Originally Posted by Mr.Rick
Which direction does your tent open with the tent mounted like that? Driver side? Passenger Side? or does it open front to rear?
I've got it setup for a passenger side open. Tepui tents allow you to mount the aluminum tracks to the bottom of the tent in two orientations, length or width-wise. This enables you to set the tent up for either side or rear opening regardless of the type of rack you have. I'm not sure of other brands but given their similarity it's probably the same deal.
I went width-wise cause I originally had it mounted on a gobi and wanted to maximize weight distribution. When I carried the tent over to this truck the factory rails worked fine so I've got no complaints.
