Old 06-05-2019, 02:29 PM #16
Chilow Chilow is offline
Chilow will become famous soon enough
Originally Posted by WildBill1990 View Post
Chilow, I hope my response on the battery group buy page didn't cause confusion. The 24F would do the job just in shorter timed pulls. Here's an article that helped me do a power assessment for mine:Design Guide for 12V Systems
Just keep in mind that the alternator on the 4Runner runs at max 130A (Cant remember what RPM thats achieved at) and to subtract that from your power draw then you can calculate the run time before discharging the battery more than 25-30% and let it recharge via the alternator.
Thanks for your help. I purchased the Northstar 24F from the group buy. I also purchased the voltage booster from ARCLedLights just to be safe. I bought a voltage reader off Amazon that plugs into the cigarette lighter to monitor voltage as well.
Chilow is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 02:59 PM #17
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
That is a good start, well done sir!
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 03:02 PM #18
WildBill1990 WildBill1990 is offline
WildBill1990 will become famous soon enough
Cool! Good call on the voltage booster! after that was posted I looked into it as well and will probably get one too. Voltage reader is a good idea, I would check periodically still with a meter at the battery just to see what the avg difference is cause I've heard of people getting different readings at the battery than what was being shown on the cigarette lighter, again, purely from what I've read on the forum, never actually tested it myself.
WildBill1990 is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 03:49 PM #19
Yea, I plan on doing a baseline test with an actual multi meter and comparing it to the cigarette lighter.
Old 06-05-2019, 06:30 PM #20
Originally Posted by halflife78 View Post
Ok, appreciate it.
Here's the pics I promised. You will definitely want to go ahead and order some extended leads for your battery cable (see last pic)
Sent from my SAMSUNG-SM-G891A using Tapatalk
Old 06-05-2019, 10:35 PM #21
halflife78's Avatar
halflife78 halflife78 is offline
halflife78 will become famous soon enough
halflife78's Avatar
Appreciate the pics, lemme know what extended leads you find lol since I assume you need some ASAP.
Any issues with the piping on the left the tray sits slightly below?
2016 TRD Pro: C4 Rock Sliders | Victory 4x4 Roof Rack | Ellis Precision Shifters | Blackvue 650s 2 CH | Full Front Clearbra | 20% Tint | Beavertail | Borla S-Type | Pedal Commander | Tail as Turn | DRL LED Foglights | ArcLight Triple State Voltage Booster | Victory 4x4 Front Winch Bumper | Victory 4x4 Front Skid | TRD CAI | SCS Stealth 6 | Dobinsons Lift & UCA | Warn Zeon 10s | Northstar 31m | Factor55 Flat Link | ARCLightLED Hatch/Map/Dome Lights | Lock'er Down Console Safe | XD Door Light / License Plate Bulbs
halflife78 is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 09:33 AM #22
TerraCrawler's Avatar
TerraCrawler TerraCrawler is offline
TerraCrawler is on a distinguished road
Just go with the Slee Offroad extended leads:
Battery and Winch Amp Draw-img_6277-jpg
TerraCrawler's Build Thread
Instagram: @TerraCrawler
TerraCrawler is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 09:35 AM #23
I havent had any with it, I just lifted up on it and the tray flexed back out. as for the leads I'm probably going to go ahead and do a Big 3 upgrade (cost~$60) with the military style leads (cost~$20) which should help the overall power system.
I will eventually be installing a PowerBastards high output alternator to solve voltage issues but in the meantime I found a $30 on-board charger on Amazon (Link) that I can just plug in when I get home every day. if you want you can uprade to this which also has the desulfation feature.
The slee extensions just posted above work really well too for about $50
Old 06-06-2019, 09:48 AM #24
...since I assume you need some ASAP.
Thank god for Amazon Prime lol.
In all reality I can keep using the stock battery for now since I don't have the winch installed yet, but when that happens next month I am not going to have a choice haha need to sell some stuff so I can go ahead and get the alternator
10000lb , 24f , battery , size , winch
1985 4runner battery draw... 88rnr Classic T4Rs 3 08-22-2018 08:59 PM
Portable battery current draw when charging JB. General Discussions 0 11-10-2011 07:29 PM
Phantom battery draw mn_homesteader Classic T4Rs 5 11-04-2008 02:06 AM
Battery Draw coming from Dome light? predatorsniper1 3rd gen T4Rs 2 04-09-2008 07:22 PM
