Old 05-30-2019, 03:30 PM #1
Mack1611 Mack1611 is offline
Mack1611 is on a distinguished road
Oil Filter Housing
Anyone know the torque specs for the 3 bolts that hold Oil Filter Housing (Filter Housing - Toyota (15671-31040)? This is for a 2016.
Thanks
Mack1611 is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 05:31 PM #2
71gs3504sp's Avatar
71gs3504sp 71gs3504sp is offline
Real Name: George
71gs3504sp is on a distinguished road
71gs3504sp's Avatar
Real Name: George
I also will like to know if people are replacing there plastic oil filter housing with a aluminum one? Would like to know which removing tool is best to use?
71gs3504sp is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 05:36 PM #3
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Sorry don't know the torque specs but want to answer the other question.
I like this one. Used the 4th gen tool for a couple years. Now in the 5th gen I got this one from the same guy on ebay.
Oil-filter wrench Toyota/Lexus/Scion - 09228-06501 | eBay
I'll use the 5th gen oil wrench this weekend on the plastic canister to remove and the aluminum to install. I'll remember to add a comment here confirming it works. But I bet it will.
Oil Filter Housing-oil-jpg
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 06:59 PM #4
71gs3504sp's Avatar
Real Name: George
71gs3504sp's Avatar
Real Name: George
Thanks!
Old 05-30-2019, 08:11 PM #5
ProfessorP's Avatar
ProfessorP ProfessorP is offline
ProfessorP is a jewel in the rough ProfessorP is a jewel in the rough ProfessorP is a jewel in the rough ProfessorP is a jewel in the rough
ProfessorP's Avatar
Years ago, I fell for all the Tundra forum hype that the aluminum filter housing was way superior to plastic. I replaced the plastic filter housing on my '09 Tundra with an aluminum one and it was always so hard to remove after that. The plastic housing was always easy to remove. The aluminum housing would stick like it was welded on especially if I waited 7,000+ miles between oil changes. Busted a few removal tools with the aluminum housing then switched back to the plastic and life was so much easier. 7 years and 150,000 miles with the plastic housing and it never broke.
ProfessorP is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 09:15 PM #6
jamoc jamoc is offline
Real Name: DeLo
jamoc is on a distinguished road
Real Name: DeLo
I broke my plastic oil filter housing during an oil change, using the OEM oil filter tool. 1st oil change after 30k service program was up. I assume the service dept. over tightened it, as they do every thing. All that aside, The aluminum works very well. I refer to this video, however torque specs. are in owners manual.
YouTube
jamoc is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 09:17 PM #7
71gs3504sp's Avatar
Real Name: George
71gs3504sp's Avatar
Real Name: George
thanks for the info!
Old 05-30-2019, 09:18 PM #8
Real Name: DeLo
Real Name: DeLo
The aluminum housing would stick like it was welded on especially if I waited 7,000+ miles between oil changes..
I agree it's very difficult, but not nearly stuck enough to break any tool. I put a bit of oil on the gasket before install
Old 05-30-2019, 11:04 PM #9
Deep_palancar's Avatar
Deep_palancar Deep_palancar is offline
Deep_palancar will become famous soon enough
Thanks
Looks to be 15 lb/ft
Oil Filter Housing-ofb-jpg
Deep_palancar is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 11:35 PM #10
Tuco S.'s Avatar
Tuco S. Tuco S. is offline
Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about
Tuco S.'s Avatar
I ordered an aluminum housing as a replacement in case the plastic housing fails. I doubt it ever will, since I'll be the one changing the oil. Never had issues with the plastic housing on any of my VW's.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
Tuco S. is offline   Reply With QuoteReply With Quote
Old 05-31-2019, 09:20 AM #11
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
When my wife bought her '14 4R 5 yrs. ago I decided to buy a spare plastic housing in the event the original ever broke during an oil change. I know many have opted for the metal replacement. My '06 Avalon came with one.
I have 2 of the special removal tools made for this style filter housing.
For the 4R, I've never had to use them. The small round plug that is removed on the bottom in order to facilitate draining the housing was tightened REAL tight at the factory. I simply take a 3/8" breaker bar and insert a short 3/8" extension into the square hole in the bottom of this plug and off comes the filter housing. To this day, that small round plug remains locked.
A number of people on some of the Tundra forums utilize my approach by applying lock-tite to the threads on the round plug. I'm not suggesting anyone do this, just saying mine ended up like this somehow.
18th oil change approaching. Doing just fine.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
15671-31040 , filter , housing , oil , toyota
WTB - 4TH GEN 06 V8 air Filter Housing groove4u Want to Buy/Trade 5 03-15-2016 06:31 PM
WTB: 3rd Gen Air Filter Housing Run 4 Fun Want to Buy/Trade 6 02-26-2016 02:51 PM
Metal oil filter housing flying fuzz 5th gen T4Rs 7 01-02-2015 08:10 PM
Where to buy new oil filter housing sandwich 5th gen T4Rs 3 06-23-2011 02:08 PM
oil leak on oil filter housing. dustyDtard Problems & Warranty Issues 6 03-29-2006 01:24 PM
