Old 05-31-2019, 03:25 PM #1
MisplacedTexan's Avatar
MisplacedTexan MisplacedTexan is offline
MisplacedTexan is on a distinguished road
Anyone else rubbing the sway bar?
OME 3" lift, SPC UCA's, SCS wheels 17x8.5 4.3 BS, 285/70/17 Falken Wildpeaks.
Alignment toe and camber are on the money, caster is up at 3.9 and 4.1
Left turns the right tire gets into the sway bar pretty heavily. Granted its closer to full lock, so I can mitigate it by not turning that hard. Just out of all the different rubbing I've never heard of anyone rubbing on the sway bar.
Still rubs on body mount in reverse only. But thats expected
2010 SR5 | ARB | Baja Designs | SCS Ray 10 | Falken Wildpeak 285/70 | Shrockworks | OME | SPC | Blue Sea | Hella Horns
MisplacedTexan is offline   Reply With QuoteReply With Quote
Old 05-31-2019, 08:26 PM #2
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
That backspacing is an offset of ~ -11mm. Trail (Trail and non TRD) rims are +15mm. 26mm is about 1 inch, pushing your rim and tire farther out (wide). This increases clearance to the shock/spring/arms, but makes the 'arc' of the wheel larger when the wheel is turned. I don't think it's common to hear complaints about rubbing on the sway bar. Tweak alignment, adjust rim offset, remove sway bar, smaller tire, sawzall, get a new rig. Good luck.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 06-01-2019, 05:35 AM #3
Brick Sprickly's Avatar
Brick Sprickly Brick Sprickly is offline
Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light
....only when I'm lonely.
2019 TRD Pro Voodoo Blue "Cobra Commander"
Brick Sprickly is offline   Reply With QuoteReply With Quote
Old 06-01-2019, 01:28 PM #4
Yea, I didn't account for the whole rotating arc/radius bit
Was rubbing on stock sr5 rims, and got caught off guard when it still rubbed on the new wheels.
Old 06-04-2019, 04:40 PM #5
matoolie's Avatar
matoolie matoolie is offline
matoolie has a spectacular aura about matoolie has a spectacular aura about
matoolie's Avatar
Have similar 3" lift, same exact tires....FN FX Pro Wheels though. 17x8, 4.5" backspace, 0mm offset and no issues.
Pretty sure your wheels are the biggest contributor.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
matoolie is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 01:09 AM #6
Well, I was going to start doing some math this past weekend and see what my options were, but when I went out to try and get the tire against it, it doesnt touch anymore.
It's like a phantom came over and made it just magically not rub. Weird.
Still runs on the body mount, and that's getting cut when I get back from work in 2 weeks.
Old 06-05-2019, 08:48 AM #7
WEAK_E90 WEAK_E90 is offline
WEAK_E90 will become famous soon enough WEAK_E90 will become famous soon enough
pics or it didnt happen.
ha
Jealousy is ugly... Don't be ugly.
Tirdy5's w/ -70 F5's
WEAK_E90 is offline   Reply With QuoteReply With Quote
bar , lock , mitigate , rubbing , sway
King Rear Shock Rubbing on Sway Bar Beach Bum 3rd gen T4Rs 10 07-13-2021 02:41 PM
Got an alignment now rubbing on sway bar. Velonici 4th Gen T4Rs 2 08-30-2018 01:24 PM
Sway Bar Rubbing Coilovers BlackWorksInc 4th Gen T4Rs 34 08-17-2017 06:55 PM
Sway bar link rubbing spindle Casper421 4th Gen T4Rs 11 01-09-2012 10:33 PM
