Some more progress this morning. The experience with the dome light helped and these two went fairly quickly.
When the boards are plugged into the metal tabs you'll find you can align the board a bit for levelness.
Check alignment as you drill your holes so the pushbutton is not at an angle.
Be sure to use new sharp drills when drilling holes in the lenses, support the lens face on a block of wood and don't run
the drill too slow. Start with a small pilot hole, check for alignment, next size drill, check for alignment.....
The plastic of the lens does not seem to be too hard but I was overly cautious cautious about cracking them during drilling.
Red light mode!
Jim _ My Adventure Blog:
http://suntothenorth.blogspot.com
2018 TRD Off Road Premium
ARB on-board compressor - RadFlo coilovers & rear suspension - Engel freezer-fridge - All Pro LCAs - African Outback roof rack, RCI skid plates
