Originally Posted by nb rob
Everything suspension related in the rear is 19 or 17mm. I’m pretty sure that one is 19mm
It was 19mm. For some reason the nut is bigger maybe like 22mm? The other side of panhand bar has exact same 19mm nut and bolt. Not sure why driver side bolt is so much bigger and different color(black). Seems like that shop might have used different size nut than the factory one.
Anyways, I tried to tighten the bolt, but it would not budge. Strange it got like 5mm gap between washer and the bolt, but it would not move.
So not sure because it would not move, should i call it a day or because there is little gap would it cause problem.
