06-02-2019, 12:16 AM
Banned
Banned
Spare tire fitment (stock location)
I’m thinking about adding an SCS F5 with 285/70/17 Falken under my stock spare location. Any issues with this fitting?
06-02-2019, 12:49 AM
Excited to see it work!
My 2010 doesn’t have any room. So I’m excited to see how I can add a bigger tire too! Thanks for posting.
I can’t put one on my roof, too heavy.
I don’t have the $ to put it behind me on the bumper either!
06-02-2019, 12:52 AM
Why bother spending the money on a matching spare wheel only to stick it under the truck to get beat up by rocks? Are you planning on rotating the spare? Seems silly. Spend the money on a rear bumper so you can get the spare up on the back of the truck, where it will stay nice and can actually be seen before dropping more $$ on a nice spare wheel.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
06-02-2019, 01:24 AM
Real Name: Bump
Real Name: Bump
I took the best tire off of the former set of KO2 275’s I had and put that as my spare (replacing stock spare). No issues fitting under the truck. Not sure about 285’s, but I can assure you my 275 fit without any issue
2015 Magnetic Gray Trail Premium - Build Thread: https://www.toyota-4runner.org/5th-g...ight=mbumpus11 <<<--- click that to see what I've done
06-02-2019, 01:43 AM
I have a 285 70 17 ko2 on my spare with no issues. Just bought a used $20 tire off some guy offer up.
06-02-2019, 02:36 AM
285/70r17 nitto ridge grappler. No problem with fitting.
91 SR5 4runner, 97 SR5 4runner, 06 Sport 4runner,
18 TRD Pro 4runner Cavalry Blue(Toytec pro lift, Nitto Ridge Grappler 285/70r17, Rigid D-SS on Rago ditch bracket, RSG angled slider, Blackout emblems, led interior, fog and h11)
06-02-2019, 08:18 AM
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
06-02-2019, 10:47 AM
The tire will fit, although it hangs down considerably more than the factory spare and reduces the departure angle. If you're asking if the rim and tire will fit it will. I had a 285/70 on my 17x9 rim up there for a short trip back from the shop a while back. I was surprised how dirty it got in 10 miles.
I can't imagine trashing a good rim with it under the truck. Just wait till you can get it hung off the back somehow.
06-03-2019, 01:22 AM
Banned
Banned
Good advice...I should just wait until i get a swing out.
08-16-2019, 01:26 AM
Originally Posted by YellowSnow
IÂ’m thinking about adding an SCS F5 with 285/70/17 Falken under my stock spare location. Any issues with this fitting?
Put my 285/70/17 Toyo R/T down there. Perfect fit.
08-16-2019, 07:29 AM
Real Name: Jacob
Real Name: Jacob
I've had a 285/70/17 KM2 in the spare location. Fits but does stick down a little more.
I'm a fan of matching spares personally. I tend to use them often haha.
08-16-2019, 09:58 AM
Real Name: Nick
Real Name: Nick
Here is a pic of my 285/70/17 ridge grappler in the stock location
08-16-2019, 07:49 PM
someone on other post said 265/80/17. It would be similar dimension but thinner. So no departures angle issue
08-16-2019, 07:54 PM
Are you sure that is the size you mean?
That would be 2" larger than stock and 1" than 285 70. Also, there are no such tires offered by either Discount Tire or Tire Rack.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
08-16-2019, 08:19 PM
Sorry 255 80is what he said, don’t know which tire he referred. but it is really a good idea. To match 285/70/17, 255/80/17 works and is available in market
