from but looks like either at the front crank or front passenger side where the hoses go from the oil pain to the block. The belt and pulleys are covered in oil...
Sounds like it is timing cover leak... as you said, it should be covered under power train warranty... still sucks that it happens with 5th gen 4.0,- I believe most of the time I have seeing it on first year (s) of this gen... what year is your 4Runner?
05-31-2019, 09:54 PM
Real Name: M
Real Name: M
Originally Posted by progress4m
sounds like it is timing cover leak... As you said, it should be covered under power train warranty... Still sucks that it happens with 5th gen 4.0,- i believe most of the time i have seeing it on first year (s) of this gen... What year is your 4runner?
2015
05-31-2019, 11:11 PM
A search for threads dealing with oil leaks will net some with pics; as mentioned there is a history of 5th gen leaks. Also, if you use brake clean, do not get it on any painted surface. It will remove the paint fast!
06-01-2019, 10:22 AM
2015
Got it.
Good luck! Hopefully dealer will take care it with no issues!
Keep us posted.
06-03-2019, 07:33 PM
Real Name: M
Real Name: M
Got it.
Keep us posted.
According to dealer its an oil pressure sensor switch which is not covered under the powertrain warranty
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
